Question about ASUS P5V800-MX Motherboard
When i plug the cpu it instantly turn on, no display, can't turn off the cpu holding the power button, might be a board problem?
  • 728 Answers
I don't know how computer technical you are, but it sounds like you knw a thing or two about them. So here's the best way to find the problem:
There could be many things that could stop the board from fully booting, Determining what is wrong is like detective work. What I do, is open up the case and take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd, harddrive or otherwise) the CPU, a graphics card (only if required) and one bank of memory. (which is not required, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. If your going to load a ide drive, make sure you set your pin setting correctly on it, meaning the drive (IDE or EIDE) your putting on the board is set to Master, or Cable Select if your using the cable placement method.
Now, turn it on, and you should get the power supply on, and the cpu fan going. If they start, then make the next step to have the single drive be your hard drive, and see if it boots. If it boots, then great, open Bios and make sure Bios is reading the board and all things are fine with it. If so, what ever you put on next make sure it one at a time so you can identify what it doesn't like.
In the case where the CPU or power supply don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card (if required) or the motherboard.
The next step is to replace each one of the first five, starting with the Ram Chip, put another like chip in and see the results. Then do the same thing to each of the remaining 4 components, the graphics card (if required), then the drive(cd, harddrive or otherwise), on to the CPU, and last the power supply. Hopefully something will show it's ugly way to make a change. Also, on the drive (IDE, EIDE or SATA) , try a different cable to make sure it's not that,
Now If no changes happen after all that, then I take it one step futher and usually get a like (doesn't have to be exactly the same, but a board that the components can be tested on) motherboard that I can test the first four, and make sure that they really work. If after that and you have tested all of the components and they all work, then it's save to say you have a bad Board my friend. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Good Luck
Mark
Posted on Feb 08, 2010
Push power button and the power light turns amber and lights up then shuts off. the light in back of the computer is light green and it starts to turn on then dies
The fact that ity is trying to start and shuts off after ..it seams that it is the CPU fan to blame ...If the fan fails to start the CPU will turn the computer down instantly due to the temperature limit ..(in 1 or 2 sec ) ..
so ...open it up ..and see if the fan is spinning ...on start ..and if it is not ...check the connection with the board or replace it ..
(by the way ..this may also be a CPU failure ..and need another one ) ..
Aug 31, 2011 | Dell Inspiron 518 Desktop Computer
Tip
Computer turns ON but there is no display?
Drain it! You might be surprised that one day as you turn your computer on, it shows no display. It can be caused by electrical charges on the motherboard, I do not specifically know how it affects the display but in case this happens to you try to do a Power Drain. It's easy, first, take the battery out from the laptop and unplug the AC Adapter if it is connected(for desktops, unplug power cord from the CPU/tower) then press and hold the power button down for at least 30 seconds. plug power supply back into your system and turn it back on. There goes your display once again.
on Sep 15, 2010 | Computers & Internet
My cpu is not shutting down even i shut down. But my monitor showing shuttingdown and display is turning off as if like the system is shut down Still cpu is running. and also my monitor is not turning on...
Shut down by holding in Power button for 5 secs... press F8 continuously on start up, go into Safe Mode with Networking.. have a look around at some of the Devices in Device Manager, check Drivers, also default to normal mode in Bios/Uefi
Aug 13, 2017 | ASUS M2N-MX Motherboard
Laptop won't turn on
try separating the laptops battery for 8 Hrs to let the mother board discharge and cleaning the mother board and memory slots and cpu socket with the air blower
Mar 21, 2010 | Office Equipment & Supplies
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Turns on, cd light comes on but cpu does not boot and light does not come on, the monitor says "no signal" . Cpu dpes not shut off at the button anymore. I have to unplug it to turn it off. HELP! By the...
You should get it repaired. That is likely a power supply failure. Yes, I see you have power, but I still say power supply, because there are 2 types of power: There is Motherboard power and there is CPU power. If CPU power is not correctly flowing, the CPU will not activate. If the CPU is not active, the board will not process any information, even though the board is receiving power. Power supplies are not hard to replace and are usually about 40 bucks
Oct 01, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Turns on, then shuts down before anything shows on monitor
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Monitor won't turn on
The inverter power supply logic board has probably goe out. You can get it here or have it fixed.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
Mar 30, 2008 | Dell E176FP 17" LCD Monitor
Intel Mother Board D845WN
Seems there is a loose wire, loose card, motherboard failure or mis-plugged wire. IS everything in right?
Nov 09, 2007 | Intel Desktop Board D845WN Motherboard
ASUS P5V800-MX Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
