Question about Sony Playstation 3 (PS3) Console
Lost owner manual for ps3 every time try to connect to network it fails need help to set up
Not with the help of u ****
Posted on Feb 08, 2010
Error code for sony 3 807
"Hey, here is a list and a reason of some of the error codes you may encounter whilst connecting your PS3 online, also the required ports need to be opened in order to play online.
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation 3 Error Code List
0710102 - DNS Error; No DSN server available.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
80010510 - Will not play hard drive games - Cause unknown
8002b241 - DVI has no audio.
80028EA5 - Unknown
80029023 - Exchanging Key Information exchange has timed out
80029024 - The attempt to obtain an IP address has timed out
80029564 - Downloaded Game will not install - Cause unknown
8002F997 - Can not update XMB firmware
8003051E - Game will not Save
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Press the x button to repair and restore default"
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.
80710092 - "An error has occured. you've been signed out from the ps network" - (connection dropped?)
80710102 - PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out.
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond"
http://community.us.playstation.com/thread/2996553?start=0&tstart=0
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
PS3 error code downloading patches. Prior fix-ya advise inop. Need help fixing router problem. Conflict with Ps3.
0710102 - Error DNS, DNS server not available.
8001050B - Don't start demos on the hard disk when you have a Blu-Ray added. Unknown cause.
80010510 - Don't start games on your hard disk. Unknown cause.
80028EA5 - Unknown.
80029023 - Exchange of key information timed out.
80029024 - The Attempt to obtain an IP address timed out.
80029564 - Game downloaded does not install. Unknown cause.
8002F997 - You cannot upgrade the XMB firmware.
8003051E - Game does not write.
80031150 - The settings are not be save. Possible System blue screen "Setting information is corrupted. Press the X button to repair and restore default".
80130203 - PS3 connects to the Internet, but not to the PSN. This could mean that the ports needed to connect to Store are not configured.
80710092 - "An error occurred. You were disconnected from the Playstation Network" - (the Internet connection lost?).
80710102 - PS3 can not start the connection with the information configured with the IP router. Try renice the router.
80710B23 - PSN is offline, or the PSN is too busy to respond.
80710D23 - Off the PS3 for a while (30 min) with the AC switch (not standby mode).
80029024 - "Could not get an IP address."
80028EA5 - Unknown - User cannot connect to PSN. Sony said user to take to get the PS3.
8002F997 - Trying to update the PS3 firmware, downloading the update file for USB and attempt to install failed.
80710016 - Playstation Network is offline.
8013013E - WEP keyError, replace WEP key for all the numbers and try again, or to replace WPA.
8013030F - Check page of the router, off SSID Broadcasting.
8002F994 - Many people are making downloading updates. Please try again later.
80028F10 - Go to Settings and choose presentation HDMI (or whatever your connection) and choose Auto, not Custom.
8002A705 - Unable to connect to. Server. Check the router settings doors.
80030920 - An error occurred during the copy operation. The file may be corrupt or there is a lot of memory. Try copy of its original location.
80010514 - total failure of the Bluray drive.
May 06, 2010 | Computers & Internet
Network Failed 4 PS3
Odds are your hijacked connection is being reset by the owner, hopefully for your sake they dont discover your illicit use of their network (cause under new law you are invaiding their privacy and stealing). If you have a computer with wifi capability you should see how often you get bumped (if any) using it, if you dont get bumped then your ps3 has issues and needs a hard reset, this can be accomplished by pressing the power button and holding it down for 30+ seconds until you hear the consol beep 2 times and it restarts, hope this helps
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
Try to connect ps3 to net says the I P address is correct then says dns failed help ?
Go to NETWORK SETTINGS--INTERNET CONNECTION SETTINGS--on prompt select YES--CUSTOM--choose connection type--ENTER MANUALLY--select name of your router (see router's back)--most likely you'll have a wep which is your router's password (see router's back)--Leave IP ADDRESS Automatic--For DHCP Select DO NOT SET--DNS Settings select MANUAL--Type the following no.Given below--Leave MTU Automatic or select 1500 manually--Proxy server DO NOT USE--Enable UPnP--Enter or SAVE....you are done.
Try doing it manually but instead of using your original dns codes do it using these
primary at 4.2.2.2 and the Secondary at 4.2.2.1/3
I hope it helped...
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
Unable to download system upgrade version 2.60
SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > WIRED CONNECTION OR WIRELESS > WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X I thought I should clarify my experience one last time in hopes that it may help someone. I was able to connect fine for a month before the 1.50 update and then things got really wierd. I have gone through entire days unable to connect to the network and entire days able to connect. Meanwhile I had full use of the PS3 internet browser and no other computer or internet issues. I can currently confirm that if I return my PS3 internet settings the original "automatic" settings I will not be able to connect, with these DNS settings in the PS3 I have no problems. I have cable internet access through Adelphia with a Linksys WRT54GS router communicating wirelessly with my PS3... GOOD LUCK!
The information I used to create this fix contained a link that has provided us with router specific DNS information to be used if the numbers provided do not work. http://www.opendns.com/start/at_home.php
Now, a day later, I am able to connect with the original automatic settings for everything including DNS. I must also point out that the network performance is much faster using the automatic settings and recommend using alternate DNS settings only when neccessary.
All I can say for those still having problems is reboot EVERYTHING. Your router, modem, PS3 and any other device that may be connected to your network.
If you still have problems try connecting the ps3 directly to your modem not through the router...
Jan 23, 2009 | Sony Playstation 3 (PS3) Console
Ps3
check your router setting will acept ps3 you can get into router by typing router ip adress into search bar on pc router ip settings will be in router manual ,hope this helps
Jun 22, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wireless hook up
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Windows Vista
1. Click Start --> Control Panel --> Network and Sharing Center
2. Click on "View Status" to the right of your connection
4. Click Details
Set these values under "manual settings" in the PS3 but add 1 to the last number for the IP Address as this has to be unique on your network
Apr 13, 2008 | Sony Playstation 3 (PS3) Console
Internet connection failed but IP address obtained.
OK IF YOU HAVE PS3, and you get the ERROR DNS while trying to login into PSN, all u need to do is, shutdown the console, then restart it by holding down the ON button on the PS# not the controller till you hear 2 beeps, then try to login again, should work.
Nov 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
