Thick Black Line in Middle of Printed Document!
Printer= Canons PC-3000 Series/Fax-L400
Problem= When ever i print a document or scan a document i am getting a A THICK BLACK LINE in the middle of the page.
what do i do?!
    Sergeant:
  • 226 Answers
Your question might best be answered at the website below
http://www.canon.co.uk/Support/index.asp
They have technical support plus drivers and other odds and ends concerning your equipment
Posted on Feb 23, 2008
  • Ravel Lively
    Ravel Lively Feb 23, 2008
    But I would bet it has something to do with your toner drum
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
WHEN I MAKE COPY OR PRINT THE PRINTED PAGE IS NOT CLEAR, IT HAS SOME VERTICAL LINE ON LEFT SIDE AND SOME DOTTS ON RIGHTY SIDE, WHAT SHOULD I DO SOLVE THESE PROBLEM?
For copy jobs, clean the glass with a soft clean cloth, regularly, not just the 8.5 x 11 screen but the 11-inch x .5 inch strip that copies when using the document feeder. Print job: their is probably dirt or ink on the rolling parts. Q-tips are good for cleaning this up, careful, don't burn your fingers.
Mar 27, 2012 | Canon FAX-L400 All-In-One Laser Printer
I am getting a thick black line in the middle of my printed document when I use my mfc 8220
I am going on the presumption that you are getting this thick black line when printing from your computer. It can be a couple of things but firstly remove the toner/drum unit from the printer.
Check that the blue tag at the end of the top end of the drum unit ( used for cleaning the corona wire or drum unit & slides from 1 side to the other. ), is in the correct left correct position. If it is in the middle then that is what is causing this mark. It should be on the side of the drum unit where the arrows match.
If the blue slider is not in the middle then have a look at the drum & see if there is a black mark around it. If there is then you will need to replace the drum unit.
If you are only getting this mark when photocopying or faxing then there is a mark on the small piece of glass at the left hand side under thye document feeder.
Jul 17, 2011 | Brother MFC-8220 Fax
When I copy or fax with my 4215 it leaves a thick black stripe down the middle of the page, but not when I print off the computer.
There should be somewhere for you to open the printer to see the area that reads the document (might be a small strip of glass), there could be something stuck on this area (tiny spec the width of your line), thus causing the lines on the scan and not the prints. I am not too familiar with that model, so that is the best I have for you. Hope it helps.
Aug 24, 2010 | HP OfficeJet 4215 All-In-One InkJet...
I don't know how to fax
The control panel LCD also provides menus to operate the copy and fax modes independently of a PC. One nice touch: the LCD displays small and large type on the same screen, allowing more information about a print job to show at one time. b.gif 21262659-2-200-dt2.gif
The flash card reader under the control panel means you don't need a PC to print photos.
The MP730, while easy to operate, lacks some of the advanced features you might find on separate printers or faxes. For example, the MP730 can't collate copy jobs. To make more than one collated copy of a multipage document, you have to place the document in the ADF several times. Nor can the MP730 sync fax numbers entered by hand or accessed from within the Windows Address Book (Canon doesn't provide its own fax/address-book software), so you may end up duplicating efforts. Nor does Canon's software create group dials from your address book on your PC or provide a cover sheet. Finally, the MP730 can't forward faxes to another number or hold a fax to send when nighttime low rates kick in, which other multifunctions do.
Still, the MP730 provides plenty of features we do like. Using the menus with the Photo Print mode, you can print a photo contact sheet, pick individual images to print, and set up the printer to copy or print onto high-quality glossy paper. In the Copy mode, menus let you print two reduced originals side by side or print the same image on the same page several times (useful for business cards, name tags, and so on). The fax engine distinguishes voice from fax, sending voice calls to your phone or an answering machine and sending fax calls to the printer or to buffer memory so that you don't have to get a second phone line installed for your fax.
Installing the MP730 software is slow but idiot-proof: You just pop in the CD and follow instructions, which require restarting your PC several times. Canon bundles the MP730 with ScanSoft's OmniPage SE, a lite version of the best optical-character recognition software on the market, and NewSoft's Presto PageManager 6.0, one of the best document-management databases available.
The MultiPass MP730 won't replace top-of-the-line printers and scanners, but its print and scan speeds keep up with other multifunctions' as well as that of most as midrange ink-jet printers and scanners on the market today. In our tests, it printed ordinary text at 6.4 pages per minute and printed CNET's high-resolution test photo in 3.7 minutes. For comparison, the Lexmark X5150 (only $149 but without fax capability or automatic document feeder) prints text at a more common 5.2 pages per minute, and printed our test photo in about 2 minutes. Canon's MP730 scans a page of black in 9.4 seconds and a page of color in 20 seconds; that's seconds faster than the HP PSC 1210. And the Canon makes copies in 18.7 seconds; that's almost twice as fast the HP PSC 1210.
Unfortunately, the MP730 delivers a mixed bag on image quality. When printing, better paper has a big effect. When we printed text on ordinary paper, for instance, it looked grayish instead of black, and a gray shadow haunted the edges of letterforms, while on coated (not glossy) inkjet paper, text popped out in a solid black and looked much cleaner. Our color photo on ordinary paper looked very dotty, had rough transitions between shades, made a blob of detailed areas, printed lines with jagged edges, and mixed inappropriate colors; coated inkjet paper improved detail and let colors appear in the right hues, though much too saturated. And on top-quality glossy paper, textures, shading, and transitions suddenly looked right, and we saw sharp, clear detail.
Grayscale scans on the MP730 when compared with other scans seemed overexposed, losing paler shades of gray along with some detail, while color scans showed accurate colors and fairly good detail despite somewhat grainy textures.
Jan 27, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Hp deskjet f380 print and scan function copys with a wide black
clean the print heads and run clean cartridge utility from printer properties window.after that
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.
Nov 26, 2008 | HP DeskJet F380 All-In-One Printer
Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Jun 25, 2007 | HP PSC 1610v All-in-One Printer
Computers & Internet Logo
129 people viewed this question
Alun Cox
David Payne
David Payne
