Lacie 1T Poulton design external hard drive is clicking
Lacie external hard drive is clicking. This is the second one I have had, will be returning this too. ANY WAY TO RECOVER DATA FAST?
Before you resort to freezers and desperation, know that the external power supplies for these things are a. crucial and b. delicate. If the output voltage is down for any reason, it can produce the same clicking symptoms. I would get to a repair shop, and ask them to test the drive with a 'known good' power supply. I did so this very morning with a LaCie drive: no more clicking, happily mounting drive...and power supply replaced under warranty. Good luck
Posted on Feb 19, 2010
  • 32,281 Answers
The hard drive may have already failed by now. When a hard drive makes a clicking noise then the read/write head is flicking back and forth across the platters.
Try the external drive in another computer. If this doesn't work, try placing the LaCie in a air tight plastic bag and place it in the freezer for a hour and then connect it to a computer.
If it doesn't work then your luck has run out. There are companies that can recover data from faulty drives BUT it will cost you an arm and a leg for their services.
The reason for this high cost, they dismantle and remove the platters in the hard drive in a clean room environment and set up the platters up in jig/drive to retrieve/copy the data.
Posted on Feb 08, 2010
My computer is not recognizing my hard drive.
You will need data recovery help. This guy does it remotely and works off of donations. FreeDataRecovery.us
Jul 12, 2011 | LaCie Hard Disk design by Neil Poulton...
I dont see the drive in my computer
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 28, 2011 | LaCie Hard Disk design by Neil Poulton...
I have a lacie 500gig external hard disc and i fail the optimization and the disc shows only 9.9mb and i formatted in hope that will have the same setup assistant -but i turn wrong.Please tell me a...
click start control panel administrive tools computer management scroll to disk drives if you can see your drive right click select properties tools tools you should see click check now click start tick in two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box then wait for that to finish
also + to expand right click you should see options update driver disable uninstall scan for hardware changes
hope this helps
May 06, 2011 | LaCie Hard Disk design by Neil Poulton...
I need to install lacie stup assistant.or download
LaCie Setup assistant is made to make it easier for the customer.
If you do not have it, you can format your drive using your MAC or PC and you can download manual and utilities from the LaCie website, which are the only things the assistant really does.
Regards,
Jan 10, 2011 | LaCie Hard Disk design by Neil Poulton...
Hi. I have a LaCie Hard Drive designed by Poulton with N2870 on it. I've misplaced the external power cord adaptor, and need to know what kind to get. The guys at Radio Shack said they need to know: ...
I have the same one. The power supply I have says input 100-240V output is 24W 12V 2A.
I'm replacing the power supply but my big problem is not knowing the polarity of the tip There is no sticker on the hard drive itself or on the power supply (that I suspect is fried). Can anyone help?
Lisa
Dec 13, 2010 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Harddisk woun't mount
The hard disk inside it has probably died. Take it out of the case and put it in the pc directly - if even now it's not responsive then it's surely dead - junk it. if now you can see it then the electronics if the case are dead - junk it and buy a new external case.
Jul 19, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
External hard drive emits noise and disconnects within 60 seconds
please try changing the hard disk compartment and thanks for your question
May 20, 2009 | Computers & Internet
Disassembling Lacie Hard Disk 500GB By Neil Poulton
this link shows you how to do it:
http://larrysthings.net/2009/05/31/opening-case-on-a-lacie-hard-disk-neil-poulton-designed-box/
May 05, 2009 | Computers & Internet
Computers & Internet Logo
309 people viewed this question
David Payne
David Payne
