Question about Omega MARS-22 Remote Vehicle Starter with Keyless Entry
Alarm goes off when loud car is near - Omega MARS-22 Remote Vehicle Starter with Keyless Entry
  • 171 Answers
The shock sensor is to sensitive, you need to adjust it from MAX to MIN move one point and try it knocking the car body if is still to sensitive move one more point until you desire is good, just don’t leave it to the MIN because if some one attempt your car braking the window the shock sensor is not going to act, but if you like to leave it to the MIN you’ll need to install a glass sensor for a better car anti theft protection.
Posted on Feb 08, 2010
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
What is the tdc? I have no idea where it is located!
what is tdc,
tdc is or means TOP DEAD CENTER, on engine timing terms.
about the alarm, European models cars may be set different than American cars. but if the are the same and this es a original alarm from the actuary, i suspect that is very little you can do, it is posible that you park somewhere were the terrain trembles, like a train near by, or the vehicle is exposed to high winds and shakes, or parking to close to other cars or cars that constantly moving, or near the highway were trucks go by, sacking and moving will make the alarm go off.
Mar 04, 2014 | 2005 Renault Megane 1.6
Tire pressure light remains on and loud alarm goes off on 2003 pathfinder
Your owners manual should have a troubleshooting chapter. It also has codes many times for tire pressure causing lights to go on.
Oct 13, 2017 | 2003 Nissan Pathfinder
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
Car alarm goes off by loud noise
Hi Scott, If the alarm is an after sales unit it has a knock sensor fitted which has an adjustable sensitivity. ask your dealer where it has been installed and then lower the adjustment. Regards John
Feb 08, 2013 | 2008 Toyota Prius
Car alarm goes off when in the heat for more than 6 hours, and when loud cars go by,
Its the sensitivity adjustment on the alarm, its now out of range, either it be adjusted or replaced, your looking at an adjustment why because the heat,
Apr 27, 2011 | Pontiac Grand Prix Cars & Trucks
My 2003 ford explorer, alarm goes off for no reason, horn blowing, light flashing. help
Adjust the sensitivity of the alarm system.
It may be too sensitive and is being set off by the glass breaking sensors.
loud noises usually set this off if it is too sensative.
Mar 10, 2010 | 1998 Ford Windstar
Alarm Malfunctioning - 2004 Sable
Have your battery checked for shorts. Mine was defective on a new Lincoln. Same problem. Even sat in it at 18 degrees one night to appease neighbors whom my alarm woke up.
Check connections at every possible point if the battery tests good.
Get up 30 minutes before alarm usually goes off and see if neighbor has loud car or slams his car door. Motion sensors can set it off too.
Aug 17, 2009 | 1998 Mercury Sable
Car alarm
you would need to conntact the dealer it should run you around 30.00 for a new clicker takes 3 secs to set up the new one
Dec 05, 2008 | 2000 Honda Accord
Omega MARS-22 Remote Vehicle Starter with Keyless Entry Logo
79 people viewed this question
Top Omega Juicers Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Omega Juicers Vehicle Part and Accessory Expert? Answer questions, earn points and help others
