Question about GE Refrigerators
GE gsl25jfpabs Profile. Water stopped coming out of dispenser. Frozen? New valve? Help
Yes, probably frozen. Open the door, minimize the freezer setting in the refridgerator section, and try out the dispenser every once in a while until you get water to flow. Might take a couple of hours so make sure you have a backup freezer or a big cooler for your food.
Posted on Feb 13, 2011
I have a GE refrigerator water comes out but it's not making ice. Bought a new filter.model number GAL25JFXN LB
there are several possible causes for your symptom: failed water valve, failed dispenser microswitch, or the line has frozen solid where it runs close to the freezer interior approximately 4 inches from where it dispenses. push a long plastic zip-tie up the water line above the water dispenser paddle. if it stops against an ice blockage you will need the water line heater kit from GE.part#WR49X10173. If there is no blockage, remove the rear service panel and follow your supply line to the water valve...have a helper push the dispenser paddle while you feel the valve body- if there is no hum or vibration you may need a new valve#WR57X10032. things get more complicated if neither of those tips help, time to call a Tech!
Apr 08, 2016 | GE Refrigerators
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
GE Profile PSS26SGPA Water Dispenser won't stop dispensing water
water shutoff valve bad or dirty,could be minerals in your water
Nov 23, 2013 | GE Refrigerators
Our GSL25JFPABS Side by side refrigerator door Water not working
water valve problem. behind the fridge. 3 or 4 screws .2 water lines. really simple.
Mar 31, 2010 | GE GSL25JFPBS Side by Side Refrigerator
The water from the door of my GE Profile fridge doesnt work consistently. Sometimes it does and sometimes is does not provide water. It has started dripping inside the freezer leaving icicles.What to do???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Dec 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
No ice and no water dispenser
Would have to talk you thru with chat .
Jul 17, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker works, water will not dispense
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
OR
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Jul 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
Not getting water out of dispenser in door of GE Profile Refrigerator-Think Line may be frozen
There should be a connector at the bottom of the door , if you get water to here but not through the dispenser then the line is frozen in the door . This can sometimes be cleared by connecting a steamer to the pipe and letting the steam thaw the ice blockage but this will not generally be a permanent repair . If water is not getting to the connector then it may be a frozen water tank in the fridge compartment or a faulty valve
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
313 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
