Question about Samsung WEP301 Bluetooth Headset
While i am in the basement my bluetooth headset beeps and the pjone get disconnected from the tower.what could be the reason?
  • 583 Answers
Bluetooth is only rated for about 30' (with no interference from objects). The flooring between your basement and upstairs is sufficient to block your bluetooth signal.
Posted on Feb 08, 2010
Bluetooth headset disconnects for no reason
Established in 2003, Shenzhen Gblue technology Co., Ltd. specializes in research, development, design, manufacturing and marketing of Bluetooth products, such as Bluetooth headsets, Bluetooth headphones, stereo earphones, wireless mouse and some other consumer electronic products. Our products are well received worldwide due to our uncompromising quality and fashionable appearance. We have integrated production lines, so we could easily meet your requirements.Shenzhen G-Blue Technology Ltd. http://www.gbluetech.com
Nov 30, 2012 | Sony Ericsson Xperia NEO MT15i Unlocked...
Plantronics Voyager 500a bluetooth system. was using the lifter, but don't want to anymore, just want to be able to switch phone to headset mode and use the bluetooth. When I hook it up and hit the...
The beeps mean it needs to be repaired or resubscribed.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
If you are using a Cisco phone you could probably plug the headset base into the phone. If it is not you will still need your lifter.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics Voyager 500A Deskphone Adapter...
My Plantronics Blue tooth earpiece gives a constant "three beep" sound. I can hear the other person on the phone but the constant beeps at the same time. The beeps happen also when the phone is...
The three beeps usually indicate low talk time. If you have tried turning off and on your headset and still have the annoying beeps, then there is a problem with the device. You'll need to contact your retailer or Plantronics (800-544-4660 x5538) for warranty replacement. If it's out of warranty, check out our website Headsets Direct for the latest in Bluetooth headsets.
Good luck from Headsets Direct!
Jul 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
I just need a pin number so i can pair my headset to my iphone
Step 1: Set the headset to be discoverable
Turn off the headset.
Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. let me know does thsi help regards golu_fixya
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. user_offline.gif
Aug 29, 2010 | Cell Phones
Pairing ge 86710
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select 86710once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 28, 2009 | GE Bluetooth In-ear Headset Wireless...
How do i disconnect my HBH PV703 Headset from a damaged phone and connect it to another Phone
Step 1 - To reset your Bluetooth headset:
  1. Press and hold down the volume keys "+" and "-" on your headset at the same time, until your hear a beep and the light flashes red and green alternately.
  2. Press and hold down the volume keys on your headset until it is turned off. The headset is now reset as it was when purchased.
Step 2 - To pair the headset with your phone:
  1. Make sure the headset is turned off.
  2. Turn on the Bluetooth function and Bluetooth visibility in your phone (This makes the phone visible to other Bluetooth devices).
  3. Place the phone within 20 cm (8 inches) from the headset.
  4. Press and hold down the call handling key on the headset until it beeps, shows a steady green light and then flashes red and green alternately. If the indicator light only flashes red or green, simultaneously press and hold down both volume keys until the headset beeps and flashes red and green alternately.
  5. If your phone supports auto pairing, press "Yes" when you are asked to add the headset to the phone. If not, check your phone User Guide on how to pair the Bluetooth device. If required, the headset passcode is 0000.
  6. The headset beeps and flashes green when successfully paired.
Jan 21, 2009 | Audio Players & Recorders
Constant beeping / connect/ disconnected
you need to turn off your bluetooth on your phone,cause as long as its on,its going to try to reconnect to your phone
Aug 27, 2008 | Motorola Mobility H350 Wireless Headset
Can't Pair With Phone
I had the same thing happen twice just recently and had to call my network and have them walk through some steps over the phone with me. They had to have me enter some numbers they gave me while talking to them and it came on. Be sure to call from a different phone than the one you are having the problem with. I also had it happen again a few weeks ago and I just removed the battery from my cell after disconnecting the bluetooth and then when I put it back together and reconnected the bluetooth it worked fine. I have had it for over a year and never had any trouble with it until this.
Jan 20, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Samsung WEP301 Bluetooth Headset Logo
50 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Ed Nelson
Ed Nelson
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
