Question about Whirlpool Washing Machines
We have a whirlpool Roper washer model #RAS8445KQ0. When the washer reaches "high spin" cycle, it stops running and will not drain. My husband checked the hose and it is not clogged or twisted. Could this be a mechanical problem?
4 Suggested Answers
  • 30 Answers
SOURCE: roper model ras8445kq0
If the agitator does not spin at all, then it is your motor coupling. If the agitator tries to spin but cannot, then it is your dog agitators.
Posted on Mar 14, 2008
jumptrout51
  • 3361 Answers
SOURCE: how do i get to the dog agitators in the roper
Pop the top cap of the agitator off. Reach inside with a pair of pliers to pull out the plastic cover. Take a 7/16 socket wrench with extension and remove the bolt. Pull up on the agitator to separate it from the bottom portion.
Posted on Jun 14, 2009
SOURCE: how many cubic feet does
3.2
Posted on Feb 22, 2011
WASHER WONT DRAIN
Does the washer spin on rinse and drain cycles ok? If it does spin but won't drain, the problem is the plasic impeller in your drain pump. This model is a direct drive unit with a reversing motor that runs one direction for agitate, but reverses to spin the tub and operate the drain pump. So if it spins but DOES NOT drain, it's the drain pump, but if it doesn't spin or drain, than it's probably a lid switch. Also the tub to pump hose or pump discharge hoses may be clogged with something. If your mechanically apt, you can do this repair yourself and save a service charge. The pump runs about 30 dollars or so and is really easy to change out. Check out Youtube videos on Whirlpool washer repairs, they will show you everything to do. Yes, I said Whirlpool, because Roper is built by Whirlpool.
Hope this helps
kcomp1863
Dec 29, 2010 | Roper RAS6233KQ Top Load Washer
I have a Roper washer. It filled with water to wash, but when it came to draining the water to rinse, it just stops. It will add water on rinse cycle, but it will not drain or spin.
Sounds like the lidswitch. As a safety, the tub will not spin if the door is up (open). In turn, it will not drain if it wont spin. This is a common problem with whirlpool washers. You can go to searspartsdirect.com to get the breakdown and order the part.
Feb 17, 2010 | Roper RTW4300SQ Top Load Washer
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Roper model ras8445kq0
Mar 14, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
