Question about GE (PSS26MSRSS) Side by Side Refrigerator
My ice despencer and water no longer works nor
My ice despencer and water no longer works nor do the buttons light up
  • 572 Answers
There a board behind the dispenser. migh be out
Posted on Feb 08, 2010
How do you unlock the ice despencer on the door?
Press and hold the lock button again. The same action which locks it should also unlock it.
Apr 30, 2015 | Samsung Refrigerators
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
I have a gsl25jf side by side. Ice will not dispense - ice continuess to be made. Water will dispense - after you try to have ice dispense from the door there seems to be a clicking sound the lights dim on...
PULL THE ICE DESPENCER OUT AND RUN HOT WATER OVER IT AND START FRESH . IT MIGHT JUST HAVE A ICE JAM, I HAVE SEEN THIS BEFORE, THE ICE BUILDS UP IN LAYERS AND WONT ALLOW THE TREY TO SIT IN SNUG TO THE MOTOR .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | GE GSL25JFPBS Side by Side Refrigerator
The ice in the tray melts and runs out the despencer outlet.\r\nMakes ice but the front part of the ice tray slowly melts and water runs out the despencer outlet. Have had service man work on it four...
Your freezer temperature is not coldenough, inspect for hardness of frozen foods. Make sure that the temperature is 5 degrees Fahrenheit or lower. Carefully feel the side of the ice maker if itis warm the unit is stuck in heat for release mode. Check and replace control module.Call repairman to check this.
Thanks
Feb 05, 2011 | Electrolux Refrigerators
Ice/Water despenser Problem- not working(no lights on the button)
Replace the main control board . Pt # WR55X10942 is the part number . The dispenser board has lost communication with the main board . The main control board is behind the refrig , behind the small 8X10 inch panel . There are 6-8 group plugs which will only fit in perspective plugins , so this board is easily replaceable . Cost of board is about $150.00 .
Jul 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge ice maker stoped working
Check out the tray heating element that is designed to melt the ice slightly so it can be scooped out into the waiting tray.
If there is no water or ice in the tray, then check out the solenoid that allows water into the system.
Apr 19, 2017 | GE LightTouch GSC23LSRSS Side by Side...
Ice despencer won't make ice any more
Is it the despencer or the icemaker which thing showing the problem makes a difference to giving you info on the repair.
Jan 31, 2008 | Whirlpool GS6NBEXR Side by Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
144 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
