Question about Hitachi CP-X251 LCD Projector
The image from my cp x251 is uneven the top and right side are angled but the bottom and left side are straight and perfect on the screen.
  • 3 Answers
This is a common problem with projection systems this is the reason that most screens are lined with black felt its non-reflective and works great to hide uneven edges also try balancing out the difference with the keystone adjustment
HitachiTech
Posted on Feb 09, 2010
When I turn on the CP-X251, the fan cycles several times and then the overheat light illuminates. Only takes about ten seconds...
have you checked the filter. is there any blockage to air flow. is the machine mounted upside down
Mar 03, 2011 | Hitachi CP-X251 LCD Projector
Chainsaw does not cut straight, veres off at an angle only happened since adjusting the chain ,is there an adjustment for this?
Typically this is a problem with sharpening the chain....if the chain has been sharpened unevenly (different angles on the cutters) it will drift to one side. Also most people tend to be more comfortable sharpening one side than the other and the teeth on that side will get worn faster.
As long as it is that right chain for the saw / bar and it is sharpened evenly it should cut straight.
There is no adjustment per se.
Take care.
Dec 06, 2010 | Garden
Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
Sep 04, 2009 | Hitachi CP-X251 LCD Projector
Picture not square
keystone should help in your opinion. adjust the keystone and the picture should be a square then.
Oct 28, 2008 | Hitachi CP-X275 Multimedia Projector
Image has bend at top of screen
first reset the setting to factory default. if it persists on a regular image too, either the lens, the tunnel or something else in the optical engine is damaged (from a fall?).
Jul 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Uneven flash
Look carefully at your images taken with flash... on the horizontal image is the lower part of the image slighty darker and have a rounded fall off at the edges? Is the vertical image dark side a straight hard line or is there a rounding to the top and bottom?
What we are looking at is if you have a very wide angle lens with the lens shade attached to the lens, then the built-in flash catches part of the lens shade and make a shadow on your subject... take the lens shade off and try the same shot and see if that makes a difference...
Have a great day...
Ed
Apr 03, 2008 | Nikon D40X Digital SLR Camera Digital...
Hl-44266w screen allignment
Don't recommend replacing the light tunnel if you never had any experience with DLP optical systems. you need to pay careful attention to the way you remove any screws or you will be forced disassembling the engine multiple time to get the alignment correctly.
Jan 01, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Sony KP-57WS510 Convergence issue?
Replace convergence IC's....STK392-560 X 2 + check pico
fuses under IC heatsinks.....................T.
Nov 12, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Hitachi CP-X251 LCD Projector Logo
180 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
