Question about Microsoft Windows XP Home Edition
Low virtual memory
Minimum virtual memory low, keeps poping up on screen. I have 224mb ram. What is best settings for initial and max memory? I play alot of games and watch tv online? My computer becomes really slow and it freezes up.
  • 111 Answers
Ok let me help you, hopefully you have atleast 2GB of hard drive space left.
Step 1: Double-click Control Panel
Step 2: Double-click System
Step 3: Click on the advanced Tab
Step 4: Click the "Settings" button under Performance
Step 5: Under Performance options Click on the Advanced Tab
Step 6: Click "Change" under Virtual Memory
Step 7: Select Custom Size, ( if custome size is grayed out uncheck Automaticall manage paging...)
Step 8: Change Custom Size to 2048, if you have more than 3 Gigabytes on your harddrive available, change the custom size to 3072.
Step 9: Hit the "Set" button then "ok"
You may need to restart your computer after this is complete.
This is really just a temporary fix. I would suggest purchasing more Ram for your computer. If you would like you may reply to this message with the make and model of your computer and I will gladly look up what you need to upgrade.
Posted on Feb 08, 2010
  • 742 Answers
Let Windows manage your memory and other resource allocation to provide you the best performance of your computer. If this "best performance" suggestion by Windows makes no good effects, then you have to consider upgrading your hardware.
To let windows give you the settings for best performance, try this:
1. Right click on My Computer icon on your desktop and click "Properties"
2. Click the "Advance Tab" and under the "Performance" group, click the "Settings" button.
3. In the dialog box that pops up, click on "Adjust for best performance" option.
My pc is running low on virtual memory when i use the internet
In general, you want to set your minimum virtual memory to about 3 times the total amount of memory installed in the machine.(3072MB for each gig of ram) The maximum should be 4096 more than the minimum setting.
To check this, right-click on "My Computer" and choose "Properties". Click on the "Advanced" tab and click the "Settings" button in the "Performance" section. On the "Performance Options" panel, click the "Advanced" tab. The virtual memory button is at the bottom (on xp machines). Selcect "custom" and then set the values according to how much ram you have in the machine. For more, check here.
http://www.thermwood.com/forums/viewtopic.php?f=3&t=897&hilit=virtual+memory
Oct 08, 2011 | Computers & Internet
Tip
How to solve low memory problems? Normally this warning message shows when you...
Normally this warning message shows when you run many programs same time than the RAM installed on your computer is designed to support. Your can solve this problem by increasing the system paging file size also called as virtual memory. Using this virtual memory windows moving information to and from the paging file for fast processing. This will free up enough RAM for other programs to run properly.
To increase the system page file follow the give path:
Control Panel > System > Advanced > Click on Settings (Under Performance) > Advanced > Change
Here under Drive (Volume label), you have option to select any of your hard disk drive, but the best choice is, select any drive other than C drive for virtual memory.
Set the double Initial & Maximum Size of your Virtual Memory. Here set initial size 700 MB and maximum size up to 1000MB; you can change this size according to the free space available on your hard drive.
on Apr 08, 2010 | Computers & Internet
Tip
Computer Tips: Low Memory Problems
How to solve low memory problems...?
on Mar 08, 2010 | Computers & Internet
I have a game called juiced and When i double click to play it it says ,,Juiced requires virtual memory to be enabled".Can somebody please help me to fix this error and play my game please?I have...
Manually manage computer memory loadTOCNode(3, 'moreinformation'); When your computer's physically installed random-access memory (RAM) is running low, Windows adds available memory by using a paging file, generally known as virtual memory, on the hard disk to simulate physical RAM. By default, the virtual memory paging file that is created during installation is 1.5 times the physical RAM on your computer. Therefore, a computer that has 1GB of installed RAM will have 1.5GB of virtual memory.
You can manually change the size of the paging file to make it larger or smaller. You can also optimize virtual memory use by dividing the file space between multiple drives and by removing allocated space from slow or heavily accessed drives. To optimize your virtual memory space, divide it among as many physical hard drives as possible. When you select drives, follow these guidelines:
  • Try to avoid having a paging file on the same drive as the system files, usually drive C.
  • Avoid putting a paging file on a fault-tolerant drive such as a mirrored volume or a RAID-5 volume. Paging files do not require fault tolerance, and some fault-tolerant computers experience slow data writes because they write data to multiple locations.
  • Do not put multiple paging files on different partitions on the same physical disk drive.
How to manually change the size of the virtual memory paging file loadTOCNode(4, 'moreinformation'); You must be logged on as an administrator or as a member of the administrator's group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
To manually change the size of virtual memory, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then press ENTER.
  2. Click the Advanced tab, and then under Performance click Settings.
  3. Click the Advanced tab, and then under Virtual memory click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
  5. Under Paging file size for selected drive, click Custom size, type a new paging file size in megabytes (MB) in the Initial size (MB) or Maximum size (MB) box, and then click Set.
  6. Click OK to close the dialog box and apply changes.
Note After you change the size of the paging file, you may be prompted to restart Windows. If you are prompted to restart, the changes will not take effect until Windows is restarted.
Notes
  • To have Windows select the best paging file size, click System managed size. The recommended minimum size is the same as 1.5 times the RAM on your computer, and 3 times that figure for the maximum size. For example, if you have 256 MB of RAM, the minimum size is 384 MB, and the maximum size is 1152 MB.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is the same as 1.5 times the RAM on your computer. It is good practice to leave the paging file at its recommended size as performance can decrease if a paging file is too large. However, you may increase its size if you frequently use programs that use lots of memory, such as graphics programs or games.
  • We strongly recommend that you do not disable or delete the paging file because this can lessen the computer's performance. However, if you decide to delete a paging file, set both the initial size and the maximum size to zero, or click No paging file.
How to manually optimize the memory usage loadTOCNode(4, 'moreinformation'); You can optimize your computer's memory usage to reflect your specific needs. If your computer is used as a workstation instead of as a server, you can increase performance by devoting more memory to your programs. Your programs will work faster and the system cache size will remain the default size that was included with Windows XP. Or, you can set aside more computer memory for a larger system cache if your computer is used primarily as a server, or if you use programs that require a large system cache.
  3. Click the Advanced tab, and then under Memory usage use one of the following methods:
    • Click Programs if you use your computer primarily as a workstation instead of as a server. This option allocates more memory to your programs.
    • Click System cache if your computer is used primarily as a server or if you use programs that use a large system cache.
  4. Click OK to save preferences and close the dialog box.
You may refer to this link http://support.microsoft.com/kb/308417
Apr 18, 2011 | Intel Core 2 Quad Q8200 Computer System...
How do I fix "virtual
Windows managed for the VM May not be the best option. Generally, I have found setting to CUSTOM setting the initial and Max to twice the RAM installed is a happy place for windows.
Jan 22, 2011 | Computers & Internet
When i playing online games on my computer it shows a massage of virtual memory low....and the system go to hang.....hw can i solve ths problem...
Virual memory is an area on the Hardrive that "acts" like memory when your RAM gets too full
If your gaming--its better to increase RAM -but here is how to increase the Virtual memory
Go to START> right-click on MY COMPUTER>PROPERTIES>ADVANCED click on SETTINGS under the Performance area-- then click the ADVANCED tab -and you should see an area to change(increase) your Virtual Memory
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Jan 05, 2011 | Computers & Internet
Old slow computer
First you can increase your virual memory .
Right click on my computer then go to proeprty then go t oadvanced
then settings of peformance
then go to advanced again clik on change set initial size same as your max size then clcik on set then apply and ok.
Aug 23, 2009 | Dell OptiPlex 740 PC Desktop
Virtual memory
The topic of Virtual Memory can be confusing for some folks, but I'll try to explain it as best I can (starting with the basics).
RAM, or, "Random Access Memory", exists in every computer. RAM are actually pieces of hardware (chips) and are used to store temporary data. The temporary data is then used for computation by the CPU (Central Processing Unit) at a later time.
So, for example: when you double click to view a movie file on your computer, it is first loaded into RAM (a chunk at a time), then moved to the CPU (Central Processing Unit) where it is processed and decoded, and eventually output to the screen and sound card. And voila, you have your movie.
RAM is also known as "Primary Memory". Comparatively, Virtual Memory (also known as Secondary Memory or Page Memory) is used in place of Primary Memory, but only if there is no Primary Memory available at the time.
Since Virtual Memory is stored on the hard drive, it is significantly slower than RAM; therefore, virtual memory usage should be avoided whenever possible. To compare: hard drive speeds are measured in Milliseconds (MS) where as RAM speeds are measured in Nanoseconds (NS). Generally speaking, the more RAM a computer has, the faster, or "more optimized" it is -- especially when switching between tasks.
If you are constantly getting the message that your system needs to increase Virtual Memory settings and you're not overworking the PC, I would suspect a memory leak. This is, of course, assuming that you haven't played with your virtual memory settings in Windows (it's best to leave it alone or restore to default).
FIX
look in Control Panel: System, Advanced, Performance, Settings, Advanced, Virtual Memory. I believe it's in a similar location in other versions of Windows.
May 11, 2009 | HP Compaq FS7600 17" CRT Monitor
Virtual Memory Minimum Too Low
Hi!
Here's the procedure on how to increase virtual memory of your PC:
Right click on My Computer > left click on Properties > Advanced > Settings > Advanced. Under Virtual memory left click on Change.
Select (left click) on the Drive on wich Windows XP is installed. In most cases this will be Drive C.
Under Drive:
Space available: Select the radio button labeled: Custom size:
To play it safe, in both the Initial (MB)size: and Maximun size: dialogue boxes type 2560 (i.e. allocate 2.5GB for the pagefile) provided you have the free memory space to spare. If you don't have enough free memory available enter the amount of memory you can spare, and meanwhile seriously consider getting a larger Hard Drive.
Mine is set to 4096MB (4GB), max. allowed by XP. This may seem like quite a lot, but the reason for this is that recent games now require a lot more real and virtual memory to function correctly, even if you have 2GB of RAM. Having a larger pagefile size does not hurt performance as such; it only takes up a bit of additional disk space.
After setting the new page file size left click on
OK > OK > OK. Then restart the computer.
Dec 21, 2008 | Microsoft Windows XP Professional With...
Nintendo DS lite game card
there several steps like these....
may be the virtual memory is low.... you trying increasing virtual memory..
this can be done by following
1. go 2 control panel,system,advanced tab
2. in performance option click settings
3.go to advanced
4. go to virtual memory option there click change select your operating system drive and increase the virtual memory minimum for 700 and max to 900... give ok
and then have check...
if same problem persists may be ram u r using is low upgrade your ram to atleast 512mb ram
or
may be you are using the old version of directx... install latest version of directx ( atleast you install directx9.0c)
or may be operating system problem(may be due virus attack system files have became unstable) try reinstalling it...
Jan 16, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
185 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
