Question about Gateway Computers & Internet
My batery light is lit up in red and when i have it pugged in it sais plugged in but not charging?
  • 44 Answers
Take your battery out, plug the adapter in and turn the computer on. If it will not turn on then you have a DC jack problem and you will have to replace it. If it does turn on wiggle the adapter near the DC jack. If it does not turn off you may need a new battery. If new battery does the same thing then the connector on the motherboard may be messed up or you may have a component on the motherboard that is not functioning properly.
Posted on Feb 08, 2010
  • sarah brooks Feb 08, 2010
    Sorry may also be bad battery
Blackberry problems
Try to charge it with another adapter
if it will not help probably your batery is dead
Aug 02, 2014 | RIM BlackBerry Computers & Internet
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
Apr 18, 2011 | Health & Beauty
Red light turns on and off while charging e-reader 600
Okay Plug It In And Let The Red Light Turn Off By Itself Then Get A Tooth Pick Or Any Item That Will Go In The Reset Hole Then Pug it In Again. The Red Light Will Still Be On But After Five Minutes Unplug It Turn It On The Light Will Be Yellow Then Turn On .
Jun 07, 2010 | Sony E-reader Portable E-book MP3 Player
Acer aspire one battery light flashes orange. When booting after a few seconds it shutsdown. Now all lights stay off. Can this acer netbook work without batery ? It doesn't seem to charge the batery
Finally I got it working again, after a lot of try's (just put the plug in for a few hours) the led was red again for a brief moment, then it starting to flash orange again.
I looked it up on a lot of forums, the problem is that the (old) bios doesn't charge the batery anymore when it is deeply discharged.
So I put the plug in and out for about 10-15 times , and the brief moment it is not flashing it's still charging. Until it is not deeply discharged anymore and then it is charging the batery like it did before.
But I still don't understand why it is not working without the batery inserted ??
Nov 14, 2009 | Acer Aspire One PC Notebook
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
W910i red lights
I just got the same problem, it's just because the battery is so dead it needs time to re-charge. Just leave the phone plugged in for a while, it will eventually show up as charging :)
May 04, 2009 | T-Mobile Dash Smartphone
Fuse blow as soon as it plug it in
sounds like your inverter has died :)
Jan 21, 2009 | Car Audio & Video
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Computers & Internet Logo
61 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
