Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
My daughter dropped my Canon SD750 on tiles and now wont turn on. Tried charging battery... Nothing happens when I press On button.
Vish2
  • 74 Answers
SOURCE: Canon powershot sd750
The AC adapter for the battery charger shoud work from 110V-240V with auto detection for voltage. Look at the marking on the AC adapter and the input voltage should show 110V-240V. Once you verify this, the charger will work on 220V and you will only need the outlet adapter.
Posted on Jan 18, 2008
futureloginn
  • 734 Answers
SOURCE: Canon powershot SD750 will not turn on.
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Posted on Dec 04, 2008
mannforever
  • 23 Answers
SOURCE: Camera will not turn on. Battery fully charged;
You can give it to an expert for repair, he can repair it for less as there must be just a fuse problem, which can be fixed for a very less amount.
Posted on Aug 11, 2009
  • 28 Answers
SOURCE: I just dropped my Canon SD750 and now it won't
I had a Cannon EasyShare CX7000 many years ago, had the same problem exactly, Canon cameras are not that durable when it comes to dropping it, but I have a Cannon Powershot SD1000 and I have dropped it numerous times and it still functions like it's new. three words REPLACE YOUR CAMERA. oh, and there is no reset button, you are out of luck
Posted on Aug 16, 2009
  • 906 Answers
SOURCE: I have a Canon PowerShot SD750. I dropped it and
If this is the case, the camera might have internal damage. Might be better to send it back to Canon delears/shop for repair. Please try below link
Canon
Posted on Jul 27, 2010
My nokia 5310 wont turn on or charge. I was updating it via my pc when the battery fell out and now it just wont turn on. i tried charging it but nothing happens. Please help!
Charge ur battery with any other phone, after ffilling ful,
then
press green button(call)+*+3
then insert the batter(pressing these button)
May 09, 2010 | Nokia 5310 Cellular Phone
SD750 not turning on
Did you reolaced battery that evening, if you did then try holding the battery door tight and the turn it on. If this will solve it it means that there is a play in battery door that happens very often if someone is not careful enough while replacing battery or merory card.
Sep 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Aug 10, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
My camera wont turn on
have you tried charging up the battery pack? If you have and the camera still will not turn on, you may have a bad battery pack.
Jun 24, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon powershot dosnt turn on
your camera has one of two issues.
  1. blown fuse this requires micro serface mount soldering.
  2. bad battery door switch
if you can not repair this or reather a shop do it we charge 75.00 plus shipping to fix it for you.
This is only a good price if their is no water damage and no lights come on at all.
Diagnosis is free.
Dec 30, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Hi
Nov 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Hi
Could be a couple different things. Was the camera dropped or exposed to liquid? If so it may be a problem that needs repair by replacing the damaged parts.
One thing for you to try is to find the small battery door switch beside the memory card slot, is it damaged or missing? Without this switch the camera will not turn on. Put in the battery and with the door open press down the switch gently with a pencil. Now press the power button... does it power?
If it's not that switch then it's most likely the fuse which has shorted out. If you can solder well then you can replace the fuse, they are pretty cheap to buy. Another option is to buy a defective camera online and make one good camera from the two.
If that's not an option you can have somebody repair it for you. If its out of warranty Canon will want $150+ to do it.
DONT throw it in the trash! It's still worth money even if you don't want to repair it, sell it online or sell it to us; we are a digital camera repair business (Google: Darntoothysam com) and would buy it for parts if we can't get the parts to fix it for you.
Hope this helps
Good luck from Darntoothysam com: Affordable digital camera repair
Thomas
Oct 19, 2008 | HP Photosmart M22 Digital Camera
My Camera will not turn on I have a Canon PowerShot SD750 Digital Elph. About 2 weeks ago, it stopped working and just randomly would not turn on. The strange part is, I had just used it about an hour...
hi emery,I guess the batteries are drained out in the camera.So just take out the memory card if u r using any.....and then try replacing the batteries.Turn ON the camera only with the batteries in.Check if its working fine.....If yes then use a different card.If no then plz get back to me.
Sep 10, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Won't turn on
Are you sure the battery is back in the right direction? If it is, try holding the power button down longer than usuall. If none of this works then it might have some internal damage.
May 12, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
81 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
