Computers & Internet Logo
Posted on Feb 22, 2008
Squid problem i m configure squid in linux sever but the clients can not able to send mails through outlook.give me any solution........................
  • moryans Feb 22, 2008
    thanks in advance
  • Anonymous May 11, 2010
    I could not understand that why squid comes into picture when you use outlook to send mails. for sending mails is required a SMTP address .... and squid is for internet accessing using internet explorer or else.
    Are you using this SMTP through squid...
    If that is so, pls send me the squid.conf...file snipppet...
    Please be more elaborate....
    Cheers - Parveen
Anonymous
Level 1:
  • Contributor 45 Answers
  • Posted on Feb 23, 2008
Anonymous
Contributor
Level 1:
Answers
45
Questions
0
Helped
22127
Points
98
Sorry dear...you cannot configure squid for that ...since squid is a http proxy ..cannot operate it in use for smtp/pop3 connectivity ....
Cheers - Parveen
Can not send e mail
Why not? Are you connected to the internet to send it? Are you using your email client (AT&T, Yahoo, Gmail, etc.)?
I've seen people be on websites or doing something on the computer and all of a sudden click the send email option without being in their email client. This brings up Microsoft Outlook and unless you've configured Outlook as your email client, it is not going to send the email.
tip
How to configure your squid in linux
To configure squid proxy go to
/etc/squid/squid.conf file and then change its port no. from 3128 to 8080.
this is the http port that squid proxy listen for .
Then create your own access list
acl_access name_access_list src networkaddress
Then finally u have the power to allow or deny the particular network
http_access allow name_access_list
Just follow the above three steps to let squid work properly.
You must enable ip forwarding also.
for this go to
/etc/sysctl.conf
in it on the line
net_ipv4 forwarding=0
change it to 1
this will enable the ip forwarding
you can check ip forwarding by
sysctl -p
How to connect yahoo mail using windows mail in Windows 7
You cannot configure Yahoo account with Windows live mail.
And the reason you are getting the error because you have Micosoft outlook in the pc and that email client (MS outlook) is not configured with your yahoo mail and it is not the default email client in your PC. Windows live mail is the default email client in your PC and you cannot configure Yahoo account in windows live mail.
Aug 01, 2010 • Yahoo Mail
My new laptop is not sending email because there are 400+ emails coming in mostly junk I am sure.
Is anything preventing you from entering your mail box? If not, go to you mail box, use a Select All (CTRL A) and delete all the junk. Once you regain control of your mail box, configure your Email client (Outlook, Outlook express or other) to automatically send certain Emails to a junk mail box.
If your current Email client is limited in functionalities, you may find Mozilla Thunderbird more appropriate.
Hope it helps
C# code how to access outlookexpress
in C# code you just need to use FCL classes to send mail such as SENDMAIL it will automatically choose default mail client configured o n your system(hence you can use default mail client as outlook express.
Plese rate this article if you find it useful
3answers
Obtain low bandwidh in linux
Sorry, I have no idea about Linux. Could be the software that is causing this issue..
I have forwarded this request to other Experts here who have more knowledge on this subject. Hopefully they should respond to your query within the next couple of hours..
1helpful
2answers
Download MAil From JAna SErver
Hello Sir,
As my internet is shared through cc proxy
I have to put proxies to all of my programs so that they can run.
Unfortunatelly the only one I cannot get running is outlook express.
When I try to edit the outlook proxy settings it sends me to Internet Explorer's settings
(which makes me think that outlook and internet explorer share the same proxy settings).
The strangest thing is that IE runs with no problems
but outlook express cannot connect to the server.
It says that the server cannot be found (both incoming and outgoing)
Could you please advise me how to make the outlook running.
Also I had try to install squid 2.7 proxy on win2k8 but i m getting some error with squid service is not runniong on win2k8 it says create services failed ...please advice me which proxy server i can use our network ( my task is only i want 2 secure internet & block some sites on my internet and outlook should be a work )
Thank you very much.
Have a great day,
Regards
Ashok
2answers
Mail server setup issue
Create the New Account(User), and Configure all the new settings.
Firewall is not configered is linux centos
try and go for it..all d best...
Use yum command as follows:
# yum install squid
Output:
Loading "installonlyn" plugin Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package squid.i386 7:2.6.STABLE6-4.el5 set to be updated --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: squid i386 7:2.6.STABLE6-4.el5 updates 1.2 M Transaction Summary ============================================================================= Install 1 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 1.2 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: squid ######################### [1/1] Installed: squid.i386 7:2.6.STABLE6-4.el5 Complete! Squid Basic Configuration Squid configuration file located at /etc/squid/squid.conf. Open file using a text editor:
# vi /etc/squid/squid.conf
At least you need to define ACL (access control list) to work with squid. The defaults port is TCP 3128. Following example ACL allowing access from your local networks 192.168.1.0/24 and 192.168.2.0/24. Make sure you adapt to list your internal IP networks from where browsing should be allowed:
acl our_networks src 192.168.1.0/24 192.168.2.0/24
http_access allow our_networks
Save and close the file. Start squid proxy server:
# chkconfig squid on
# /etc/init.d/squid start
Output:
init_cache_dir /var/spool/squid... Starting squid: . [ OK ] Verify port 3128 is open:
# netstat -tulpn | grep 3128
Output:
tcp 0 0 0.0.0.0:3128 0.0.0.0:* LISTEN 20653/(squid) Open TCP port 3128 Finally make sure iptables is allowing to access squid proxy server. Just open /etc/sysconfig/iptables file:
# vi /etc/sysconfig/iptables
Append configuration:
-A RH-Firewall-1-INPUT -m state --state NEW,ESTABLISHED,RELATED -m tcp -p tcp --dport 3128 -j ACCEPT
Restart iptables based firewall:
# /etc/init.d/iptables restart
Output:
Flushing firewall rules: [ OK ] Setting chains to policy ACCEPT: filter [ OK ] Unloading iptables modules: [ OK ] Applying iptables firewall rules: [ OK ] Loading additional iptables modules: ip_conntrack_netbios_n[ OK ] Client configuration Open a webbrowser > Tools > Internet option > Network settings > and setup Squid server IP address and port # 3128.
See also You may find our previous squid tips useful:
Grand Canyon Tech
Grand Canyon Tech
