Question about DeLonghi XU33 Alfredo Elite 1500 Watts Toaster Oven with Convection Cooking
My Delonghi toaster oven has a heating element (one of 2 long narrow rods going across the bottom of the toaster oven) that split open. I am assuming this is dangerous. Am I right? Can the heating element rod be replaced in these ovens?
3 Suggested Answers
SOURCE: Heating elements
The upper element for AS690 is part# 512623
Thw lower element for AS690 is Part# 512624
Available at www.nelsonappliance.com/Toaster+Oven+Parts.html
or
http://abtecparts.com/delonghi_toaster_oven_elements.htm
Posted on Jul 27, 2008
SOURCE: Delonghi AS690 toaster oven lower element won't turn on.
Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
Posted on Nov 14, 2009
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
HEATING ELEMENTS
The heating elements are inside on the top and bottom
Jun 08, 2013 | Bella Cucina 13049 1500 Watts Toaster Oven...
The lower electric elements are twisted and do not put out the proper amount of heat Can they be replaced
Go to the DeLonghi website. You can probably email them or maybe even call them. Also, here is an address that will bring up a list of places that sell oven parts. Copy and paste it into the address bar.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http"//www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 01, 2011 | DeLonghi AR680-Stainless Steel Toaster...
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Bottom heating element warped then stopped working
can you get in to replace the element?then do so if you can it is easy just look how it was put in as you take it out to replace it!
Sep 28, 2010 | DeLonghi AD699 Airstream Digital 1500...
Bottom elements on DeLonghi AD699 failed.
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
BOTTOM ELEMENT DOES NOT WORK
If the top element is working, then it is either the element, the wiring harness , or the control board.
Since both elements are controlled through the same temperature probe, then the temp. probe should be OK.
The heating element must be removed and tested using a multimeter.
The part is tested disconnecting wiring from element contacts, setting a multimeter to read impedance at Rx1, and reading Ohms on element contact.
If the circuit is open (no continuity and infinite Ohms value), then the element has blown and must be replaced.
If the element has continuity, test the wiring harness, then replace wiring harness or control board.
All the test must be done by a trained repairer, strictly observing all health and safety rules.
Regards.
Oct 21, 2009 | DeLonghi EO1238 Toaster Oven with...
Heating elements
or
Jan 03, 2008 | DeLonghi AS690 Airstream Stainless Steel...
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
DeLonghi XU33 Alfredo Elite 1500 Watts Toaster Oven with Convection Cooking Logo
476 people viewed this question
Top DeLonghi Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Craig Butler
Craig Butler
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
