Question about Sewing Machines
How do I get an instruction manual for Contessa 510? I need to thread the machine and bobbin. Also need to know how to place the bobbin thread so as to have the needle pick up the bobbin thread. Is it possible to still get a manual for the machine? Thanking you,
I have this manual if you want some pages sent by e-mail let me know.
Posted on Sep 13, 2010
I need help putting the bobbin threader back onto a Nelco JA38 sewing machine and the springs are giving me fits. Any help?
Not sure if you are having problems with the bobbin winder or threading the bobbin. This may help:
Nelco JA 38 Sewing Machine Threading Diagram
To avoid awful thread nests under the fabric, be sure to ALWAYS RAISE the presser foot when threading the top thread.
Interestingly, the bobbin threading instructions (above) show the bobbin loading into the bobbin case so it turns COUNTER-clockwise. This is the opposite of instructions for most machines. You can probably try both, the clockwise or Counter-clockwise,and see if one works better than the other.
Be sure to use fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil on your machine. Open it up, while gently wiggling the handwheel, drop a couple drops of oil every place that metal rubs against metal. Avoid plastic or rubber parts! You may even find little round holes throughout that are oil ports. Be sure to get the area around the needlebar, presser foot lifter, feed dogs, the bobbin area, and all the dial and selector mechanisms.
You can find manuals for your machine online (not free!).
Nelco Sewing Machine Manuals Instruction and Repair Manuals
Aug 07, 2017 | Sewing Machines
Need manual instructions for Riccar 2910 need help with bobbin, threding machined and tension setting and bobbin holder.
You may be better off going to google and search "riccar 2910 manual" That way you can follow their detail dorections rather then someone elses and it confuse you. Usually the PDF versions have pictures with it :-)
Apr 07, 2016 | Riccar Sewing Machines
I have mislaid the instructions for my Elnita 140. In particular, I need to find the instructions for threading, including the little bobbin that goes underneath!
This is a machine made under licence for Elna back in the 80's I believe. So should be a bobbin inside a bobbin case mounted vertically. Try this link for threading up, it should be very similar.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_225_threading_diagram.htm
Many machines have this bobbin case design and they all work much the same way, you need to place the bobbin into the bobbin case with it turning the right direction, click the thread into the tension spring on the outside of the bobbin case then latch it into the rotary hook of the machine, usually there is a little latch on the bobbin case that holds it in.
Top thread is usually fairly obvious, from the spool through an eyelet, through the take up lever, through a tension device, then down to the needle.
Always thread up with the pressure foot raised as this opens up the tension device and allows the thread to seat in correctly.
You can probably buy a manual for your machine from either sewusa.com or www.sewingpartsonline.com or "sewing machine relics" websites. Or just search ebay, there are several vendors who sell pdf copies of different manuals there.
I hope this helps you get sewing with your Elnita, four thumbs up if so.
Aug 21, 2011 | Sewing Machines
Borrow sewing machine from sister unsure how to thread it correctly and when i do the thread fromthe needle keeps breaking when i try to sew its a brother XL-5130 sewing machine and i know nothing on how...
you need to go to this webpage http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/doc/manual_index.html?reg=us&c=us_ot&lang=en&prod=hf_xl5130eus&dlid=&flang=English&type2=-1 and download the instruction manual for this model. It has the threading up instructions plus selecting stitches, winding a bobbin etc.
The thread breaking is most likely due to incorrect threading up of the top thread. I suggest that if you can, you print out the manual, put into a little folder and place beside the machine and refer to it often. Follow the instructions in it on winding a bobbin, putting it into the bobbin case correctly and threading up the top thread. Make sure the bobbin goes into the case the correct way, as per image.
Remember, ALWAYS THREAD UP TOP THREAD WITH THE PRESSURE FOOT RAISED, this keeps the tension discs open so the thread can seat into the tension device correctly. And you must get the bobbin thread into the tension spring fully and then place the bobbin case into the shuttle using the little latch so it stays in place.
Also, new needle for every new project, and put the needle in "flat shank to the back". It will take standard domestic sewing machine needles 705/130H but it is important to select the correct sized needle for the fabric you are sewing so that the needle can penetrate the fabric but not leave big holes. So for light weights like chiffon you want a size 60 or 70. For medium weights a size 80 and for heavy fabric like denim or a coat weight wool you would use size 100. Ball points for stretch fabrics so that the needle pushes between the fibres and a regular point for woven fabrics.
I trust this helps you out, 4 thumbs up if so. Thank you.
Jun 28, 2011 | Brother XL-5130 Mechanical Sewing Machine
Bobbin thread does not loop up when threading machine. Then the needle thread get wraped around the inside the bobbin sewing the material to the machine
There are so many thing you need to re-check.
First clean out the bobbin area to be sure there aren't any thread tangles still there.
Open the manual and start from the beginning with threading the machine with the presser foot lever UP - always.
Read the instructions and do not rely solely on the pictures as we all sometimes rush to do (I am just as guilty as the next person to do this).
Make sure the bobbin thread is feeding from the bobbin case in the correct direction.
Hold onto the end of the top thread (after needle has been threaded) and lower then raise the needle to catch and bring up the bobbin thread.
Place the fabric under the presser foot and as you hold onto the ends of the top and bobbin thread, hand walk the first stitch, then use the power pedal.
If you need a manual, you can download (free) from Singer - http://www.singerco.com/accessories/manuals.html
Mar 25, 2010 | Singer 8280 Mechanical Sewing Machine
Cannot remember how to thread bobbin elna
i solved the problem after i had a closer look at the top of machine
Feb 14, 2010 | Elna Sewing Machines
I have a Bernina 530 Record and i'm trying to but
You would be best to download an instruction manual for your machine as it explains clearly, with diagrams how to thread and insert the bobbin. You probably wont find the 530 manual however download a copy for Bernina 530-2 or 532-2 as they are almost identical to the 530.
Sep 25, 2009 | Bernina Sewing Machines
ELNA CONTESSA 410
I have a Elna Contessa 710 Manual. If you think it will help I may be able to scan a copy and email it to your own email address. Plz supply email address if interested or still unable to thread machine.
Mar 14, 2008 | Elna 2007 Mechanical Sewing Machine
Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
Dec 12, 2007 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
