Question about Sewing Machines
How to thread the Serger 334 DS - Sewing Machines
  • 161 Answers
Look on you tube; most overlockers are pretty similar and there is a good video there
Posted on Sep 14, 2010
My serger is still not working properly trhread still breaking lower and upper
Generally, thread breakage is due to incorrect threading, threaded out of order, tension too tight, or the threads are looping or hanging up on their way through the thread path. Be sure to remove ALL the threads from the machine and RAISE the presser foot while threading. Give each thread an extra little tug when going through the thread tensioners to make sure they are seated all the way. Consult the owner's manual to verify the thread paths are correct and the threads are threaded in the specified order. (If not threaded in the proper order, the serger will most likely never work satisfactorily.) Perhaps changing thread brands will help--and avoid old or bargain bin threads. Set the tension guides to the midway point between high & low numbers before testing.
If there continue to be issues, the timing may be off or a looper may be bent. Take it for service.
Make It Handmade How to Thread Your Serger Out of Order
sewing patternreview com
https://answers.yahoo.com/question/index?qid=20120705022414AAvIeRH&submit=y
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
serger thread keeps breaking help
Mar 19, 2016 | Sewing Machines
Tip
Threading a Serger
When threading a serger, you MUST follow this sequence.
1. Upper looper
2. Lower looper
Then thread your needles. If your thread breaks, you must un-thread your needles before re-threading your loopers.
on Mar 05, 2015 | Brother 925D Serger
Threading diagram for rimoldi 3 thread serger model 627
Rimoldi Serger Manual PDF And Ebook Files - DocsFiles
docsfiles.com/pdf_rimoldi_serger_manual.html
Rimoldi Serger Manual PDF Files, Manual For Rimoldi Serger honda nx 250 service ... Manual FREE Parts Crochet - Loopers RIMOLDI 8 8 Kl 327 , 527 , 627 , F27 ...Rimoldi Serger Manual Rimoldi B.27.77 Industrial Serger, 3-Thread, Nov 26, ...
rimoldi 329 threading diagram Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your rimoldi 329 threading diagram question. ... Rimoldi orion 627... rimoldi overlocker how to thread Which Model Rimoldi? ... Level 3 Expert.
rimoldi pdf - P(1) - Docs-Engine.com
Feb 05, 2016 | Sewing Machines
Why does the upper looper thread keep busting?
Quite possibly the machine is not threaded correctly, the tension setting for that looper is too tight (could be the upper looper tension disk is stuck or dirty causing the thread to hang), or the thread is looped around something like the thread tree.
Replace the needles. Remove all the thread and re-thread from the beginning. Be sure to RAISE the presser foot before threading. Make sure to thread the threads in the correct order.
Serger Troubleshooting For Any Serger Serger Machine Series Ep 4
Nov 01, 2015 | Brother 1034D Serger Sewing Machine
Kenmore serger thread keeps breaking
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Mar 26, 2013 | Sewing Machines
I recently got an older bernette 334 ds serger and it doesnt look like it hss ever been used. i went to plug it in and run it and nothing happened only light came on
If it's old and has never been run, it will need a proper service fro the parts that have become immobile due to the lubricant "gumming up".
Off to the sewing machine shop for you!
Jan 15, 2013 | Bernina Bernette 75
Can serger for about 3 inches on my brother 1354d serger and then thread breaks
Jan 01, 2013 | Sewing Machines
My serger will only sew a few inches, then the thread on the lower looper breaks. I have checked threading, rethreaded many times.
Been there, done that. Old serger almost went out the window more than once.
Raise the thread antenna and loopers to their highest positions.
Set the tensions to zero. If your serger has auto-tension, raise the presser foot as this also opens the tensions.
Begin threading from the right as indicated in your manual or on the door of the serger.
If this continues, the serger may need to be serviced as the timing could be the problem.
Ask before leaving the serger as the service cost usually starts around $100.
I finally gave in and bought a Babylock with instant jet-air threading.
Apr 01, 2010 | White Sewing Speedylock 1600 Mechanical...
The order in which to thread the serger
Your serger should be color coded for threading. Just do one at a time either left to right or right to left with the cones. And you should be all set.
Apr 19, 2009 | Baby Lock Eclipse Serger
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
