Question about Eiki EIP-2500 Multimedia Projector
Remote won't turn on Eiki EIP-2500 projector
I have an Eiki EIP 2500 at my church. I have recently run into a problem with the remote not turning on the projector. I can turn on the projector manually from the button on top. When I try to use the remote, though, it won't turn on or off. I have brand new batteries in the remote. Also, if I uplug the projector, and hold the power button for about 10 seconds, then plug the projector back up, sometimes the remote will work, but the next time I go to turn the projector on it won't turn on via the remote. I have no idea how to go about troubleshooting or fixing this. Any suggestions? Thanks.
  • codermeister Feb 08, 2010
    Actually, I forgot to mention that I had thought of that and went over the LED on both the remote and the IR port on the projector with isopropyl rubbing alcohol and a Q-tip. Thanks for the suggestion, though.
    homedesigner, I had a sneaking suspicion that might be the problem, but I wasn't sure if remotes go bad. I appreciate the assistance. It looks like I'll just have to order a replacement remote for it. Thanks!
  • 583 Answers
Try cleaning the IR port on the projector (and the remote itself). These can get enough of a dust layer build up that they can't "see" the infrared signal being sent.
Posted on Feb 08, 2010
  • Mark Tidwell
    Mark Tidwell Feb 08, 2010
    My electronics tech background would suspect the remote itself is going bad. If you have a learning remote somewhere that you could try learning the power on/off code of the original remote (since they are placed only a few inches apart, you could most likely still get a learning remote to work). Then, if the remote will turn the unit on and off, you'll know it is time to replace the remote. The IR receivers usually don't go bad, although it is not impossible.
Where can I find a service manual for the Eiki EIP-2500?
difficult to find online, try comparable model of SHARP XG-MB55X
May 24, 2012 | Eiki EIP-2500 Multimedia Projector
How to remove top cover of Eiki EIP-2500 projector
loosen all the screws from the bottom ( one is in the middle) and two at the back ( edge)
press the grill on exhaust fans side near the heat warning mark.Lift carefully the rear and turn towards the lens side, BUT BE CAREFULL that some points of the upper cover will not scrape of some smd parts from the mainboard !!
Eiki EIP 1600T projector will not power on. Projector was running when power went off for just a few seconds. Will not power back up now. I have power to projector.
inside there is a thermal fuse, that might be activated, because the cooling of the lamp did not happen after the power surge.
You need to remove the upper cabinet to reach, but do this very carefully !!
May 22, 2011 | Eiki EIP-1600T DLP Projector
Is it possible to connect a projector and a flat-screen tv and control both with a laptop computer? (the flat screen would be used instead of a projection screen)
when connected at the same time, you need an active signal splitter, or
connect the flat screen to the monitor out terminal of the EIP-2500.
Apr 03, 2011 | Eiki EIP-2500 Multimedia Projector
Need a new remote control for a EIKI EIP1. How do I order one? I am in Perth Western Australia
Hello, I couldn't find any remotes available for this projector.
Try contacting Eiki directly with the form on the page below
Click here:http://www.eiki.com/ContactForm.aspx
Sep 20, 2010 | Eiki EIP-2500 Multimedia Projector
No power to Eiki EIP-2500 projector
there is a fuse on the power supply. if the fuse is good, you'll need to replace the power supply.
Jun 22, 2009 | Eiki EIP-2500 Multimedia Projector
Eiki EIP-25 shuts down after 30 sec (ceiling mounted)
there must be something loose inside. maybe the button panel.
Mar 07, 2009 | Eiki LC-X50M Projector
Eiki EIP-2500 Multimedia Projector Logo
518 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
color wheel light...
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
