Question about Frigidaire FEB27S5A Electric Single Oven
Oven door wont stay closed - Frigidaire FEB27S5A Electric Single Oven
    President:
  • 949 Answers
The hinge door assembly is bad, they will run around 70.00
Below I posted a website that you can look at the parts, the springs are bad in yours.
This website they are out of stock, but you can see what they are and write down the part #, so you can go somewhere that has them, or find
an appliance dealer near you that has them.
Hope it works out for you.
http://www.appliancepartspros.com/part_details.aspx?part_id=2147742&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d109618%26diagram_id%3d362230
Posted on Feb 08, 2010
Tappan oven door wont close
Is the door lock engaged preventing the door from closing?
Aug 21, 2012 | Ovens
We have a classique oven and it wont close properly. It stays open about 25-30mm can you please give us advice? thanks
I presume the gap you are talking about is at the top of the oven door. If so, this means that the door springs are worn/lost their tension. The only way to fix this is to get the springs replaced.
Feb 13, 2011 | Ovens
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Door wont shut and the light stays on
Since this is a new install, check around the perimeter of the oven door and see if it is closing all the way flat against the surface. The hinge could have partially popped out and needs to be reset. Can you tell if the oven door is popped out at the top portion of the oven door or the lower portion of the door?
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Whirlpool RBS245PDS Electric Single Oven
The oven door on my Whirlpool oven won't stay closed
Sounds like the door hinge springs are weak, it will probably be neccessary to replace them both.
Please leave feedbck
Dec 06, 2008 | Ovens
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Frigidaire FEB27S5A Electric Single Oven Logo
128 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
