Question about Samsung LN-S4095D 40 in. LCD HDTV
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture, but the problem repeats the same way. When it works for half to one hour, before the image disappears, the colors are getting stained with other colors (I can't describe it more precisely) and the image flickers vertical white lines for a few seconds before the image goes black.
  • 2,326 Answers
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
Posted on Jun 11, 2017
5 Suggested Answers
SOURCE: vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Posted on Apr 21, 2008
  • 11 Answers
SOURCE: Samsung LN-S4041DX 40 in LCD TV
Hi. You can try to go into service mode and reset the LCDTV to Factory Default. This will clear out all buffer over run's and any software related issues. It may fix the problem or it may not. If this doesnt fix the problem than you need to have a qualified Technician to look at it. The problem is in the AV circuit board, a technician who is qualified to repair electronics at circuit board level should be able to repair this problem rather quickly and inexpensively. Most technicians who do not have the expertise in repairing cicuit boards to component level would rather replace the whole AV board than repair it and this will be rather expensive.So talk to the repair shop before you drop the TV off.
Be very careful when accessing service mode. I suggest to write down all information in all areas before proceeding to a factory reset. If you do not record all values correclty you run the chance of not being able to use the TV again. To go into Factory Service mode, use the original remote and in this sequence push POWER OFF-MUTE-1-8-2-Power ON, the set will turn on and enter service mode, if you hit all previous keys correctly. If it doesnt try again. When you are done hit POWER OFF and this will exit service mode and save the data.
Posted on Jan 28, 2009
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
  • 11361 Answers
SOURCE: we have a samsung tv
Similar to this?
It can be T-CON, Power supply, LCD panel.
Learn more about T-CON/LCD panel here (not just for SONY TV): PDF download
Also read my guide:
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 11, 2011
When we turn our TV on we get sound, but our picture is distorted for about 15 min then it's clear. Any sug?
Your TV is about 5 years old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 26, 2015 | LG 46LD550 46 in. LCD TV
Samsung LN-S4095D HDTV Screen Glitching
look to see if same issue with a DVD etc connected to a rear input.
Jun 07, 2012 | Samsung LN-S4095D 40 in. LCD HDTV
I have a Samsung LCD (LN-T5271F) about 2 years old and lately when I turn it on, it clicks on and off several times before it actually stays and the tv comes onI have a Samsung LCD (LN-T5271F) about 2...
Call Samung customer service, they are doing this repair for free. I had the same problem at 11 months, they replaced the power supply board under warranty. At 2 years I had the exact same problem again and this time they replaced 2 - 50 cent capacitors on the power supply board. It took the repair man less than an hour and he had the replacement capacitors on hand. The original board and the replacement board they gave me had capacitors that were faulty. Hopefully these new capacitors will last. I have to say that I was thinking (no more samsung products for me) but I got excellent customer service and they admit that they had a faulty product and they accepted responsibility.
Apr 26, 2010 | Samsung LN-T5271F 52 in. LCD Television
Thmy samsung LN-T3242H - 2 years old - the picture
Make sure under your audio options you are in stereo mode and not it SAP, (Special Aided Programing).
Dec 24, 2009 | Samsung LNT2642H 26 in. LCD Television
No picture on Samsung LNS4051D HD TV.
Maybe the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
Jul 24, 2009 | Samsung LN-S4051D 40 in. LCD Television
Picture stays on for 3 mins, then slowly disappears
sounds like the filament of the picture tube is losing voltage. normally this would be caused by a bad/broken/cracked solder connection. If this is the problem, it may not be too dificult to fix if you have the soldering skills and know what to look for.
Dec 15, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture appears to be cracked
It is cracked. Maybe not the first layer, but for sure the lcd is cracked. This is the reason why you found it on the garbage. The lcd panel is way more expansive like the tv itself. You can sell it on ebay for parts.
Dec 31, 2007 | Samsung LN-S4095D 40 in. LCD HDTV
Help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
I had the exactr same problem with P#3 and the same model of TV, I turned of the 24 hz setting as you suggested and it si workign great! The only thing I am wondering is what ewxactly the 24 Hz setting is. The actual title is "BD 108P 24 HZ output. I didn't turn off 1080P did I? Don't think so as picture looks great. Even though I didn't ask the original question I REALLY appreciate the answer!
Dec 24, 2007 | Samsung LN-S4095D 40 in. LCD HDTV
Open Questions:
See all Samsung LN-S4095D 40 in. LCD HDTV Questions
Samsung LN-S4095D 40 in. LCD HDTV Logo
91 people viewed this question
Jerry Greenberg
Jerry Greenberg
