Question about Hitachi 61SDX01B 61" Rear Projection Television
Screen is red and green and the screen is offset or showing a double image with one being greena and the other red
    President:
  • 788 Answers
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. Your symptom sounds like a damaged convergence IC.
If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, heat sink compound, and some basic soldering skills, you can repair the television yourself.
*** VERY IMPORTANT NOTE***
If your set is not producing a clear picture and the colors are not lining up, do not continue to watch the set as this can lead to further failure and possibly damage the individual CRT’s in the set.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
How do I tell if the IC’s are damaged?
Since you cannot look inside of an IC, you will have to locate some of the components in the area around the convergence IC’s. You may be able to see some resistors that have changed colors or you test a resistor and it no longer reads the value marked by the color bands or the printed value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulator for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts. When you order from them you will get a kit with instructions on how to do the repair, step-by-step.
I hope this information allows you to resolve this issue.
I am doing this for free.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
Posted on Feb 08, 2010
My magnavox tv has double letters in both red and green images on the bottom 2 inches of the screen
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
Blu Ray showing "split screen/double
Did you check your settings on your tv and blu ray?
Jun 04, 2017 | Televison & Video
Picture shows double images in red and green with red and green bands across the bottom of the screen
convergence ICs need replacement there are two STK392-110 Convergence ICs in that model, Also check the 2.2 ohm 2watt resistors there are 6 of them in that model.
Jan 22, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Dec 28, 2009 | Sony KP-53HS30 53" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
I am getting a double image on my 48 inch television how can i get rid of it? it is showing colors green and red on double image
Assuming that your TV is a rear-projection TV, then it sounds like the separate red, green & blue tubes aren't set correctly.
Each tube needs to be alligned exactly to produce the image on the screen. If any of the 3 are mis-alligned then the effect you describe is caused.
Somewhere in the menu settings, will be an option to set the Convergence. This option will allow you to set the allignment of all three tubes.
Older sets do not have this option, and need to be adjusted via controls on the main PCB.
Apr 22, 2009 | Televison & Video
Problem with RGB color...registering as green and image distorted
did u fix your tv cuz thats the same thing thats happening to me
Apr 15, 2009 | Philips 60PP9202 60" Rear Projection...
Double Image Red and Green
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
J.v.c. big screen tv 56-58 inch
my jvc big scrreen worked just fine last night and this am i turned it on and the color is greena and red with double vision can you help
May 25, 2008 | Televison & Video
Hitachi 61SDX01B 61" Rear Projection Television Logo
159 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
