Question about Microsoft Xbox 360 Console
Xbox 360 software malfunction, but no red lights
My xbox 360 does not have any red lights, but when I turn the system on the dashboard just pops in and out. Is there anywhere I can download the existing firmware for the xbox so that I can reset everything.
  • 340 Answers
You may have a corrupted update, try this.
1.Turn off console
2.Press and hold the sync button on your console
3.Keep pressing the sync button and turn your console on
4.When the console has fully rebooted, let go of the sync button
this will clear any corrupted updates.
If you need to download any updates just google, downloading updates to console.aspx you should find all the updates you need here.
Remember thumbs up if this helps.
Posted on Feb 08, 2010
Testimonial: "thanks for trying :)"
My xbox 360 has a red ring on it and the dashboard won't come on. how can I fix it?
i have an xbox myself and ive never heard of it lighting up red. it could be damaged in the circuit board and the red light could be the way the system is telling u there is a problem
Dec 18, 2011 | Microsoft Xbox 360 Elite Console - Black
The xbox is saying my acount is courrupt
Turn on your Xbox 360 console.Access the Xbox 360 dashboard, go into "system settings," then into the "memory" option and Delete profile if it is shown as corrupted. The profile is damaged.Sign out of your profile if you are already on. Press the Xbox guide button, press the X button and select the option "Yes, sign out."Go into the "My Xbox" section of the dashboard.Select the option "Recover Gametag" in the Xbox 360 dialog box. Press the A button on your controller to select the option. Follow the instructions to repair your profile.Enter your Gamer-tag in the "Xbox Live Gamertag" dialog box that pops up.When the process is completed, your avatar will appear in the "sign in" area of the dashboard.
Feb 18, 2011 | Microsoft Xbox 360 Console
Three red lights
Three red lights error occurs when there is a general hardware failure with the Xbox 360. When this error occurs the systems signals it by showing 3 flashing red lights around the power button. There are a variety of reasons speculated why this error occurs.
The most common consensus is that the Xbox 360 has an inefficient design causing it to overheat. The overheating causes other reactions to the parts in the system to malfunction giving you the 3 flashing red lights.
So how do you fix it? Well if you still have your Xbox 360 warranty then you can ship it to Microsoft to have them fix it. Microsoft has extended the warranty to 3 years due to the huge number of problems with the consoles. There are a few stipulations to the warranty, though.
  • Only covers the Red Ring of Death Error. It does not include other types of malfunctions.
  • Applies only to the original purchaser of the Xbox 360. So you would not be covered if you bought your system from somebody else or if you purchased a used version.
  • Must have your receipt or proof of purchase.
  • Be prepared to lose any saved information that you may have if Microsoft decides to send you a replacement system instead of fixing your old one.
  • Prepare to be without your Xbox 360 for up to 4 weeks or longer, although some people have reported receiving them back much sooner.
So if your system is still under warranty and you meet the requirements above then you can send your unit to Microsoft since they do not charge you for the repair.
Dec 23, 2010 | Microsoft Xbox 360 Console
How do i connect to live?
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live".
applysettings.jpg3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Edit Settings" then "Additional Settings" tab then select "Advanced settings" & put the Physical Address of your PC without the dashes on the "Alternate MAC Address" part and select "Done", when it asks you to Apply Settings choose "Test Xbox Live".
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live". editbasic.jpg3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you'll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Default" when it asks you to Apply Settings choose "Test Xbox Live".
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose "Test Xbox Live".
If you faced any other kind of troubles with this part failing even after you tried these steps please don't hesitate to leave a comment.
Read more: http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html#ixzz14pRocyB3
Nov 09, 2010 | Microsoft Premium System for Xbox 360
Xbox 360 wireless adapter 1 red flash of light
Hi Sir
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Please Rate
Jun 09, 2010 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 Console: my xboxs 360 has three red lights flashing...
Hi Sir
Please Rate
May 17, 2010 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
Everytime i turn my xbox 360 on a red light comes
also know as the ring of death, its a software issue and you need to replace your system
Dec 30, 2009 | Microsoft Xbox 360 Console
Xbox 360 comes on dashboard pops up but wont go to the game
If you have uploaded the updates, this happens all the time. you must go to "my xbox" option and there will be a disc there. Hit "A" and it will play the disc.
Feb 24, 2009 | Microsoft Xbox 360 Console
My Tray Door popped open after two red lights shut down console and won't close!
Here is a great page that has a step by step process for opening your unit. (they also sell parts and mod equipment)
http://www.llamma.com/xbox360/repair/Xbox-360-Disassembly.htm
You may need a new drive, but I doubt it. After you get the Xbox open, peel off the silver tape thats on the bottom front of the DVD player, unplug the 2 connections, and lift it out. Turn the player upside down and remove the 4 screws, flip it back over and make sure that the try is lined up correctly with the mechinism.
I hope this helps. Good luck and happy gaming!!
Sep 12, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
61 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
