We have been experiencing a black square that just seems to appear out of nowhere. We think it may have something to do with the parental control block or rating system. This is quite frustrating as we have nearly memorized the menu format trying to figure out whether we have done something wrong..
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If it is a black box in the middle of the screen it is caused by one of two things:
1) In the customer menu under closed captions SCROLL through the options and make sure TEXT is not highlighted---text was designed so written material could be broadcast but it never really took off--if text is highlighted simply choose either OFF or something other than Text 1 (there are usually text 1-4 available but text one should be the only active one).
2) If you are using a cable or satellite box it may have the same option in its menu----the text box could be coming either from the TV or from the Box that is giving it signal.
Usually the box will only appear on certain channels like PBS---if you see it on some channels but not others it will likely be the setting in the set---if on all channels more likely from the box.
Let me know what you find.
SD TECH
Posted on Feb 08, 2010
Turning off the parental controls on RCA projection T V's
It seems you have answered your own question, I have noted and archived it--for future use to help others.
Dec 04, 2012 | RCA Televison & Video
After the tv is tuned to a new channel, a black square appears over the majority of the screen. The Direct TV tech said that it was a parental control feature that needed to be reset
Actually, your TV's closed-captioning is turned on and it's set to "text" mode. This causes the set to blank out the area where the text would go if there was any. Most remote controls have a single button to turn captioning on, so it's easy to get into this mode without knowing it. Press that button or use the TV menu to go through the caption settings to turn them off, and the box should go away. (Parental controls don't just blank out a part of the screen; they disable the channel completely. I hate it when a technician won't say "I don't know" and then gives out wrong information.)
Jan 01, 2011 | Philips 27PT9007D 27" TV
The TV is a Mitsubishi CS-26201C to the extent it matters and the remote is the original remote. A small child played with the remote and now a black square pops up and covers vitrtually the entire screen...
The child managed to press the button on the remote that controls closed-captioning, and now the TV is set for "text" mode. I don't remember if the button says "caption" or "cc", but it's one of those or something very similar. Press the button again to go through the settings until you get back to "off" and the box will be gone.
What's happening is that in text mode, the TV blacks out the area where the text would go. If there isn't any, the result is that mysterious black square. It may not show up at all on some channels, or only during some programs. It depends on whether captioning is being broadcast. Since many TV remotes have a single button to control caption settings, it's easy to get into this mode without realizing it. But it's easy to fix.
Hope this helps! Thanks for using Fixya.
Nov 06, 2010 | Mitsubishi CS-26201 TV
Black Box appearing on my screen
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Check the closed caption feature in the menu setup. Consult the instruction manual about closed caption, or call the manufacture tech support.
What is probably activated is the closed caption bulletin board feature, and the station you are tuned to has the board up but with nothing on it. They use these to put text messages mainly for programming schedules and notifications.
Jerry G.
Apr 13, 2008 | Insignia IS-LCDTV32 32 in. Television
Black square (parental Control??)
You'll have to go into the menu setting of the VCR and turn the controls off, also you can try completely unplugging the VCR and then plugging it back in again to see if it goes away.
Feb 10, 2008 | Curtis DVD-7600 DVD Player/VCR
Jvc #av32950-big black blockout type square appeared on the screen& won't o away . it's like a parental control thing..but checked that . any clue??
Here's some thoughts I have:
1. Unplug the set and wait a minute, then plug it back in.
2. Could it be coming from your cable box? Try playing a dvd or vcr tape and see if it's still there.
Geno
Jan 24, 2008 | JVC AV-32950 TV
A black square on my tv
That when you enabled the Parental Control ON. Try to turn it off. But you need the 4 digit code do that. And if you dont know try to call 800 company number and ask how to reset the TV for factury default. Good luck Hope this may help you Pls. rate me
Aug 07, 2007 | Nikon MC-EU1 LCD Remote Control
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
