Question about Toshiba Satellite A100-S8111TD Notebook
I'm looking for a power button ribbon cable for laptop toshiba satellite A100 my email: brouphael@hotmail.com
  • 44 Answers
I just had a friend needing on of these for a P100. She got one from Toshiba. Call them and make sure you are very careful in explaining exactly what you need. You can try ebay, but to my surprise they did not have one when I was looking for it.
Posted on Feb 08, 2010
Where do I find the part number for the motherboard
Look near the memory slots. You will see labels. Also look all inside the board for labels. Write down the numbers you see on your motherboard. Then get on Ebay and look for motherboards for your laptop. The board on ebay will have model numbers on them, look for a number that matches what you wrote down.
Below is a link to the motherboards I found on eBay for Toshiba Satellite A100.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+A100+motherboard&_sacat=See-All-Categories
Below is a link for the A105 motherboards
http://www.ebay.com/sch/i.html?_nkw=Toshiba+Satellite+A105+motherboard&_sacat=0&_odkw=Toshiba+Satellite+A100+motherboard&_osacat=0&_from=R40
May 13, 2012 | Toshiba Satellite A100 A105 Series Laptop...
What did toschiba satelite 8100 lap top model number psaane/03j02gen transpose to
The Model Name and Model Number is Satellite A100-033.
It's one of the Satellite A100 series of Notebook PC's.
http://icecat.com.ua/en/p/toshiba/psaane-03j02gen/notebooks-laptops-satellite-a100-033-796649.html
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
2) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
3) Free Service Manual for the Toshiba Satellite A100 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the line that starts with Satellite A10. Scroll across, and click on A100.
This is a PDF file.
It may take up to 30 seconds before the first page comes up. It may also take additional time to fully download
{Service Manual for your daughter's laptop. I gave a solution to another one of your posted problems}
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 17, 2011 | Toshiba Computers & Internet
How do I remove and replace the keyboard on my satelite A 120 laptop. Can I have some instructions please.
Step one: Remove the two screws from the bottom of the computer that are holding down the Toshiba Satellite A100-S8111TD Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Toshiba Satellite A100-S8111TD Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Toshiba Laptop Keyboard.
Final step: To insert the new Toshiba Satellite A100-S8111TD Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Toshiba Satellite A100-S8111TD Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Regards,
G33k
May 09, 2011 | Toshiba Satellite A100-S8111TD Notebook
KEYS 9, O, L, AND . CANNOT BE PRESSED IN LOWER CASE.HOW TO REPAIR?
This sounds like a problem with the keyboard itself. Laptop keyboards are somewhat difficult to repair. However, fortunately they're usually easy to replace.
I found a new keyboard for your pc on ebay at the following address:
http://shop.ebay.com/i.html?_nkw=Toshiba+Satellite+A100-S2311TD+keyboard&_sacat=0&_odkw=Toshiba+Satellite+A100-S2311TD+PC+Notebook+keyboard&_osacat=0&_trksid=p3286.c0.m270.l1313
Generally laptop keyboards can be swapped out by prying off the plastic trim at the top of the keyboard. It's usually just snapped into place. This will typically reveal several screws holding down the keyboard. Remove these screws and carefully lift out the old keyboard. You'll see a ribbon cable coming off the back of the keyboard and plugging into a socket. Remove this cable. Sometime this is done by just pulling up on the connector and sometimes there
Sep 28, 2010 | Toshiba Satellite A100-S2311TD Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
How do I manually reset Toshiba Satellite A100 Bios Password??
press the power button at once and you remove the hand
May 16, 2009 | Computers & Internet
Toshiba a100-psaakl
Please let us know what your operating system is
Jan 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Display driver
select portables, satellite from this link put the proper type of your laptop and get the video driver.
Regards
Dec 30, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
