Question about Electrical Supplies
Circuit breaker trips out when all lights on the circuit are off.
The circuit trips out after being on for a period of time with lighting on or it trips out overnight when all lights are off. Have replace the circuit breaker but still same problem.
  • kevwest Feb 08, 2010
    Was electricians suggestion.
  • 43,501 Answers
You have a dangerous situation there. If the breaker is tripping like that and espec. if you have no load on it then there is an intermittent short that is happening in the circuit somewhere. The hot wire is shoeting to the neutral or ground wires at some time... This will cause a fire if you leave it and do not find the cause. The best fix would be to rewire the whole circuit if you can not find the cause of the short. To identify the short look for a black spot in the wiring some wher. the arc from the short will cause a burn mark when it happens..
Good luck and be careful!!
Heatman101
Posted on Feb 08, 2010
Testimonial: "Thanks, but can't work out why doesn't stay shorted."
  • D. Floyd Kolb
    D. Floyd Kolb Feb 08, 2010
    Please get a professional to look at your wiring... It is impossible for someone at a keyboard miles away to get you to the cause of your problem. That will need to be done hands on.
    Heatman101
  • 12,061 Answers
No No NO.... One NEVER EVER just replaces the Breaker. As any sort of FIX. You MUST Always find the CAUSE, as you run the risk of FIRE, It may cause a fire at night... NOT GOOD. You MUST find the fault... PLEASE Get an Electrician. Your Life is worth more than a Circuit Breaker. I have been doing this for over 30 years now, I DO know what I am talking about.
  • gregshuffiel Jan 07, 2011
    what if you added a couple of outlets.and something like the microwave will trip the breaker when the air window unit is on...could you go from 20 amp to a 30 amp if you can see that the circuit simply has too much draw
2 Suggested Answers
  • 142 Answers
SOURCE: The Lights circuit breaker keeps trips without load
try a new breaker, they do wear out over time
Outlets not working all fuses are good
120-
VOLT
AC
SYSTEM
The following electrical components (if so equipped) will only operate when your
RV is connected to shore power: 120 to
12-volt power converter, air conditioner,
120-volt refrigerator, microwave oven, television(s), fireplace and appliances
plugged into convenience receptacles.
SECTION 6 - ELECTRICAL SYSTEM JAYCO TOWABLE
6-2
120-
VOLT
CIRCUIT
BREAKERS
The 120-volt AC circuit breakers located in
side the main load center protect all
120-volt wiring and components in the RV fr
om circuit overloads and short circuits.
Should a circuit overload or short circui
t occur the circuit breaker protecting the
affected circuit will "trip" preventing the flow of electricity through that circuit.
If a circuit breaker trips, shut "off"
the appliance on that circuit (i.e., power
converter etc.) and allow the circuit breaker to cool down for a brief period of time.
After the cooling down period, reset the circuit breaker by moving its lever "off" and
then back to the "on" position. If the circuit breaker re-trips or frequently trips,
contact your dealer to have the electrical problem diagnosed and repaired.
A circuit breaker identification label is permanently attached to the inside surface
of the 120-volt load center.
Maintenance and Replacement
At the beginning of camping season, inspect the circuit breakers and replace as
needed. Test by turning each circuit breaker "off" and back "on". Circuit breakers
are wearable parts and must be replaced
as needed, as part of your RV
maintenance. If you have any questions, consult your dealer.
Please contact your dealer for repair assistance when replacing circuit breakers.
CONVERTER
The power converter converts 120-volt AC power to useable 12-volt DC power
when the shore power cord is connected to an external power source.
The converter has a built-in protective thermal breaker that will shut it down should
overheating occur. Overheating can be
caused by operating the converter above
its maximum power output for an extended period of time, or by an obstruction to
its ventilation air flow. To reduce converter heat build keep unnecessary 12-volt
lights and motors turned "off"
Keep the converter cooling fins and fan clear of
obstructions.
Inspection and maintenance
If the 12-volt power converter is not working (auxiliary battery not being charged)
check the reverse polarity fuse(s) in the converter fuse panel.
There are no
customer serviceable parts inside the converter case and the
manufacturer's warranty will be void if
the case has been removed
. If you
have further concerns contact your dealer.
Nov 16, 2014 | Jayco 2013 Jay Flight Swift 264BH
Suddenly, turning on my light switch trips the circuit breaker. I tried changing the light switch and it still trips the circuit breaker. How can I fix this problem?
It sounds like the problem is in your light. Leave your circuit breaker in the OFF position, as well as, the light switch. Then, take down the light, or lights...and check out each connection in the light box. It's best to do one at a time, this way you can go by process of elimination. If there's a lot of lights working off this switch. You can disconnect all the lights from the middle of the room. Put wirenuts on all the bare wires, and then try and see if your lights come on without tripping the circuit. If it trips, then you know the problem is further down the line. I'm going to assume there's only one or two lights, so take them down and check the splices (connections). It seems like you have a loose wire at one of the lights. Please feel free to check back with me if you have any further questions. Good Luck! - Jim
Jun 05, 2014 | Leviton Electrical Supplies
Why are my circuit breakers rapidly tripping?
circuit breakers working indicates an overload of the circuit probably from a short in the wires or relays . Circuit breakers are resettable fuses and if you had fuses instead by now you would be hunting the fault as replacing the fuses all the time becomes a bore.
Apr 26, 2014 | 1999 Dodge Ram 2500 4WD
Arc fault breaker trips when you turn florescent and can lights on
Sounds like something is wrong with the light check the wiring. Unhook the light and try ther breaker if breaker does not trip then problem is in the circuit.
Jul 24, 2011 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Electrical problem, dashboard gauges, turn siginal and brake lights will go off and then come back on for a short period of time then go back out. This is on a 1989 Ultra Glide Classic
You've got a short circuit somewhere in your lighting circuit. It's cause in too much current to flow and tripping out the circuit breaker. The ciricuit breaker resets itself after a few minutes that it needs to cool off. Once it resets and the short has not been fixed, it'll trip again. This will continue until the short circuit is found and repaired.
If you need a schematic, I have one and will gladly e-mail you a copy if you'll contact me directly at wd4ity@bellsouth.net. This forum will not allow for a file size of over 150Kb. Remind me of what you want. It wil consist of three JPG files. No charge.
Once you get the schematic, study them well. I'd start by looking for any light that did not work. Trace the wires for that light. Has the headlight been changed to a higher wattage? Do all the turn signals work? Tail light? Brake light, front and rear? Check all lights and then if you must disconnect the lights one at the time.
Good Luck
Steve
Nov 07, 2010 | Harley Davidson FLHT Electra Glide...
I have a 1995 Buick Century that out of the blue last night, the dash lights, headlights, radio, and dome light quit working. Today I checked the fuses, unplugged the battery to reset the ECM, and fished...
There could be a timed circuit breaker:
Circuit Breakers The headlights are protected by a circuit breaker in the headlamp switch. If the circuit breaker trips, the headlights will either flash on and off, or stay off altogether. The circuit breaker rests automatically after the overload is removed. The windshield wipers are also protected by a circuit breaker. If the motor overheats, the circuit breaker will trip, remaining off until the motor cools or the overload is removed. One common cause of overheating is operation of the wipers in heavy snow. The circuit breakers for the power door locks and power windows are located in the fuse box.
Oct 13, 2010 | 1995 Buick Century
Eaton Arc Fault Breaker type BRAF tripped. I reset it but lights will not work. Ideas please?
My arc fault breaker trips in my bedroom when ever a load is put on line. The trunk line comes into a three gang switch box and feeds the entire room. At times I can turn my ceiling fan and light on for 10 to 20 minutes before the breaker trips. Other times the breaker will trip when either switch is first turned on. I plugged a 4 watt night light in a wall receptical, without the ceiling light or fan on, it also trips the breaker. I have had other plug in lamps, 60 watt, work in other recepticals for a while. The problem seems to appear in all recepticals and lighting in the room.
Feb 19, 2010 | Eaton ARC FAULT CIRC BREAKER
I'm trying to connect a GSW-SK door switch to an led rope light. The circuit breaker trips every time I plug the power cord into the outlet. Any ideas?
The circuit breaker trips because you have some sort of short circuit. Use a Meter set to OHMS, and try to find the "Short". Check the wiring in the Plug also.
Feb 11, 2010 | Gardner Bender #GSW-SK Door Switch
Feb 08, 2010 | Electrical Supplies
I have a 15 amp single pole circuit breaker that
It could be either or at this point. First thing to do, is unplug all electric devices from the plugs on that circuit, and then attempt to reset the breaker. If it does not trip, one of the devices plugged into a receptacle on that circuit could have a short. If it doesn't trip, plug each device in one at a time to see it it trips the breaker to pin point what is causing the short. If the above has no effect, I recommend replacing the breaker. It is easy and inexpensive to do. Just make sure you main is shut off before doing any work on the panel. I hope this helps and good luck!
Nov 06, 2009 | Connecticut Electric & SWITCH UBIP130...
Electrical Supplies Logo
1,591 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
