Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
I need manuals for my carpet steamer - Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
    Novelist:
  • 171 Answers
Hi there its SmartAlec from NelsonVacuums.com.au. Judging buy the picture in your query you have a bissell. Lucky for you they have most of their user manuals online at bissell.com.au. Just type in your model to the search bar there and you should get access to all the information you need.
Happy Vacuuming!
Posted on Feb 08, 2010
Do I need to use any cleaning agent inside my steamer or spray it on top of the carpet then steam it
Steam cleaning is supposed to mostly eliminate the need for chemicals.
I suggest you check the steamer instructions or contact their customer service for advice before testing a small area of carpet for colour fastness that is usually hidden.
Nov 10, 2016 | Top Vacuums
Hoover spinscrub
I would be careful in mixing solutions with different machines. The steamer carpet cleaner applies the cleaning solution differently than the spin scrub. If anything, I would delude the solution before using it in the shampooer. The steamer automatically deludes the solution, the scrubber directly applies a thick coat.
Elisa Jed ' http://www.babayans.com/en/
May 01, 2014 | Vacuums
Would like to remove urine stains on carpet with steamer. Do not have any instructions. Please help
You should not try to remove the stains with the steamer. Removing stains with a steamer can cause a chemical reaction that will bond the urine to the carpet.
Mar 15, 2010 | Electrolux Envirosteamer 370A Canister...
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
How do you use on carpet
There is an open rectangular glider that the steamer sits on. It does not come with all models. You can by it from Shark.
Jul 26, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
Bissell 1697W power steamer
I JUST PURCHASED A NEW BISSELL CARPET CLEANER AND THERES NO INSTRUCTIONS IN MY BOOK AS TO HOW MUCH CLEANER TO USE, IT SAYS ON THE BOTTLE OF CLEANER THAT CAME WITH IT,IT SAYS TO ADD 5OZ.OF CLEANER TO EACH GALLON OF HOT TAP WATER
Apr 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
112 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
