Question about Uniden BC350C Base Scanner
How do i get the channels to my pro-137 scanner
    President:
  • 2,761 Answers
If you're looking for frequencies to program into the scanner your best bet is to visit
www.RadioReference.com
The site has a comprehensive database of active frequencies, by location, and a lot of other useful scanning info.
BillB
Posted on Feb 08, 2010
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Can the GRECOM PSR255. be used to scan for aircraft /airband frequencies
Your radio is not capable of recieving air band frequencies. It will only receive 4 bands consisting of: 26 - 54 MHz; 68 - 88 MHz; 137 - 174 MHz and 380 - 512 Mhz.
The VHF airband uses the frequencies between 108 (just above commercial FM radio) and 137 MHZ (just below 2 meter Ham radio). Amplitude Modulation ("AM") is the mode that transmissions are made. The lowest 10 MHz of the band, from 108-117.95 MHz, is split into 200 narrow-band channels of 50 kHz. These are reserved for navigational aids such as VOR beacons, and precision approach systems such as ILS localizers
Jan 26, 2013 | Grecom Gre Psr-255 50 Channel Handheld...
How do I reset defaults on pro 137
To reset your scanner to its original factory defaults:
- Power the scanner OFF
- Press and hold the 2, 9, and SCAN keys and power the scanner ON
- The message Initialing ... Please wait will display during the RESET. Do not power the scanner OFF while this message is showing.
Need the manual for your scanner? You can download and print it here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-137%20OwnersManual.pdf
Bill B
Aug 13, 2010 | Radio Shack Pro-97 Handheld Scanner
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
Problem with PRO-2066 scanner not receiving local 800mhz Motorola trunk system II. It does trunk with the current data channels used (showing the ---- line) but I only hear transmissions on freqs ending...
It is difficult to explain in simple terms but I will try.
Google rebanding.
Some radios can have their firmware updated but I don't think your PRO 2066 can.
Channel numbers and frequencies preprogrammed into your scanner have changed over the past few years.
When a data signal says go to channel X that channel is now Y, but your scanner is still looking for X
Hope this helps
Aug 21, 2017 | Radio Shack Pro-97 Handheld Scanner
Programming a pro 137 scanner
1. Press SCAN/MAN to enter manual mode.
2. Press EPGM to put the scanner in
programming mode. PGM appears.
3. Use the number keys to enter the channel
number you want to assign to a frequency.
4. Press SCAN.
5. Use the number keys and •CLR to enter the
frequency, including the decimal point you
want to store.
6. Press EPGM to store the frequency.
7. Press EPGM again. The Edit Channel menu
appears.
8. Rotate the knob to select 1: Edit Car#, then
press EPGM.
9. Use the number keys to enter the car number
in 3-digits, then press EPGM.
10. Rotate the knob to select 2: Edit Tag, then press
EPGM.
11. Use the number keys to enter the tag then
press EPGM.
12. To program the next channel in sequence,
press Menu then repeat the steps from 3.
For more details, you can download and print the complete operating manual by following this link:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000137_PM_EN.pdf
To be certain that you have all the active frequencies in your area, visit:
Dec 28, 2009 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-137 Unlock All Channels
THAT ONLY UNLOCKS THE FREQ. THAT YOU HAVE BLOCKED
Jul 11, 2009 | Uniden BC350C Base Scanner
How do i unlock my pro 137 scanner
Unlock the scanner for what? 800 MHz cellular frequencies? This scanner will not "unlock" for those frequencies.
Mar 02, 2009 | Uniden BC350C Base Scanner
Uniden BC350C Base Scanner Logo
79 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
