Question about Kodak Easyshare C813 Digital Camera
Error on formating new memory card in camera error says memory card is full brand new card i tried 2 in faact same error kodak c310
    Genius:
  • Kodak Master
  • 1,099 Answers
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Posted on Feb 08, 2010
A new SD card 2 GB wil not work in my C310 kodak digital camera Message in camera "memory card full" message in card reader when trying to format the card says "write protected" Is this card too Big?
No, the C310 will handle a 2GB card.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 10, 2010 | Kodak EasyShare C310 Digital Camera
I placed a new memory card in and the camera says MEMORY CARD FULL. i try to format it and the error code says FILSYS ERROR e00100
1. Remove the memory card from your camera.
2. connect it to a computer using a compatible card reader or can directly connect to a laptop using its card reader present in the laptop.
3. Format the card from your computer and put the card back to your camera.
I hope this is helpful to you
Please rate the solution provided.
Thanks
Jun 29, 2010 | Kodak EasyShare C310 Digital Camera
My camera won't accept new 2GB SD card. Keep
Do you have pics on the internal memory? You must format the internal memory with no card in the camera. Then, format the card.
Jun 07, 2010 | Kodak EasyShare C310 Digital Camera
I have a kodak c310, trying to format the card and it keeps saying memory full format card, so i format and it comes up FILESYS ERROR e00100, but it's a new card?
The c310 will only accept SD cards up to 2GB.
You haven't said which card you're trying to use but the symptoms are typical of those encountered if you try either a larger capacity SD card (which go to 4GB maximum) or if you're trying to use a later SDHC (the HC means High Capacity) card. The c310 was designed and manufactured before SDHC cards were manufactured and is incompatible at the basic hardware level. SDHC's will fit inside as they have the same form as SD cards, but your camera is unable to use them.
If you have tried using the wrong card then all you need to do to fix the error is to replace it with a standard SD card not exceeding 2GB. In practice you'll find that your camera may have issues with some brands/models of 2GB SD cards but that it will work fine with any make or model of 1GB SD card. The smaller capacity card will also ensure that your camera does not become awkwardly slow in operation.
Hopefully I've answered your question; all I ask in return is that you return the favour by rating my answer.
Oct 21, 2009 | Kodak EasyShare C310 Digital Camera
MEMORYCARD
Did you format it in the camera or in your computer? In the camera is the correct way.
Oct 04, 2009 | Kodak EasyShare C310 Digital Camera
MY kodak easyshare c310 wont work
Take the pictures off the camera first and then format the card IN the camera.
Jul 31, 2009 | Kodak EasyShare C310 Digital Camera
Memory card reads full
What size card is it a plain SD or MMC? is it less than 4 meg? is it 2 megs or less
2 meg or less it needs to be formatted. It is 4 meg the camera will not read it.
It happened to me on a Z740
Jul 24, 2009 | Kodak EasyShare C310 Digital Camera
I bought my Kodak Easyshare C310 a few years ago and has been working fine. I bought a new SD card as lost my old one, and when I inserted into the camera it said the memory card was full (wasnt as brand...
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Kodak EasyShare C310 Digital Camera
Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
Mar 22, 2009 | Kodak EasyShare C310 Digital Camera
Kodak memory card error
Hey hardygurl198,
What is most likely going on is you need to format the card so it will work in your camera. Every time you get a new memory card for a digital camera or if you put a memory card formatted to a different camera in a new digital camera you will need to format the memory card before you can use it. Directions on how to format your memory card are on page 27 of your camera manual, and I have provided a link to a PDF download of your manual in case you need it. I hope this helps!
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00431/C310_CD40_GLB_en.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 08, 2008 | Kodak EasyShare C310 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
220 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
