Question about Maytag Neptune MDE5500AY Electric Dryer
One of the paddles is loose and im not sure how to get the top poped up
  • Maytag Master
  • 2,694 Answers
Unplug the dryer,open the door,take out the four screws,2 holding the door and the other 2 opposite the door screws,remove the door and pull the front off, you should be able to get at the loose screws down in the right hand corner,if you want to open the top take out the screws on top and remove the brackets that hold the side and the top together
Posted on Feb 08, 2010
Testimonial: "alittle late but it was excatly what i did thank you"
Remove loose change from washing machine
Depends where the loose change is? Some times it caught between the middle paddle and the basket.Tthat I just use a small flat tip screw driver and finger, trap it and lift carefully out. If the coins are underneath the basket then its more involved. First, tape the door down and lift top cap and prop up aside. Then remove tubs cap off of tub. Next inside basket in the center, remove center cap off of paddle. Then remove bolt from center. Remove paddle." This I use a screw driver small enough to fit in paddle holes, one on each side to lift equally,back and forth." You will find six phillips head screws under paddle you need to remove. This should be able to lift the basket out. Walla!! T
here's the bottom of the tub and anything lying there should be removed. If you want to really inspect it there are two 5/16th head screws that hold a protective plastic plate that should be removed and checked sense your there any ways. good luck to you and hope this helps.
Feb 21, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
I have a new paddle light switch im trying to install and for some reason it keeps poping the breaker. im wondering if im installing it correctly
make sure you are hooking up the correct color wires to it main wire on top of switch, bottom wire of switch other color wire they should be blackor any other color , just dont hook up the white wire to it this will make your breaker pop , If your copper is touching any metal this will make it pop also,good luck
Jul 29, 2011 | Cooper Industries Cooper Wiring: Single...
It's like the motor is going in slow motion when kneading...only about 10 min into the process too...then it simply doesn't turn anymore, like the dough is too stiff or heavy to move...
Hi, It could be a few things. It could be the paddle is sticking. Take the pan and paddle out of the machine and see if you can spin the paddle freely by hand. If it spins freely that is great. If it sticks then the sealed bearing that the paddle rotates in is failing. If everything is okay, then the belt is slipping and is too loose or is worn out. The dough gets thicker and requires more work for the belt. If the belt is loose then the paddle won't turn. The belt and motor is located in the base of the machine. Be sure to unplug before you check this out. Also, make sure the pan is installed correctly in the machine. Good luck...Hank
Nov 29, 2010 | Regal Ware K6725 Kitchen Pro Bread Maker
I have a Maytag MD55 dryter and one of the paddles
You remove the door screws with the triangular plastic plates and screws for the door on the opposite side. pull front forward and down. Remove the two bolts at top corners to raise top (unplug machine of course). screws are on outside of drum. When reassembling, make sure that the right screws go with the right area (The wider screws go in the triangular plates and the thinner go in the door) Make sure the door hinges are put in their grooves before reinserting the front.
May 14, 2010 | Dryers
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Loose paddle
Pop the top ... remove the front ... carefully remove the belt ... take the drumout - you are correct, the paddles are held onwith screws - tighten them.
reassemble
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the paddles inside the dryer has come loose, how can I fix this?
remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Jun 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Fin / paddle has come loose in the drum.
The paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
if its loose you may need to replace it, they are available as a spare part and come with instructions. you will need to varify which version you have by counting the bumps on the end of the padle, should be 2 or 3.
basically you put a small screwdriver down on of the holes in the top of the paddle, i think the 3rd one, to push the metal drum tab down enough to be able to pull the paddle towards you and out of it's slots. carefull not to push the tab down too far as it will bend inside the drum and isd pain to bend back again.
Any further help, Let me know.
Thanks for using Fixya.
Do rate the solution 'Fixya" if 100% satisfied.
Apr 30, 2009 | Washing Machines
Loose Paddle in the Drum
not the right method, the paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
Feb 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Dryer Paddle Loose
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
This should allow you to access the tumbler.
Dec 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
63 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
