No sound otherwise all OK. Using AWA stb 237
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please reset the TV by unplugging the power cord for more than 4 hours and plug it back in. Now check that the sound is coming normally from the set. You’ll need to also check these parts---
Breakdown or overheating of some components of amplifier, wiring, speakers, function settings, power supply and sound detector inside the signal IC processors are fine.
Go to the on-screen-display and make sure you are set for stereo audio. Please check that the on screen display is set up for internal speakers and stereo audio. Also, check any other settings that may have gotten disturbed accidentally. Make sure that all the settings are correct and that the internal switch on the back is set right. Use headphones and check if you’re getting sound through them. You’ll need to check that the issue is with the speakers, wiring or the amplifiers.
If still the issue is not resolved then check the audio chips are fine. If you’re using RCA cables then switch to HDMI and vice-versa.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 08, 2010
How do I connect my hi sense hl19k16l/c141 to a awa dp644 DVDs player to get Dalby 5.1 sound? I can get music but no voice for people in a movie. Philip
An HDMI cable would be good if you have the ports for it. That's simple otherwise an optic cable from sound to TV a coaxial cable is good. Just wire it as output from TV to input on sound system
Mar 06, 2017 | Televison & Video
Phillips Universal remote SRP2008b/86 will not operate my AWA DP239 DVD player even though there is an awa code listed.
Try using code search. Also, Philips may be able to provide a code as code lists are sometimes updated.
Nov 13, 2013 | Televison & Video
Akko
http://www.awa.com.au/AIKO---Set-Top-Box/default.aspx
You can download the manual here. The factory reset is within. If you don't find it, let us know I will tell you how. Best to look for yourself as your set top is a diff one than mine and I want to be sure.
Jun 10, 2013 | Computers & Internet
No sound or picture
No picture - No sound. In otherwise the set is dead. Start troubleshoot from power supply regulator section. If you are not handy, seek tech support.
Jun 25, 2012 | Televison & Video
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
AWA STB 262 doesn't work properly
bennoanddash
With all receivers, depending upon the type cable going from the receiver to the TV, the TV is set either to a channel or an input setting (if using any cable other than a coax cable). I hope this helps.
Ray Calo
DISH Network
Nov 07, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Unable to rescan channels AWA STB 262 set top box.Need to scan for lates channels. Menu button not working. AWA HD Digital Terrestrial Receiver Model STB 262
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
Sep 01, 2009 | Televison & Video
I own a Go-Video DVD-VCR Player, Model DV3140. I recently switched to Verizon service and find that I can no longer olay my DVDs/VCRs with the Fios System. Can you assist me in how to program my player...
Hi
You can reprogram it by following these instructions--
Power turns on or off both your STB and TV when you are in STB mode. (If you have a DVR STB, the DVR will continue to record scheduled programs when off.) However, you can reprogram how the Power Key works. If you want the Power Key to control multiple devices at once --
1. Press and hold the STB key.
2. While holding down the STB key, press OK.
3. Release both keys. The Device Keys will blink twice.
4. Press 9 - 7 - 7. The STB key will blink twice.
5. One after the other, press each Device Key you want the Power Key to control, in the order you want them to turn on or off. Each selected device Key will blink twice after it is pressed.
6. Press OK when done. The STB key will blink three times to indicate success in programming.
For example, to program the Power Key to turn on or off your TV, AUX and
STB, in that order with one press of the Power Key, press [STB+OK], [9-7-7],
[TV], [AUX], [STB], [OK].
These are the codes for GO Video DVD Player--
Go Video 0771, 0768, 0810, 0896, 1071, 1102, 1185, 1757
You can view/download the manual for the fios from this link--
Verizon fios remote programming
You can visit this link for more information--
Verizon FiOS Troubleshooting
If you want to doanload the user manual for your verizon set top box you can get it from here
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Televison & Video
AWA set top box STB232 connected to Panasonic LCD
Loss of sound is often a SCART connection problem. Check that the SCARTS are pushed in securely. Or if the SCART is old, it may be faulty. Try a newer one, or one that you know is definitely ok.
Mar 21, 2009 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
