Question about Cell Phones
My G1 spent five months in a flower bed and was found last weekend covered in mud after surviving watering and several inches of rain. It's been cleaned up and surprisingly, the phone turns on, the screen looks great, and the keyboard works. I did a hard reset but I can't get past the "tap the Android" screen since the touch screen doesn't respond at all. There's some corrosion on the back side of the flip out screen, not from the battery, but probably from rust on a contact thingie next to the SIM card. Can this be fixed? I have my replacement but would like to have a standby since I can't be trusted with nice things. I don't want to do the repair myself, by the way, but would like to find someone who can do it.
  • 8,197 Answers
On link below is a site that will repair you g1 phone. You just mail it in and pay the fee.
http://www.ppctechs.com/T-Mobile-G1-Phone_1121/repairs/Full-Service-Repairs.htm
Posted on Feb 08, 2010
Tip
Cut Fresh Flowers to Last Longer
I love having fresh cut flowers in the house, they add so much color and life. What I have noticed is that I usually have to replace them because once they've been cut they never seem to last longer than a few days. I spent a bit of time expreimenting with different techniques for preserving fresh cut flowers so that they will last longer than just a few days. These are the best techniques that I was able to come up with.
The Proper way to cut flowers
Most people, myself included, think that cutting stems with regular scissors is okay. This is not the case, when you cut flower stems with scissors that aren't meant for cutting stems you can crush the stems and will block the flow of water to the flowers. Simply usng pruning sheers will work wonders for your flowers. Be sure to cut your stems underwater because you want to prevent air from going up the stem and blocking the flow of water to the flowers.
Mixing different things into the water that you place the bouquet in can help to preserve your flowers. I have to note that you should pick one of these methods and not mix all the suggestions together.
Putting a few drops of liquid bleach and a teaspoon of grandulated white sugar in a quart of water will work wonders. Mixing equal parts of lemon-lime soda and water is very good for your fresh cut flowers. If you don't have the soda on hand you can always use a teaspoon of white sugar, two tablespoons of white vinegar and a quart of water to preserve your flowers.
I like to use the lemon-lime method the most especially when you are going to be putting the flowers into a glass vase and will be on display immediatly. There is something beautiful about the bubbles in the water.
on Dec 15, 2013 | Event Planning & Celebration
How do I get rid of bed bugs in my mattress?
I recommend calling a professional; however there are a few things you can do yourself to control them. Make sure to vacuum the area around your bed thoroughly as well as the mattress itself. All of your bedding should be washed in hot water and dried on a high heat. Scrub the seams and folds with a hard bristle brush, and wash with alcohol. Whatever you do, DO NOT spray pesticides anywhere on the mattress where may come into contact later with your skin.
If you don't want to call a professional, take a look at this video, maybe you will consider buying a few simple products so that you can successfully rid of your bed bug problem.
http://www.youtube.com/watch?v=QFnXUsCdKMk&feature=related
Jul 25, 2012 | Furniture
Just bought a home and found a wall wet, took tile off and the foundation crumbled off and there was a hole underneath with water in it. What would cause that?
Most likely water up against the foundation wall exterior.
You have a major problem
First make sure that any water - rain or otherwise - is not allowed to build up or seep back towards your home
Rain gutters need to extend out 5 feet or more away from the home. Flower beds need to be graded away from the foundation.
You may have legal recourse with the seller and or appraiser depending on the laws in your state
I am so sorry to hear about your problem - your troubles are just starting Good Luck
Mar 08, 2010 | Plumbing
Mud mud mud, rain rain rain how to dry mud up? new home construction. put crush and run in drivway pure mud has swallowed 1st and second load of crush and run, had 9 inches of snow saturday, more expected...
depending on what the ground looks like under the surface stone dust might work well to help fortify the top layer into a solid mass. where are you in?if the grounds going to freeze i wouldnt do anything now.
Feb 04, 2010 | Sport & Outdoor - Others
Water in chassis from rain. When I accelerate or decelerate I can hear water rushing back and forth on both the drivers side and passenger side after a heavy rain. I took the trim off just under the door...
Water could be in the sill sections. There are usually several drains in every door and box section but the sill drains tend to be small and easily blocked by factory applied sealer as much as mud and dirt.
Sometimes a drain has to be "modified" and sometimes a new temporary or permanent drain must be produced.
The water location might be pinpointed by jacking the vehicle in certain ways while stationary.
Nov 15, 2017 | 2000 Mazda MX-5 Miata
Shuts off will driving, especially if I hit a bumpy road.
check the wires to the fuel pump if they have rubbed against something and the insulation wore through hitting bumps or rain could cause it to short and kick the relay and resets again and will start
Jul 06, 2009 | 1996 Jeep Grand Cherokee
Want to Kill Clover in Vinca Beds
vinca is pretty hardy..but check the label on weed be gone ..if its not listed i would try putting it on a FEW vinca plants and observe if they survive...you will know in 1-2 days.
May 31, 2009 | Ortho Chickweed Clover Killer Pint
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
