Question about Frigidaire GLTF2940ES Front Load Washer
Mold growing mold is growing in the front of this washing machine. It sticks inside and looks really gross. Any suggestions???
    President:
  • 949 Answers
If you mean on the outside of the machine, there is probably a slow water leak, and it is soaking the floor which is making to much moisture.
If your talking inside the machine.
Try and wash by hand the machine with a 50/50 bleach/water/ and a 1/4
cup dish detergent.
Run the machine through a full wash cycle, with a 1/2 gallon bleach
in a small load setting,
Then run the machine with full load setting and nothing for detergent, just the water, say three times. To flush all the cleaning you did away.
From now on leave the door open when done so if there is any water or moisture inside it does not stagnate.
Posted on Feb 08, 2010
Mold in bosch nexxt 100 series- how to get rid of it?
yes bleach and a very hot wash. but remember mold grows in damp /wet so always leave door and soap draw open when machine is not in use this will dry out parts and cut down on mold growth ,
Sep 09, 2016 | Bosch Washing Machines
Mold in the machine. how do I clean and disinfect it?
The best way to get rid of the mold is to use bleach water. You need to clean and scrub it out, making sure the bleach gets in every cranny. Lastly, really (and I mean really) rinse it out. I would suggest washing it out several times to be careful.
Elisa Jed ' http://www.colfaxcorp.net/services.html
Apr 06, 2014 | Venta Airwasher VS 207 3.7 Gallon...
Bad odor
I fixed the bad odor problem once and for all!
This problem is caused by mold and mildew growing in a large ventilation hose that runs from the top of the wash drum to a large vent hole in back of the machine.
To correct this problem you can buy a kit from http://washerfan.com/ or do the cheap fix like I did.
Step One: Find the vent grille on the upper left corner of the machine. Remove the machine top, only a couple small screws hold it on.
Step two: Remove the hose clamps that hold the hose to the drum and grille then snap out the plastic grille.
Step three: The grille is convex so I used a belt sander to make it flat then I took a computer case fan that was the same size as the grill and hot glued it to the plastic grille. I wired it to an old 12 Volt phone charger (12V 500 Ma) and made it blow air INTO the vent.
Step Four: Put everything back together and enjoy a stink free washer because the mold can no longer grow in that hose.
Note! You must bleach, clean and scrub that crud out of that large vent hose and it is some kind of gross! If you're allergic to mold please wear respiratory protection. My fan has been blowing air into the washer 24/7 for six months and I have seen those case fans run non stop for years. It it dies just snap the hot glue beads and put another fan on it. Total cost for the entire fax, about $10.00
Mar 30, 2014 | Samsung WF337AA Front Load Washer
SAMSUNG WASHER SMELLS AND STAYS DAMP
Note! You must bleach, clean and scrub that crud out of that large vent hose and it is some kind of gross! If you're allergic to mold please wear respiratory protection. My fan has been blowing air into the washer 24/7 for six months and I have seen those case fans run non stop for years. It it dies just snap the hot glue beads and put another fan on it. Total cost for the entire fix, about $10.00
Also note that you have to leave the door open a little bit for the air that blows in the back to blow out the front door.
Feb 10, 2014 | Samsung WF337AA Front Load Washer
Washer stinks
Dec 19, 2013 | Samsung WF337AA Front Load Washer
Mold on the seal
In the front load type washing machines you have to leave the door open after using it to allow everything to dry out. If you dont do this it will cause mold to grow on the door seal and inside the machine. So remember to leave the door open . Hope this helps you.
Feb 01, 2011 | Maytag Neptune Washer
Mold and mildew all around the seal.
The only solution here is for you to replace the door seal, and in future, do more high temp washes, as the prob is caused by doing too many low temp washes, ie: 40--50 degree temp washes, this causes build up of bacteria and the like.
Please rate my solution.
Thanks.
Oct 18, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Mold is growing in the washer...HELP!
Look at the manufacturer instructions for help first for guidance. If none, I suggest you put in a heavy duty dose of chlorine bleach. Dont exceed 25% mix to start.
Sep 07, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
Mildew
all front loads all brands have same issue with mold people today tend to use less bleach CHLORINE BLEACH that is ..allow machine to fill with hot water normal wash pour 2 cups CHLORINE BLEACH in water allow to wash a few min to mix open door and with cloth wash inside of door gasket be sure to roll gasket back and wash underneath lip allow to finish complete cycle should remove most of mold try to this every few months..also leave door open between use to allow moisture to dry out as much as possible like i said YOU ARE NOT ALONE
Jun 27, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
114 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
