Question about Proform 7.25Q Treadmill Walking Belt
I have a Proform 725ex treadmill. I can't remember where the small allen wrench that came with it is. I thought it was somewhere on the treadmill in a compartment or storage place. I have used it before to adjust the belt , but now need it for replacing belt.
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
  • 3 Answers
SOURCE: HOW DO YOU ADJUST THE BELT ON A PROFORM 725 SPACE
Use the allen wrench to loosen side that is touching. 1st locate on the end of the treadmill 2 slots, 1 on each side and place the allen wrench into the slot. turn anticlock wise 1/4 turn. Turn on treadmill at 3 to 4 miles per hour (not standing on it) and make ajustments in 1/4 turns until belt gets centered and snug. When you have it centered you may ahve to tighten or loosen it in case it is slipping when you are running on it. When you ajust it when centered you should do this in 1/4 turns on both sides to keep it centered. If this doesnt fix the problem I suggest that you may have some other problem or are not capable of reolving this problem on your own. Ask another friend for there opinion if this fails.
Posted on Feb 20, 2010
  • 82 Answers
SOURCE: Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
Posted on Apr 22, 2010
maxtreadmill
  • 832 Answers
SOURCE: Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jul 16, 2010
Belt on treadmill is moving towards the right and bunching up
you need to adjust the travel of belt. to do this you need a allen wrench that came with it. if you have it run treadmill at slow speed,go to the rear right at the right end cap there is a hole, use the allen wrench and unscrew slowly while watching the belt until returns to the middle. if it slips when walking go back to rear and adjust by screwing in one turn on each side until belt wont slip.
Feb 09, 2011 | Proform 380 Treadmill Walking Belt
Belt slips when walking on it.
there's a wrench that came with it, an allen wrench, turn on betl at medium slow speed, go to rear of treadmill and using the wrench give at each end caps(there is a hole to put the wrench) a half a turn on each side several time and walk in it until belt remains stable.
Feb 08, 2011 | Proform 530 Treadmill Walking Belt
My proform 590 treadmill has these problems ; belt slips when running or walking ,speed goes up and down does not stay constant and you can hear motor noise increasing and decreasing in motor what should...
simple(maybe). go to the rear of treadmill,get the allen wrench that came with it,run at med-slow speed and adjust the rear roller with allen wrench. 1 turn per side 2 or 3 time then walk on belt until wont slip. all the problem is belt tension. also. make sure if it need lubrication under board and belt(some are lubless others dont).
good luck to you.
Feb 08, 2011 | Treadmill Doctor Proform 590Qs Treadmill...
Belt is slipping.... does this mean I need a new belt?
Typically you can tighten the belt with an allen wrench at the rear of the belt, treadmill be sure to align belt before tightening. Alternate each side as you tighten
Nov 25, 2010 | Proform XP 580 Trainer Treadmill
HOW DO YOU ADJUST THE BELT ON A PROFORM 725 SPACE SAVER PERSONAL TRAINER TREADMILL. IT MOVES FROM SIDE TO SIDE AND IS FRAYING AT THE EDGE. DO YOU ACCESS THE ADJUSTMENT IN THE FRONT OR THE BACK OF THE...
Feb 19, 2010 | Proform 730 Folding Treadmill Model...
I have a proform treadmill that slips as soon as i step on track i looked at the belt it looks good how do i tighten up the track
There should be adjustment screws on the back left and right sides. The screws will be horizontal with the tread, and probably need an allen wrench to tighten. If the tread runs straight, tighten each side 1/4 turn at a time to keep them even. Check the tread after each adjustment, and stop as soon as the tread quits slipping.
Sep 08, 2009 | Proform Crosswalk 500 Treadmill
Looking for instructions to remove belt from J8 pro-form treadmil
I have a proform j8li treadmill. What size allen wrench to I need to adjust the belts?
Danielg@jcnj.org
Thanks
May 03, 2009 | Exercise & Fitness
Proform treadmill belt won't stay centered. travels to left and rubs against side
Adjust the tension on the right side rear using an allen wrench. Try 1/4 turn clockwise( should tighten). then run tread mill for 30 sec. to see if it centers itself. repeat again if not. if its to tight then turn the left side in a 1/4 turn
Apr 28, 2009 | Proform Exercise & Fitness
Proform 7.25Q Treadmill Walking Belt Logo
162 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
