Question about Lexmark T630 Laser Printer
Printer problem dear sir , I have a lexmark T630 printer. But today it comming 917 service transfer roaler error.what the error massage?
  • 4 Answers
Hello, it is likely that the transfer roller requires replacing. You may be able to purchase the roller from a local office supply, otherwise buy on line. However, there is more to it...
The error means, the Transfer Roll Cannot start servo operation. Verify correct cable connections from the Engine board to the HVPS (high voltage power supply). Make sure there is continuity between the transfer roller and its contact on the HVPS; replace the transfer roll if the continuity is correct.
If there is no continuity, make sure the HVPS contact returns to its upward limit when depressed, and make sure the left bearing of the transfer roll is making proper contact.
If the wires are all connected correctly, and there is continuity through the roller contacts, replace the roller.
Posted on Feb 23, 2008
    Problem Solver:
  • 13 Answers
Your transfer roller needs replacing.
How I fix the error 917 service transfer roll
Try replacing/reseating transfer roll.
  1. The right and left transfer arm assemblies
  2. The high voltage power supply (HVPS)
  3. The main engine/system board
Feb 18, 2015 | Lexmark E350d Laser Printer
241 paper jam message
Lexmark T630 241 paper jam message - Indicates a paper jam from the pull down manual feed tray.
If you check to make sure and small fragments of paper are not hindering the operation of the switch. The switch is located on the left side of the tray and will be spring loaded. The switch should move freely without binding. Make sure no toner or dust is on the optical sensor assembly. See Diagram for location.
If the switch seems OK and the printer still reports an error, the printer will require professional care.
Jan 15, 2011 | Lexmark T630 Laser Printer
Error code 917.00
Step Action 1 Turn off the printer and let the printer sit, powered off, for one minute. 2 Power the printer back on. 3 If the 917 error does not return on power-up, try printing a few pages. If the error does not return during printing, this may have been an isolated incident. Continue using the printer as before, but pay close attention to it for the next few days to see if the error returns. 4
If the error returns on power-up, as soon as you try to print, or re-appears at a later time, inspect the transfer roller. (Click the links in the steps below for images.)
  1. Turn the printer off.
  2. Open both the lower front cover and the upper front cover of the printer.
  3. Remove the toner cartridge and place it aside.
  4. Look at the transfer roller. Make sure nothing is stuck on the roller or wrapped around it. If you find any obstruction, try your best to remove it without damaging the transfer roller or knocking the roller loose.
  5. Make sure the transfer roller is not loose or damaged. If the roller is damaged, the roller will need to be replaced. Please contact Lexmark Technical Support or a local authorized service provider for further assistance.
  6. Spin the transfer roller. Make sure it spins freely.
  7. If the transfer roller appears to be fine, reinstall the toner cartridge and power the printer back on.
  8. Try printing again to see if the error message returns.
If the 917 error still will not clear, or if the error continues to occur intermittently, the printer will likely require service. Please contact Lexmark Technical Support or a local authorized service provider for further assistance. See Contacting Lexmark below for more information.
Jan 11, 2011 | Lexmark T642 Laser Printer
Have error code 917.0 on Lexmark 640 laser printer.
From the service manual:
917 .00 Problem with transfer - transfer servo start error.
• Check HVPS
• Check system board
• Check HVPS/input sensor/toner sensor cable.
Often the problem is caused by the transfer roller (foam roller underneath the toner) not seated correctly (the gear should be at the right side of the printer).
Less often the charge roller is missing (the roller that comes down when you close the front door).
Dec 28, 2010 | Lexmark Office Equipment & Supplies
I received an message 917.00 service transfer roll. How do I fix this ?
Here's an article on A 917 or 917.00 Service Error Is Appearing on a Lexmark T640, T642, T644, or an X64xe Series Printer. Just click on this link: http://bit.ly/aQD8jS. Follow the recommended actions. If error won't clear, printer may require service. Don't hesitate to contact Lexmark technical support for assistance. Thanks.
Aug 06, 2010 | Lexmark T640 Laser Printer
Lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
May 07, 2009 | Lexmark T642 Laser Printer
I am getting a message on the printer that says, "932 Service Printhead Error". The printer is a Lexmark T630. Help
The message indicates that the laser scanning head is defective. Lexmark calls it a printhead. Unless you want to spend a lot of money, it may not be worth fixing. A new part runs over a hundred dollars.
Dec 01, 2008 | Lexmark T630 Laser Printer
Lexmark error codes
Too many to list here. Try justmanuals.com, you can get the service manual for about $10.
Jan 14, 2008 | Lexmark T642 Laser Printer
Printer Lexmark T630
The error message is normally caused by either plugging accessories into the rip controller board or the engine board. In some models the board may be conbined. Or invalid or illegal commands sent from the printer. Try upgrading the firmware first. If that does not work you you may have a bad board. Hope this helps Click on the link below and select your operating system http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:359:0:0
Sep 10, 2007 | Epson Stylus Photo 1280 InkJet Printer
Lexmark T630 Laser Printer Logo
817 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
