Question about GE JVM1440 Microwave Oven
Replacement bulb for the underside of the microwave.
The bulb located on the underside of the microwave has no identification number - what is the bulb type/number for a replacement?
  • 863 Answers
Here you go bud. Just copy the web address below and paste in the address box above:
http://www.partstore.com/ModelSearch.aspx?utm_source=GE-v01-G-01&utm_medium=website&utm_campaign=Brand_landing_pages&s=google&MfgName=General+Electric&BrandName=General+Electric&ModelNumber=JVM1440
Posted on Feb 08, 2010
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Screwdriver
Light
Unplug the Magic Chef microwave from the wall outlet.
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Oct 08, 2016 | Magic Chef Microwave Ovens
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
I have to replace microwave light bulb. It's GE counter top Microwave JES1142PSE model. I hace opened the microwave and have located the bulb,but could not unscrew.I don't know needs to be pul
That exact model number is not showing up, so you may want to check the tag on or in the unit and look here for parts.
Most of the models in this class of ovens were not really made to be serviced, so GE only makes the turntable parts available.
It also sounds like your bulb is an assembly - the socket and bulb and one piece.
So your local appliance parts store should have a generic replacement for it. You should take the bulb.
Be careful when disconnecting the leads.
Apr 14, 2013 | GE Microwave Ovens
Model # JVM1870W07-what is the easiest way to change these-was able to get the bulbs out-but can't the new ones in-hard to see the holes from the back
HELLO.The easiest and only solution is given below.
things you need
  • Phillips screwdriver
  • 40-watt replacement bulb
    1 Unplug the microwave and open the door.
2 Remove the screws from the front grill and pull it off of the oven. The screws are located on the underside of the grill.
3 Pull the light bulb housing toward you through the access panel.
4 Unscrew the old light bulb and replace it with the new 40-watt light bulb.
5 Rotate the light bulb housing toward the back of the oven. Reattach the grill with the screws and plug the microwave back into the electrical outlet.
Thanks.
Sep 16, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Sharp 930 Convection Microwave that is no longer rotating. Any help?
This problerm is commonly attributed to a turntable motor that is no longer working. If the model number you posted this question under is correct, the part number for a replacement turntable motor is 46-841666-3. You may also consider replacing the turntable coupler (also called the turntable shaft). The part number is NCPL-A021WRFO. If your existing coupler is still in good shape, there is no need to replace it.
Replacement parts can be purchased on line at searspartsdirect.com. There is a complete list of helpful exploded view parts illustrations to assist you with parts identification/location.
If you need instructions on how to replace a turntable motor, the following link explains:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
If you have any questions, please post back and let me know. I hope this helps you.
Jan 29, 2010 | Sharp R-930AK Convection/Microwave Oven
Sharp carousel model number R-930ak + parts The plate inside does not spin sounds like a cheap plastic gear on the bottom is worn out and stripped. MAkes a clicking sound
This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
For the model number you have listed, the part number is 46-841666-3.
You can purchase replacement parts at searspartsdirect.com.
The site also offers helpful exploded view diagrams to assist you in parts location/identification. The motor is listed at item 001-20 under the "Cabinet" heading. If you have any questions, please post back and let me know. I hope this helps you.
NOTE: You also consider the turn table coupling, which is item 004-22. The underside of the coupling has a keyed slot that fits on to the turn table motor shaft. If the coupling becomes cracked, or if the keyed slot "rounds out", it may be slipping on the motor shaft and not turning.
Dec 17, 2009 | Sharp R-930AK Convection/Microwave Oven
Hi, I have a GE JVM1440 & the plate won't spin
This is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
If the model number is correct, the part number is WB26X10038. You may also consider replacing the turn table shaft (coupler), part number WB06X10138. You can purchase replacement parts at the following websites: searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back and let me know. I hope this helps you.
Dec 09, 2009 | GE JVM1440 Microwave Oven
Bulb cover (glass)...
Your part number is WB06X10372 for your light cover
Oct 31, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440 Microwave Oven Logo
206 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
