Question about RTO Construction Bobcat by Woody Click
I get code 32-49 Lift actuator short to ground.Does this mean I have to replace the actuator?
  • 32 Answers
Switch lift and tilt actuator plugs and see if problem changes to tilt actuator fault. If so yes replace lift actuator and calibrate actuators.
Posted on Nov 17, 2012
Need to replace the liftgate switch, where can I get instructions to do that?
How do you know it need's a switch ?
Rear Hatch/Gate Description and Operation
The lift gate can be opened by operating the switch on the instrument panel. Battery voltage is supplied to the lift gate actuator through the body control module (BCM). The BCM will pulse the lift gate actuator when a release input is received through the key fob, or the instrument panel switch. Did you test voltages ? Check for BCM DTC'S - diagnostic trouble codes ?
Circuit/System Description
The lift gate switch is an input to the body control module (BCM). The BCM supplies battery voltage to the signal circuit and when the lift gate switch is activated the signal circuit voltage goes low. The BCM controls the lift gate release actuator assembly through the LIFTGATE relay. When the lift gate switch signal is activated, the BCM enables the LIFTGATE relay by applying battery voltage to the lift gate relay circuit and the relay is energized when the BCM grounds the LIFTGATE relay control circuit. When the relay is energized battery voltage is supplied to the lift gate release actuator assembly through the lift gate release actuator control circuit.
May 29, 2016 | 2008 Pontiac Torrent
I have 2005 chevy tahoe my doors all licks but my liftgate door with window stays open use to lock w all my doors? I havent check anytjing yet? I cant lock it.
Here is how it works !
Liftgate Locking Operation
The lift gate will lock any time the vehicle is shifted out of park on vehicles equipped with an automatic transmission and at vehicle speeds exceeding 5 kph with manual transmission. This happens in conjunction with auto door locks if enabled or independently of auto door locks if the feature is disabled. This ensures that the lift gate is locked anytime the vehicle is shifted out of park or when the vehicle is in motion.
The lift gate lock relay supply and coil sides receive a constant voltage through the battery voltage supply circuit and the ECC fuse. The normally closed contact is connected to ground and the control side is connected to the body control module (BCM). A lock function will occur when a door lock switch activation, keyless entry lock transmission, auto door lock function or a lift gate lock function has been received by the BCM. The BCM will then ground the control side of the lift gate lock relay. This energizes the relay and allows voltage to be applied to the lift gate lock actuator lock control circuit. Since the other side of the lift gate lock actuator is connected to the normally closed contacts of the door unlock relay to ground, the lift gate will lock. When an unlock function occurs the BCM will ground the control side of the unlock relay and the rear doors and lift gate will unlock.
The BCM also runs diagnostics on the lift gate lock relay control circuit and will set DTC B3825 as current and also send a Class 2 message to the DIC. The DIC will display REPLACE LIFTGATE FUSE to inform the driver that a fault has been detected in the lift gate lock circuit and that the lift gate is not locked. Faults that will set the DTC and cause the DIC to display the message could be any of the following:
An open ECC fuse
An open or short to ground in the lift gate lock relay battery positive voltage circuit
A faulty lift gate lock relay
An open or short to ground in the lift gate lock relay control circuit
A short to ground in the lift gate lock actuator lock control circuit
A faulty BCM
May 14, 2016 | Cars & Trucks
I have two code error on my jeep grand Cherokee 2007 idle air-control p0507 x3 of them & p2767 input/turbine speed sensor B, could you help me get idea, of what it is?
code p 0507 refers to idle speed control (ISC) system rpm higher than expected==causes -wiring--ISC actuator/IAC valve --throttle motor -- throttle valve tight / sticking---ECM
it als o refers to idle air control(IAC) system--circuit low===causes --wiring short to ground --IAC valve ---ECM
code p 2767 refers to transmission input shaft speed sensor/turbine shaft speed (TSS) sensor B---no signal===causes --wiring---transmission input shaft speed sensor /TSS sensor
Mar 26, 2016 | Jeep Cars & Trucks
I recently replaced the catalytic converter to my 2000 bmw 300I and now It is giving the p2096.
Possible causes
- Oxygen sensor harness is open or shorted
- Oxygen sensor circuit poor electrical connection
- Exhaust system leak
- Faulty front or rear (pre-cat or downstream) oxygen sensor
what it means Harness is open or shorted It means that the wire(s) connected from and to the component (sensor, solenoids, actuator, etc.) is either open (cut, broken, disconnected) or shorted (touching other wires, components, body). "Open" and "short" are common electrical terms. An open is a break in a wire or at a connection. A short is an accidental connection of a wire to ground or to another wire. In simple electronics, this usually means something won't work at all. With complex electronics (such as ECMs or PCMs) this can sometimes mean something works, but not the way it's supposed to.
Circuit poor electrical connection It means that the component (sensor, solenoids, actuator, etc.) connector is not fully connected or is disconnected. Before replacing any components, try fully disconnecting the connector, reconnect and test the system or component again.
Faulty or Failed component It means that the component it's more than likely the cause of the code and that needs to be replaced
Engine mechanical problems When a code list as possible causes an engine mechanical problem, it means that the problem is not caused by electronic component, but rather by a mechanical component such as pistons, valves, mechanical pump
Mar 26, 2015 | BMW Cars & Trucks
2001 chrysler town and country. A\C heat Blowers will not work when controlled my front main pannel. It is a auto temp controlled system. The rear blower will work but no heat when controlled by the rear...
This may be similar to what I just fixed on an '00 dodge:
http://www.dodgeintrepid.net/showthread.php?t=89711
Accessing the Integrated Diagnostic System:
Procedure for Automatic Temp Control (ATC) equipped vehicles:
With the engine ON and the vehicle stopped set the temp to 75*F. Next hold down the Floor, Mix and Defrost buttons until the ATC display begins to flash. While the display is flashing, the system will run it's tests and calibrations.
When the display stops flashing, the tests and calibrations are complete.
The ATC display can only display one error code at a time. Any stored codes can be scrolled through by pressing the Panel mode button once for each code. DO NOT press any other button or you will have to start the test over. Note the codes and refer to the list below to determine what system is malfunctioning.
List of Climate Control DTCs:
23: Blend door actuator feedback failure (bad servo)
24: Mode door actuator feedback failure (bad servo)
25: Ambient temp sensor failure
26: ATC In Car thermister failure (ATC only, bad ATC head or ATC head disconnected while battery is connected)
27: ATC in car sensor failure (ATC only)
31: Recirculation door actuator stalled (stuck door or bad servo)
32: Blend door actuator stall failure (stuck door or bad servo)
33: Mode door actuator stall failure (stuck door or bad servo)
34: Engine temperature message not received (ATC only, bad ATC head or bus failure)
35: Evaporator sensor failure
36: ATC control communication failure (bad ATC head or bus failure)
37: Blend door actuator output shorted to battery (bad servo or wiring fault)
38: Blend door actuator output shorted to ground (bad servo or wiring fault)
39: Mode door actuator output shorted to battery (bad servo or wiring fault)
40: Mode door actuator output shorted to ground (bad servo or wiring fault)
41: Recirculation door actuator output shorted to battery (bad servo or wiring fault)
42: Recirculation door actuator output shorted to ground (bad servo or wiring fault)
43: Common door shorted to battery (probable wiring fault, could be a servo that failed in an odd manner)
44: Common door shorted to ground (probable wiring fault, could be a servo that failed in an odd manner)
45: A/C control blend door input open or shorted with respect to ground (MTC only, wiring fault or bad servo)
46: A/C control blend door shorted to battery (MTC only, wiring fault or bad servo)
47: A/C switch failure (MTC only)
48: A/C control mode door input shorted to ground (MTC only, wiring fault or bad servo)
49: A/C control mode door input shorted to battery (MTC only, wiring fault or bad servo)
50: A/C control electric backlite (EBL) switch fails (MTC only)
51: System voltage too low for calibration!!! (check battery cables, battery and alternator!)
Dec 10, 2014 | 2001 Chrysler Town & Country
TROUBLE CODE P 1613 IN WV PASSAT 99
P1102O2S Heating Circuit Bank 1 Sensor 1 Voltage Too Low/Air Leak
P1105O2S Heating Circuit Bank 1 Sensor 2 Short To Positive P1107O2S Heating Circuit Bank 2 Sensor 1 Short To Positive P1110O2S Heating Circuit Bank 2 Sensor 2 Short To Positive P1113O2S Sensor Heater Resistance Too High Bank 1 Sensor 1 P1115O2S Sensor Heater Circuit Short To Ground Bank 1 Sensor 1
P1116O2S Sensor Heater Circuit Open Bank 1 Sensor 1
P1117O2S Sensor Heater Circuit Short To Ground Bank 1 Sensor 2
P1118O2S Sensor Heater Circuit Open Bank 1 Sensor 2
P1127Long Term Fuel Trim B1 System Too Rich
P1128Long Term Fuel Trim B1 System Too Lean
P1129Long Term Fuel Trim B2 System Too Rich
P1130Long Term Fuel Trim B2 System Too Lean
P1136Long Term Fuel Trim Add. Fuel B1 System Too Lean
P1137Long Term Fuel Trim Add. Fuel B1 System Too Rich
P1138Long Term Fuel Trim Add. Fuel B2 System Too Lean
P1139Long Term Fuel Trim Add. Fuel B2 System Too Rich
P1141Load Calculation Cross Check Range/Performance
P1144Mass Air Flow Sensor Open/Short To Ground.
P1145Mass Air Flow Sensor Short To Positive.
P1146Mass Air Flow Sensor Supply Voltage.
P1155Manifold Absolute Pressure Sensor Short To Positive.
P1156Manifold Absolute Pressure Sensor Open/Short To Ground. P1157Manifold Absolute Pressure Sensor Supply Voltage.
P1160Intake Air Temperature Sensor Short To Ground.
P1161Intake Air Temperature Sensor Open/Short To Positive. P1162Intake Air Temperature Sensor Short To Ground.
P1163Fuel Temperature Sensor Open/Short To Positive.
P1164Fuel Temperature Sensor Implausible Signal.
P1171Throttle Actuation Potentiometer Sign. 2 Range/Performance P1172Throttle Actuation Potentiometer Sign. 2 Signal Too Low P1173Throttle Actuation Potentiometer Sign. 2 Signal Too High P1176Rear O2S Correction
P1177O2 Correction Behind Catalyst B1 Limit Attained
P1196O2S Heater Circuit Bank 1 Sensor 1 Electrical Malfunction P1197O2S Heater Circuit Bank 2 Sensor 1 Electrical Malfunction P1198O2S Heater Circuit Bank 1 Sensor 2 Electrical Malfunction P1199O2S Heater Circuit Bank 2 Sensor 2 Electrical Malfunction P1213Injector Circuit Cylinder 1 Short To Positive
P1214Injector Circuit Cylinder 2 Short To Positive
P1215Injector Circuit Cylinder 3 Short To Positive
P1216Injector Circuit Cylinder 4 Short To Positive
P1217Injector Circuit Cylinder 5 Short To Positive
P1218Injector Circuit Cylinder 6 Short To Positive
P1225Injector Circuit Cylinder 1 Short To Ground
P1226Injector Circuit Cylinder 2 Short To Ground
P1227Injector Circuit Cylinder 3 Short To Ground
P1228Injector Circuit Cylinder 4 Short To Ground
P1229Injector Circuit Cylinder 5 Short To Ground
P1230Injector Circuit Cylinder 6 Short To Ground
P1237Injector Circuit Open Cylinder 1
P1238Injector Circuit Open Cylinder 2
P1239Injector Circuit Open Cylinder 3
P1240Injector Circuit Open Cylinder 4
P1241Injector Circuit Open Cylinder 5
P1242Injector Circuit Open Cylinder 6
P1245Needle Lift Sensor Short To Ground
P1246Needle Lift Implausible Signal
P1247Needle Lift Sensor Open/Short To Positive
P1248Start Of Cold Start Injector Control Difference
P1251Start Of Cold Start Injector Short To Positive
P1252Start Of Cold Start Injector Open/Short To Ground
P1255Engine Coolant Temperature Sensor Short To Ground
P1256Engine Coolant Temperature Sensor Open/Short To Positive P1300Misfire Detected, Fuel Level Too Low
P1250Fuel Level Too Low P1325Cyl. 1 Knock Control Limit Attained
P1326Cyl. 2 Knock Control Limit Attained
P1327Cyl. 3 Knock Control Limit Attained
P1328Cyl. 4 Knock Control Limit Attained
P1329Cyl. 5 Knock Control Limit Attained
P1330Cyl. 6 Knock Control Limit Attained
P1336Engine Torque Adaption At Limit
P1337CMP Sensor Bank 1 Short To Ground
P1338CMP Sensor Bank 1 Open Circuit Or Short To Positive P1340CKP/CMP Sensor Signals Out Of Sequence
P1341Ignition Coil Output Stage 1 Short To Ground
P1343Ignition Coil Output Stage 2 Short To Ground
P1345Ignition Coil Output Stage 3 Short To Ground
P1354Modulating Piston Displacement Sensor Electrical Circuit Malfunction
P1386Internal Control Module Knock Control Error
P1387Control Unit Internal Altitude Sensor
P1391CMP Sensor Bank 2 Short To Ground
P1392CMP Sensor Bank 2 Open Circuit/Short To Positive
P1393Ignition Coil Power Output Stage 1 Malfunction
P1394Ignition Coil Power Output Stage 2 Malfunction
P1395Ignition Coil Power Output Stage 3 Malfunction
P1401EGR Valve Power Stage Short To Ground
P1402EGR Vacuum Regulator Solenoid Valve Short To Positive P1403EGR System Control Difference
P1407EGR Temperature Sensor Signal Too Low
P1408EGR Temperature Sensor Signal Too High
P1410Tank Ventilation Valve Circuit Short To B+ P1420Secondary Air Injection Control Module Electrical Malfunction P1421Secondary Air Injection Valve Circuit Short To Ground P1422Secondary Air Injection Valve Circuit Short To B+ P1424Secondary Air Injection System Bank 1 Leak Detected P1425Tank Ventilation Valve Short To Ground P1426Tank Ventilation Valve Open Circuit P1432Secondary Air Injection Valve Open P1433Secondary Air Injection Pump Relay Circuit Open P1434Secondary Air Injection Pump Relay Circuit Short To Positive P1435Secondary Air Injection Pump Relay Circuit Short To Ground P1436Secondary Air Injection Pump Relay Circuit Electrical Malfunction P1440EGR Valve Power Stage Open P1441EGR Vacuum Regulator Solenoid Valve Open/Short To Ground P1450Secondary Air Injection System Circuit Short To Positive P1451Secondary Air Injection Circuit Short To Ground P1452Secondary Air Injection System Circuit Open P1471EVAP Control System LDP Circuit Short to Positive P1472EVAP Control System LDP Circuit Short To Ground P1473EVAP Control System LDP Open Circuit P1475EVAP Control System LDP Malfunction/Signal Circuit Open P1476EVAP Control System LDP Malfunction/Insufficient Vacuum P1477EVAP Control System LDP Malfunction P1478EVAP Control System LDP Clamped Tube Detected P1500Fuel Pump Relay Electrical Circuit Malfunction P1501Fuel Pump Relay Circuit Short To Ground P1502Fuel Pump Relay Circuit Short To Positive P1505Closed Throttle Position Does Not Close/Open Circuit P1506Closed Throttle Position Switch Does Not Open./Short To Ground P1512Intake Manifold Changeover Valve Circuit Short To Positive P1515Intake Manifold Changeover Valve Circuit Short To Ground P1516Intake Manifold Changeover Valve Circuit Open P1519Intake Camshaft Control Bank 1 Malfunction P1522Intake Camshaft Control Bank 2 Malfunction P1537Fuel Cut-off Valve Incorrect Function P1538Fuel Cut-off Valve Open/Short To Ground P1539Clutch Pedal Switch Signal Fault P1540VSS Signal Too High P1541Fuel Pump Relay Circuit Open P1542Throttle Actuation Potentiometer Range/Performance P1543Throttle Actuation Potentiometer Signal Too Low P1544Throttle Actuation Potentiometer Signal Too High
P1545Throttle Position Control Malfunction P1546Wastegate Bypass Regulator Valve Short To Positive P1547Wastegate Bypass Regulator Valve Short To Ground P1548Wastegate Bypass Regulator Valve Open P1549Wastegate Bypass Regulator Valve Open/Short To Ground P1550Charge Pressure Control Difference P1555Charge Pressure Upper Limit Exceeded P1556Charge Pressure Negative Deviation P1557Charge Pressure Positive Deviation P1558Throttle Actuator Electrical Malfunction P1559Idle Speed Control Throttle Position Adaption Malfunction P1560Maximum Engine Speed Exceeded P1561Quantity Adjuster Control Difference P1562Quantity Adjuster Upper Stop Value P1563Quantity Adjuster Lower Stop Value P1564Idle Speed Control Throttle Position Low Voltage During Adaption P1565Idle Speed Control Throttle Position Lower Limit Not Obtained P1568Idle Speed Control Throttle Position Mechanical Malfunction P1569Switch For CCS Signal Faulty P1580Throttle Actuator B1 Malfunction P1582Idle Adaptation At Limit P1600Power Supply Terminal No. 15 Low Voltage P1602Power Supply Terminal No. 30 Low Voltage P1603Internal Control Module Self Check P1606Rough Road Spec. Engine Torque ABS-ECU Electrical Malfunction P1611MIL Call-Up Circuit/TCM Short To Ground P1612Engine Control Module Incorrect Coding
P1613MIL Call-Up Circuit Open/Short To Positive P1616Glow Plug Indicator Lamp Short To Positive P1617Glow Plug Indicator Lamp Open/Short To Ground P1618Glow Plug Relay Short To Positive P1619Glow Plug Relay Open/Short To Ground P1624MIL Request Signal Active P1626Data Bus Drive Missing Command From M/T P1630Accelerator Pedal Position Sensor 1 Signal Too Low P1631Accelerator Pedal Position Sensor 1 Signal Too High P1632Accelerator Pedal Position Sensor 1/2 Supply Voltage P1633Accelerator Pedal Position Sensor 2 Signal Too Low P1634Accelerator Pedal Position Sensor 2 Signal Too High P1639Accelerator Pedal Position Sensor 1/2 Range Performance P1640Internal Control Module (EEPROM) Error P1648CAN-Bus System Component Failure P1649Data Bus Powertrain Missing Message From Brake Controller P1676Drive By Wire MIL Circuit Electrical Malfunction P1677Drive By Wire MIL Circuit Short To Positive P1678Drive By Wire MIL Circuit Short To Ground P1679Drive By Wire MIL Circuit Open Circuit P1681Control Module Programming Not Finished P1686Control Unit Error, Programming Error P1690MIL Malfunction P1691MIL Open Circuit P1692MIL Short To Ground P1693MIL Short To Positive P1778Solenoid EV7 Electrical Malfunction P1780Engine Intervention Readable P1851Data Bus Drive Missing Command From ABS P1854Drive Train CAN-Bus Inoperative
Read more at: https://www.obd-codes.com/trouble_codes/volkswagen/
Copyright OBD-Codes.com
Apr 03, 2012 | Volkswagen Passat Cars & Trucks
2009 Ford Fusion codes 2107,2110 car slows to 30mph and will no longer accelerate
Well, those codes definately are related to why your vehicle will no longer accelerate!
P2107 is "Throttle Actuator Control (TAC) Module Processor"
This code means that the TAC portion of the Powertrain Control Module (PCM) has failed the self-test.
Posiible causes:
> TAC motor circuit harness shorted to ground
> TAC motor circuit harness shorted to voltage
> Damage Electronic Throttle Body (ETB)
> Damaged PCM
P2110 is "Throttle Actuator Control (TAC) Forced Limited RPM"
This code is informational only. It sets in conjunction with other throttle actuator control codes (like P2107 above). It is just letting you know that the PCM is limiting RPM due to a TAC malfunction, (So it doesn't do a "TOYOTA" on you and run away!"
Jul 06, 2011 | Ford Fusion Cars & Trucks
2 error codes on 2008 nissan sentra p2101 and p2118 what do these codes mean? only has 24,000 miles on the car
code P2101 (which is a Throttle Actuator Control Motor)
Trouble Code: P2118
Electronic Throttle Control Motor Circuit Malfunction
Trouble Code Conditions:Ignition is on and ETC motor is not in limp-home mode. When the PCM detects an internal error or short between the ETC motor and ETC motor positive circuits in the ETC motor driver. The ETC light will be flashing.
Possible Causes:
  • Throttle plate or bore malfunctions
  • ETC positive circuit is open or is shorted to ground, battery voltage or ETC negative circuit
  • ETC negative circuit is open or is shorted to ground or to battery voltage
  • ETC motor has malfunctioned
  • PCM has failed
Oct 23, 2010 | Nissan Sentra Cars & Trucks
A p0301 p1142 p1545
CODE PO301 - CYLINDER NUMBER 1 MISFIRE DETECTED. POSSIBLE CAUSE- BAD COIL - SPARK PLUG - INTAKE MANIFOLD VACUUM LEAK - DIRTY OR FAULTY FUEL INJECTOR. CODE P1142 - DID NOT SEE. CODE P1545 - THROTTLE VALVE ACTUATOR MALFUNCTION.POSSIBLE CAUSE THROTTLE VALVE CONTROL MODULE FAULTY - THROTTLE VALVE IS DAMAGE OR DIRTY - THROTTLE VALVE MUST BE IN THE CLOSE POSITION - ACCELERATOR PEDAL OUT OF ADJUSTMENT. THROTTLE POSITION ACTUATOR IS SHORTING TO GROUND OR POWER.
May 09, 2010 | 2000 Volkswagen Jetta TDI
RTO Construction Bobcat by Woody Click Logo
902 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
