well after some research or a lot of research. I found a few articles that suggest that there is a problem with the board inside the case. It suggest that you take apart the case and remove the hard drive and put it into your computer and it will work just fine.
Hi Lois, If your Maxtor appears in Disk Utility but the disk volume is not displayed, it's possible that the partition on the disk has been deleted for some reason. If that's the case, you will have to use a disk partitioning utility to create a new partition and then format the hard drive. Best wishes, Graemevm
mine will also occasionally disappear. i have had to do a restart of the pc which gets it back for my 160 gb firewire external.
the blinking light may be indicative of the hdd going bad, though.
Try it in another computer if you have one. Or...try it in another USB port on your desktop PC. I would see if it appears in the device manager. If so, and you don't get a drive letter, try running 'diskmgmt.msc' and looking to see if the drive pops up under available drives.
All you should have to do is copy your files from their present folder on your computer to the Maxtor drive; you can find the drive location by clicking on the My Computer icon; or you can drag the files from their present position to the Maxtor.
You have a possible corrupted file. Open My Computer and right-click the drive icon. Click PROPERTIES in the menu. Click TOOLS. Click CHECK NOW. Click a check into the AUTOMATICALLY FIX FILE SYSTEM ERRORS box. Click START. The OS may tell you a reboot is required.
If all else fails, dump the data to some other storage device and use DISK MANAGER to delete the partion, make a new partition and format.
