My DVD/CD RW cannot be detected from Windows XP and also from boot manager
    Guru:
  • 161 Answers
In that case there are two things that can be the problem..
1st check your cables.. the SATA if you use sata cables the IDE if you use IDE..
check your power supply cable... you try to change the cables just to make sure they are ok...try to change your IDE/SATA cable..
try to use other power supply cable inside you CPU..
then turn on your computer go to your set check if the CD rom is now appears in the menu..
id not you maybe your cd rom is damage..
for you to know if it is damaged try to connect it in other computer..
i hope i've help you..
Posted on Feb 08, 2010
My DVD player can't detect DVD CD file, but it can play CD. i've tried to check on the device manager and its working properly. i also have tried reinstalling its driver but still not working... i am using...
i have faced this problem in my case DVD was working and cd not you problem is the lens of you cd/dvd drive has become worst and cant work any longer it needs to be replaced. Hopefully it might have helped you.
Jun 19, 2010 | Microsoft Windows XP Professional
Tip
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP Home)
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP) [IDE]
Simple solution:
Situation
There is a yellow exclamation mark for CD/DVD drives in Device Manager. The device status in the properties of the driver might indicate an error code, for example 32, 37, or 39. Or the drive simply does not appear in My Computer or Device Manager.
Solution
To solve the issue, you have to edit the Windows Registry:
Click Start, then Run, type REGEDT32 and click OK.
Locate and then remove the following registry values:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}LowerFilters
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}UpperFilters
Close Registry Editor.
Reboot the system for the changes to take effect.
Note: Some programs are unable to detect the CD/DVD drive after these steps. To solve this, simply re-install the program in question, eg: usually your recording software. Also, in few instances the order in which the programs are (re-)installed can make a difference.
on Sep 12, 2010 | Computers & Internet
My Samsung CD-R/RW TS-H292A won't open so I tried to flash the new firmware (TS04) using sfdnwin but I got an error now my cd writer is totally not working although device manager still detects it. What...
Well at this point you dont have much options try to flash it again but with a new flash file and do it in pure DOS (Not a Dos Box in Windows) you need to boot the system from a Win Win 98 cd or floppy. and then flash from there.
Dec 05, 2008 | Pioneer DVR-107D DVD±RW Burner
Not Reading/writing not even detecting
You need to check the bios on start up. You should have your CD/DVD drive as the first boot device.
Apr 20, 2008 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
Windows doesn't recognize new SATA DVD-RW drive. It has a ? in the Device Manager window in XP, but i cannot find the correct .inf file to satisfy it.
you need to do few things
1. reset the bios so that it starts detecting the drive
2. right click on the option with yellow ? and select uninstall and restart your system
3. remove the upper and lower filters from registry
the path for the same is
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
try booting through this drive using a bootable cd just to check if its not an issue with the DVD RW
i hope these steps help
please let me know in case it does'nt so that i check for further possibilities
Feb 29, 2008 | Computers & Internet
Does not detects boot cd
The other xp installer is not a bootable cd\dvd.
Sep 21, 2007 | Microsoft Windows XP Professional With...
My dvd rw is not detected
When installing SP2 version, you possibly corrupted the drivers for the DVD. It is possible there are different drivers for the DVD between XP and XP (sp2). Go to the laptop mfg website and download the newest drivers for the DVD.
Aug 20, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
