Question about Fisher Washing Machines
Fault 247 fisher & Paykel aquasmart. Not washing Only spinning
5 Suggested Answers
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
SOURCE: Our Fisher & Paykel Washing Machine is not
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Posted on Sep 30, 2009
  • 713 Answers
SOURCE: Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
Posted on May 27, 2010
  • 251 Answers
SOURCE: Fisher paykel aquasmart top loader washing
Hi - you have possibly some restrictions in/around your smart pump unit, inside is a flapper valve suppose to control flow in both directions, often this gets the rough treatments.
Be careful if you wish to have a nosy its located beneath the smart agitator.
Posted on Jun 18, 2011
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Jul 31, 2014 | Fisher and Paykel Washing Machines
Out of balance
Have you replaced the suspension damper rods on the machine
these also need replacing at the same time.
Jun 13, 2013 | Fisher and Paykel Washing Machines
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Service error 247
247. (11110111) SmartPump Flapper Fault
The Motor Control Module has registered a drop in the water level during the recirculation
phase of the wash cycle. Water is being drained instead of recirculated. The most likely
cause is that the flapper is stuck in the drain position.
Primary Source: Flapper valve.
Action: Check for free movement of the flapper (replace if broken or
damaged).
May 09, 2012 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aquasmart top loader washing machine continuously comes up with fault 247 when trying to spin. Appears to be a balance problem as rearranging clothes and a restart allows it to...
Jun 18, 2011 | Fisher and Paykel Washing Machines
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Sep 03, 2008 | Washing Machines
Washing Machines Logo
495 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
