Question about Sony DRX-710UL DVD±RW Dual Layer Burner
Won't burn CD-r or DVD-R
When I try to receord a CD-R or a DVD-R, the following message pops up:
Please insert an empty disc to write to...
Disc required for compilation: CD-R/RW
Disc type in the recorder: (Empty)
  • 2 more comments
  • Johnbug May 24, 2008
  • Anonymous Jul 26, 2008
    it will not burn dvd-r
  • Anonymous Jan 11, 2009
    Worked once upon a time, now doesn't even recognize any disk in it.
  • Anonymous Jan 26, 2009
    It Says To Insert A Disk when There is One In There
This problem typically occurs when someone downloads Nero, and then uninstalls it, using one of the Nero Clean tools. I've been looking forever to find a way to get my CD Burning capability back and am getting ready to re-install windows unless someone can point me in the right direction.
Posted on Aug 11, 2008
    Genius:
  • 1,019 Answers
make sure that your program that is setup to record. i.e nero-img burn et,c. is set to look at the drive D:- Or E:- whichever letter your drive is assigned by the computer.
Also try using a different Blank-media. if any disk has failed a full write, without finalizing Or creating the Table Of Contents. It will read as Empty Or Blank. you can see This By looking carefully at the underside of the Disk, to see whether it has been burned by the laset. ( Towards The Centre ) if the Dye is darker on the inner-edge, then this is possible.
You can also try using a different Packet writing software, or re-install the program.
Hope this helps.
Mike @ Compurepair.
Posted on Feb 22, 2008
Cd's appear to burn but do not play
change your burn software and file formats /if there are music files/
Apr 24, 2012 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Can't play CD's
The laser lens in your player might be dirty or failing.
Try the following solutions:
Clean the laser lens with a DVD player lense cleaning disc.
Lense cleaning discs are available at many electronics retail store and websites.
Jun 15, 2008 | Philips FWC399 CD Shelf System
Disc drive no longer reads discs, when trying to burn error "please insert empty disc" pops every time, regardless of CD inserted.
Assuming you have already tried a cleaning kit, the unit has probably burnt out the laser and will need replaced. Luckily new DVD+R burners can be found for less than $25.
Mar 17, 2010 | Dell Dimension E310 PC Desktop
How do you burn a cd on this notebook?
  1. Insert a writeable CD or DVD into your computer's CD or DVD recorder.
  2. In the dialog box that appears, click Burn files to data disc.
  3. In the Burn a Disc dialog box, type a name for this disc, and then click Next.
    It might take several minutes for the disc to be formatted in the default Live File System format. When the formatting is complete, an empty disc folder opens.
  4. Open the folder that contains the files you want to burn, and then drag the files into the empty disc folder.
    cdb4d559-8825-47a1-8175-79020965d91c.pngYou can copy files to the disc folder by dragging them to the disc icon or to an open disc folder As you drag files into the disc folder, they are copied automatically to the disc.
But I recommend you to use any CD or DVD burning software like Nero, BurnAware etc. There are lots of free burning tools available on Internet too.
Why I recommend third party software is because you can select burn speed plus minimum disc burning error.
Feb 02, 2010 | Toshiba Qosmio F45-AV412 Notebook
Cd disc drive on Toshiba laptop pops open when i try to burn disc
Please make sure you have enough space available on your disc.Please switch to a new empty disc and let me know if you get the same error.Before trying with a new disc restart your laptop and then burn with the new disc.
Thank you.
Aug 13, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
VGC-RB30 DVD/CDR DRIVE
You actually perhaps using a non blank disc at that time. Burners don't really accept non writeable Discs. Check your CD first before burning. If you are using a rewriteable disc (CD-rw) that has files, it can burn and files will be overwritten but if you're just using a CD-r with files in it, the burner will eject and will tell you to insert a blank disc.
Dec 22, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
It doesnt work
The disc type is not correct, cd or dvd or blu ray or cdrw. The new disc in not empty for burning or its not empty.
Worst, the laser head is busted, it can't read disc inserted so it ejects thinking it is reading the other side but not.
please vote. thanks.
Oct 27, 2017 | Hitachi DZ-MV230A DVD Camcorder
Target Disc not Empty!!!
I have a DVD/CD duplcator, yes I can burn a CD, but when I try to burn a DVD I get this message TARGET DRIVE NOT READY, what can I do?
Nov 26, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
No Disc inserted or drive not ready, please try again
Setup Nero for CD recording mode, not DVD. The software does not change automatically.
Dec 09, 2007 | Sony VRD-VC10 DVD±RW Dual Layer...
Sony DRX-710UL DVD±RW Dual Layer Burner Logo
1,007 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
