Question about Bosch SHU5316UC Dishwasher
Bosch SHU5315UC dishwasher doesn't end cycle
The SHU5315UC runs for a very long cycle and sits with 1 minute to go for a long time
  • 572 Answers
Make sure 120 degree water enters the diswasher
Posted on Feb 08, 2010
Bosch Dishwasher Model SHU5315UC/U06 Looking for Cycle Buttons That are no longer avail #176079
There are several places on-line where you can find this parts. Depending on where you are. For example you can look up www.dlpartsco.com
May 08, 2016 | Bosch Dishwashers
How do I run a diagnostic test on the Bosch shu5315uc/u12? The cycle time of my dishwasher is at least 4-5 hours.
Long running time on a Bosch dishwasher is almost always a blown solder joint at the heater relay on the control board. You can resolder the joint, replace the relay or replace the control. Control board part number is 00266746.
Jan 13, 2015 | Bosch Dishwashers
I have a Bosch SHU5315UC and the only cycle that will run is the rinse/hold. None of the other cycle buttons will work. It seems as if they have no resistance or spring back when pressed. Any ideas?
Depending on age and other factors; key pads do wear out and require replacement. Many of these controllers us a silicone positive touch system like the keypad on a computer. Others use a direct contact system that has a spring action and contact points. If the later fails, it can be due to use, a breakdown of the recoil system, or damaged contacts.
Mar 17, 2014 | Bosch SHU5315UC Dishwasher
Our Bosch dishwasher has a water sensor that affects the length of the dishwasher cycle. Lately, the cycle will go down to 3 minutes, then sit there running at that time for several minutes and then jump...
check on manufacturers review sites , there may be something simple like it just needs to have a descaler fluid run through it to clear any debris or dirt contaminating the sensor unit itself.
Jan 09, 2018 | Bosch Dishwasher NTC Sensor 165281
Won't complete the cycle
Hello, welcome to Fixya.
The reason your dishwasher is displaying a "1" is the control has detected a heating error. Here`s why...
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
macmarkus :)
Apr 26, 2010 | Bosch SHU5315UC Dishwasher
Cycle runs forever
Th Bosch units are prone to circuit board failure and this is the common symptom. If you are electronically inclined go the applianceaid.com and search Bosch for test codes to pinpoint the issue.There is an online picture of the faulty relay solder joint I repaired mine and a neighbors, Bosch will in some cases supply parts at no charge and they do not recommend repair, however IMHO it is a repairable cold solder joint very visible on the board. If you are good with needle tip soldering iron you are in luck
Sep 07, 2009 | Bosch SHU5315UC Dishwasher
2002 Zuma starts, runs for 1 to 2 minutes then shuts off.
There is a very good chance your fuel tank vent is plugged. This causes basically a vapor lock thus no fuel is able to reach the carburetor or fuel system. By letting the bike sit you are essentially letting fuel get through the system enough to let it run for a few minutes. So check for pinched vent tubes, this happens frequently after you have a routine service performed and the tank is removed.
Good luck and let me know if this helps you.
Jun 18, 2009 | 2005 Yamaha XT 125 R
Bosch dishwasher SHU5315uc control board issue
Check the main smoothing capacitor on the control board. Could be low value.
Jul 24, 2017 | Bosch SHU5315UC Dishwasher
Bosch SHU5316UC Dishwasher Logo
584 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
