Question about EliteGroup P4M800-M7 Motherboard
Can you please tell me where the front jack audio pins and USB pins has to be pinned
    Guru:
  • 161 Answers
Ok...
this is how you can find it..
you can see the audio pin in the lower left of your board...
and the usb socket you can see it in the right side of the board..
by the way there name encrypt on it..
take note the - sign indicates the black wire and the positive is the red..
don't get messed up..
hope i've help you..
Posted on Feb 08, 2010
How do I connect my acer c20 projector to my laptop?
here are options usb is most likely easiest though HDMI is highest quality any good retailer will have these cables take the unit down and tell them you need interface cable to usb for laptop
Input:
  • Analog RGB/Component Video (24-pin Universal) x1
  • Composite Video/Audio (2.5mm 4-pin mini jack) x1
  • HDMI (Mini, Video, Audio, HDCP) x1
  • USB (Micro-AB) x1
  • SD (Micro, SDHC) x1
May 23, 2012 | Computers & Internet
I have an Intel motherboard E210882 with front audio (2 USB Ports and only 1 Audio Jack (green color). I need the proper wire placement to connect each of the above to the correct pin in the J9C2 Pin Box....
It doesn't matter where USB ports go, they're universal.
Audio ports are usually labeled by color. Plug similarly colored plugs into similarly colored holes. It's possible your laptop might not have all the slots for the box.
Mar 01, 2011 | Computers & Internet
What is the maximum memory of P5S-MX-SE motherboard and what is thge type of video card should I use
memory support 4 gb ddr 2 1 x Audio - line-In - MPC 4 pin , 1 x memory - floppy interface - IDC 34 pin , 1 x parallel - IEEE 1284 (EPP/ECP) - D-Sub 25 pin (DB-25) , 1 x serial - RS-232 - D-Sub 9 pin (DB-9) , 1 x display / video - VGA - D-Sub HD 15 pin (HD-15) , 1 x keyboard - generic - Mini-DIN 6 pin (type PS/2) , 1 x mouse - generic - Mini-DIN 6 pin (type PS/2) , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x Hi-Speed USB - USB Type A 4 pin , 1 x Audio - line-out - jack stereo 3,5 mm , 1 x Audio - line-out (side surround)/line-in - jack stereo 3,5 mm , 1 x Audio - line output (cental/subwoofer) / microphone - jack 3,5 mm
Nov 12, 2010 | ASUS Computers & Internet
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
I have pront panel audio and usb port but am not able to connect the pin can you please explain me the pin diagram to connect my front pannel usb and audio
depends on what board you have?
majority have the same pin outs tho,
http://www.vistax64.com/attachments/sound-audio/8065d1227471405-realtek-audio-jack-mixup-capture.jpg
there is link to a page that explains both F_USB (Front usb ports) and F_AUDIO (front audio connections)
Aug 31, 2009 | Computers & Internet
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Sony Vaio VGN 'B series' - broken headphone jack.
Hi there, your question has two way you can fix it:
1) see speaker jack circiut on your motherboard, picture here
there are 5 pins to the jack socket, you may just find out 2 and 3 pin which is stereo audio output lines, and also need a ground 5 pin. then connect 3 wires go outside speaker. this way quite tough for you.
if you cannt do this way go next
2) find a USB audio card instead of onboard one. this is very easy.
reference here:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+audio+card&_sacat=See-All-Categories
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 24, 2009 | Sony VAIO® VGN-N130G/B PC Notebook
Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Apr 01, 2009 | Dell Dimension 4600 PC Desktop
Audio deosn't work on mobo
Hi Chris, the problem can be one of two issues. If the sound jack located at the back of the PC did function at the same time as the front case sound jack. Than the problem is the jack it's self is bad. (Back of PC). Someone had to hook up the front mic & sound jack to the motherboard. So disconnecting the front sound & mic may give you rear sound & mic.
Turn to page 2-29 in you're user manual for the Asus M2N-SLI. The pic shown is the default setting for the front case audio & mic. (What you do see are the two jumpers connected). So disconnect any connector & place a jumper over pins 9 & 10, (last two pins at the right of the two rows of pins). Place another jumper over pins 5 & 6.
Pin 1 is the first pin on the left bottom row (MIC2). Pin 2 is the first pin, left edge top row (AGND). Pin 8 is not installed but you still count its spot as if there was a pin. (This is how the board was setup from factory). Once you fix this you should regain sound & mic function at the rear of the PC. To fine tune the audio run the Asus sound effect manager. If you installed this software, (Recommended). If it’s not by you're clock than it’s in control panel.
Link to all for M2N-E SLI
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Good Luck!
m
Jun 07, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
63 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
