Question about Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
SP0812N HDD 80Gb
I installed a second HDD to my PC as Slave.
It's a SP0812N and should be 80 Gb. The master is a WD 120 Gb. BIOS identifies the model correctly but with 32 Gb only. Is there something in my motherboard that limits the HDD size?
  • El-Sid Feb 24, 2008
    I found the problem !
    This issue isn't an OS issue, the BIOS detected the drive with 32Gb before starting Windows. When I tried to connect the drive to the secondary slot, I read the jumper settings to set it to Master and I noticed there was a jumper option to limit the capacity to 32Gb. I took off that jumper and at the next boot the BIOS detected it with the right size: 80 Gb. Although Windows stole aout 5.5Gb cause it detected only 74.56Gb for partitionning. I wonder why Microsoft steals so much ?
    Genius:
  • 1,019 Answers
this mainly depends on The Operating system, if your using Windows 2000 or above it should,nt be an issue.
sometimes there are limitations on 2 hard-drives sharing the same IDE channel on the mainboard.
Try putting the second hard-drive on the secondary motherboard slot, with it,s own individual cable.
If non of the above works, it,s possibly not formatting correctly.
you,ll need a program that zeros then formats the drive.
Hope this helps.
Mike @ Compurepair.
Posted on Feb 22, 2008
  • Mike Waldron Feb 24, 2008
    all hard-drives are,nt true capacity, it,s standard for a drive to format out to 74-76 gig. this is due to the allocation units for blocks/cylinders et,c. the o/s is only probably 700mb plus.
    The main thing is, that your up and running.
    I bet your glad you took the time to study the jumpers ?
    Regards mike @ Compurepair.
Can not detech
Good day!!!
please check the HDD itself if it is set on master?slave?
please change it to master..
if the problem persist just add a comment.
Jul 11, 2011 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
How to set master, slave settings in sata hdd
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Regards
Ashly
Feb 02, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Need to know how to upgrade a hard drive from a 8 gig to 80 gig
I am typing this on a Dell 4600 RIght now. You need to look up how to set the jumpers on the internal hard disk ( 8GB) to SLAVE MODE, and set the 80GB to Master.
Remove the 8GB from the metal bracket, and put the 80GB in its place. Put the 8GB beside it. Plug the 80GB into the end of the IDE cable, and the 8GB into the middle. When you boot, you can hit F2 to go into the bios, and change the boot order from HD0 to HD1 and you can boot from your 8GB.
Now, If you want to boot from the 80GB, ( which I would ) you need an operating system.
Get your Disk labeled Reinstallation CD, Microsoft Windows XP Home Edition, Including Service Pack 1, and boot from it. Then format the 80GB, and install the OS There.. You will need your WIndows XP Home Key. ( you can either get it off the case or use Magic Jelly Bean Key finder to get it off your 8GB. Get the key and write it down. ITS IMPORTANT ).
Then you can change your boot order in BIOS, back to HD0, and boot from your fresh copy of XP Home.
If your interested in having a close to seamless experence as possible, you might want to invest in a copy of Partition Magic Pro. It can copy both the restore partition, ( the first 600MB of your 8gb disk ) and the primary partition of the 8gb, and resize the 8gbs primary partion on the 80gb to 80gb. ( YEA! ).
If you have *any* *any* lack of understanding please clarify
Oct 01, 2009 | Dell Dimension 4600 PC Desktop
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
WD drive won't work as master when Seagate 80GB drive connected as slave.
The jumpers on the Seagate must be set to slave.
otherwise they are conflicting for the Active partion and bootloader.
Regards
Richard.
Apr 26, 2009 | Western Digital Caviar WD200BB 20 GB Hard...
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
I have a 2000 1100 series computer with a 37 GB hard drive thats out of space. I ordered a 80 GB and installed it but it still only shows the 37 when i go the my computer icon how do i clone the 80 GB to...
jjfsrm,
to clone ur 80gb,u must have a cloning software..
and if u wanted that the 80gb is ur first drive,u should install ur operating system on ur 80gb..and of corz the jumper on ur 80gb hdd must be on primary position,and for d 37 should be a slave..
ur 37gb is the first boot thats why it is on the primary,but if u put ur 80gb into primary,ur computer will not function well coz it does not have the o.s..
Apr 07, 2008 | Computers & Internet
Samsung SpinPoint P80 SP0802N 80 GB Hard Drive Logo
573 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
