Question about Xerox DocuColor 12 Printer
Verify UDP port 427 is unblocked from your printer at 192.168.1.107 to your PC
marketex
  • 371 Answers
SOURCE: Can't figure out how to open the UDP port number 427
Printers cannot function unless able to communicate in both directions.
Posted on Apr 26, 2009
SOURCE: cannot conect my printer to my wireless network
Don't know why this becomes an issue with these type of HP printers but i think ive worked a way around it...
Heres how you do it: (XP)
Control Panel>Printers and faxes>
Then select "Add printer" and choose the first option (Local printer attached to this computer)
An errormessage will appear saying they were unable to find printer. Click next to find the printer manually...
Now select "Create a new port" and choose standard TCP/IP... Ignore the list of different types of printers, now select "From Disk" and then click next... Once The computer recognizes the printer, it all should be in order...
Hope this could help you...!
Posted on Feb 18, 2010
nonontech
  • 4737 Answers
SOURCE: I can't get round this
If the printer is already detected and the problem is only with that UDP port 427, then you better create a new Firewall rule on the Router with the IP address 192.168.0.103. Referring to the screenshot you've posted back earlier, only two rules have been created. Add another two with the similar settings and with the new IP address 192.168.0.103. Restart your computer, the router and the printer. It should work fine. By the way, which router are you using? What model and what make? [for reference only, not much related with this issue.]
If you home network is already correctly setup and running, then you only need to deal with the Router's firewall settings.
Good luck.
Thanks for using FixYa.
Posted on Nov 14, 2010
vonnielsen
  • 169 Answers
SOURCE: Computer says unable to communicate with printer :
Most of the times just skipping that message will let you use the printer. That message is something that has to do with the printer rediscovery just incase the printer get's disconnected.
Checking with your anti virus software provider might help.
Regarding that message though. Try skipping that and try printing.
The printer should work.
Posted on Feb 06, 2011
  • 205 Answers
SOURCE: Trying to install a HP
try installing it with out an internet connection. If you are having internet dont update the product yet.if a firewall pops up and says that it is blocking the installation, just skip or unblock it.
Posted on Mar 29, 2011
I have an HPDeskjet D2360. It prints the test page correctly but if coming from a document such as MS office Open office or PDF, it comes out blank. Tried both for windows 7 and 10. How do i fix this?
If you can print, consult your firewall vendor's support site for steps to add the printer as an exception to allow communication with your printer. The printer uses UDP ports 137, 138, 161, 162, 427, and TCP ports 137, 139, 427, 9100, 9220, and 9500. After changing adding these ports as exceptions, re-enable the firewall in the Print and Scan Doctor.
http://support.hp.com/us-en/product/HP-Deskjet-D2300-Printer-series/1841737/model/1101015/document/c04714314/
could be a printer language mismatch with driver
check services and if print spooler is running
Oct 26, 2016 | Office Equipment & Supplies
Trying to install a HP Photosmart eStn C510 printer I keep getting an error message to Verify Firewall Software UDP Port 427 needs to be unblocked from your printer at 192.168.0.3 to PC Ineed...
Mar 29, 2011 | Office Equipment & Supplies
Computer says unable to communicate with printer : if using firewall unblock UDP port 427..I'm not sure how to do this. This problem occurs sporadically..sometimes the printer works, sometimes it doesn't
Feb 06, 2011 | HP Officejet 6500 Wireless All-in-One...
I tried connecting my wireless printer and it came up with this Your computer is unable to communicate with your printer at 192.168.1.5. This may be caused by firewall software. If you are using...
Open whatever program you're using for virus protection and/or firewall, and turn that OFF temporarily. If that solves the problem, then start looking for port blocking on the firewall software.
You might also try the ADMIN screen on the router - maybe 192.168.1.255. Log in and look to see if a firewall or port blocking feature of the router has been turned on.
You can discover the Router IP by opening a COMMAND PROMPT (black screen, white text), then typing ipconfig /all and "enter". The Gateway address will be displayed along with a lot of other information, including the IP of your PC.
May 08, 2017 | HP Photosmart C4580 All-in-One InkJet...
I am trying to install a wireless printer to my lap top and is asking me to make sure the udp port 427 is unblocked for inbound and outbound traffic how do you do that?
On your laptop open the control panel then windows firewall, if you are using windows 7 the first link on left should be allow program or application. You will add an exception rule, name it, specify the port 427 and click ok. Now on to the second part. Open your web browser IE logon to the router, for example linksys is 192.168.1.1 if you don't know what your routers ip is, right click your connection in the tray, click status and advanced and note the IP address of your gateway, this is usually your router or firewall.
Login to the router, find the firewall port forwards tab, specify a name and the port 427 and click save to create the port rule. Now try your setup again.
Aug 29, 2010 | NetGear Computers & Internet
Cannot conect my printer to my wireless network
Nov 21, 2009 | Xerox DocuColor 12 Printer
I have Windows XP and am trying to install HP Office Jet Pro 8500 Wireless and am getting the message to check UDP Port 427 to see if it is open. How do I do that? Don
Hello my friend,
If the HP device will be used locally you will not need to open any port, because open port mean do the port forwarding which is used only in NAT mode but anyway if they ask if the port UDP 427 is open that means that you need to access to the router web interface which is usually 192.168.1.1 and then under Port forwarding you will need to add a rule with external port: 427, Type: UDP, internal port : 427, internal IP: the ip of your HP device. and then save and reboot. everything should be fine after that.
Best Regards,
Oct 31, 2009 | Linksys Wireless-G WRT54G Router
HPOfficejet Pro 8500 Wireless - need to open port 427 -Norton 360
hi first of all I would like to inform you that you have one of the best printers of HP now the open port error 427 that you get is generally due to blockage in network or firewall so we need to first check weather the printer is successfully connected to the network or not so press setup on printer go to network and then go to print network config page it will be on view network settings now note the ipaddress on the wireless tab of the page open a internet explorer and then type the ip address in the address bar and hit enter the printer page should open up if it does that means the printer is on network now turn off nortan firewall and turn on windows firewall now click on the add exception tab of windows firewall it vista it will be allow a programs through windows firewall now click on add port and in port name type the ip address of the printer in port number type 427 and then select udp ot tcp according to the error message you get in the installation if its udp select udp if tcp select tcp now in windows firewall click on allow programs through firewall and then in exception tab check all the entries related to hp apply and ok now restart the computer now try to install
if still you get the same error
click next if you have next highlighted and go to the next step and select the third option from the screen that will be contiue installing the printer
complete the installation
if the next is not highlighted then add an exception in nortan as well for guidelines open hp.com and in the search bar type c01633677 and open the document select nortan and see the instruction to add exception
if still problem persists let us know
Aug 23, 2009 | HP Photosmart C4580 All-in-One InkJet...
Apr 25, 2009 | HP Photosmart C4580 All-in-One InkJet...
Since both your printer and your desktop are on the LAN side of your router, the hardware firewall isn't really a concern here. I would check the following:
-Make sure the printer is actually connected to the network. If you are having wireless difficulties, and have a wired ethernet port on the printer, try plugging it in rather than going wireless. (If this fixes the problem, you can then concentrate on it being a wireless connectivity issue rather than a firewall issue.)
-If possible, try printing from a different PC on the network. Does it work with that PC? If so, then reinstall the printer on the problem PC, perhaps even clearing out and reinstalling the drivers.
-You may also want to manually assign an IP address to the printer. This address must be within the same "range" as the rest of the network. Since your router is probably assigned 192.168.1.1, and DHCP auto-assigns your PC 192.168.1.100, make the printer 192.168.1.20. This way, the printer has the same address every time the PC goes looking for it.
-Make sure you don't have a second firewall on the affected PC. Zone Alarm, Norton Internet Security and many other "all in one" security packages sometimes throw a firewall in there without your knowledge. See if you can "ping" your PC from another computer on the network, and can you "ping" the printer from the problem PC?
Hope this helps!
Apr 06, 2009 | Linksys Wireless-G WRT54G Router
Xerox DocuColor 12 Printer Logo
1,267 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
