Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water in door freezing - GE (PSS26MSRSS) Side by Side Refrigerator
Check to see if your ice tray has caked ice in the bottom of it. Mine started working again after I cleaned out the ice tray.
Posted on Feb 08, 2010
My freezer is very cold but not freezing water into ice. The door was only partially closed because a towel was in the way but after fixing that it has been 6 hours and it's still not freezing. The...
That really cause the freezer not to freeze water because of that towel. Since you already remove the obstruction, just observe it and it will gonna freeze the water. Be sure that the door gasket magnet has tightly closed freezer door and no cold air is going outside. If there is, again it will takes longer to freeze water into ice.
Just observe and it will gonna go back to normal operation.
Good luck to you.
Jul 03, 2011 | Frigidaire Side By Side Refrigerator 26...
Why does water dispenser stop working? Seems to work fine after thawing freezer for about a day and seems to freeze up. Water line for dispenser routes through the door.
The water is door spigot can be freezing up if the ice door is stuck open. When you actuate your ice in door function you hear a solenoid CLICK. That solenoid is supposed to open the ice door flapper. If the flapper is not funtioning correctly (stuck open) then in as few as as 2 - 3 days your water in door can freeze again. If you want unit specific information we need your make and model number to better help you.
Thanks for hoosing FixYa,
Kelly
Feb 22, 2011 | GE Refrigerators
After you open and close the refrigerator on top, the freezer drawer pops open. it is now leaking water.
check to see if the fridge is tilted back a little so the top door closes with just a little shove,also if there isn't any weight on the freezer door it will pop open,put something on the door,a bottle of water that will freeze or whatever you want,it could be leaking from stuff melting from the door being open, is the water dripping from the door?the door does freeze up and will melt out if door is left open, hopefully your air ducts didin't freeze up,make sure you can feel cold air blowing into the fridge section,if not heat up the back wall where the evap fan motor is with a hair dryer the air ducts are near there and check the freezer ceiling for frozen water droplets,hopefully everything will freeze back up with the door closed.
Jan 28, 2010 | Amana ABB1927DE Bottom Freezer...
The cold water dispencer freezes in my amana bottom freezer refrigerator
The water line runs through the door and this is where it freezes. It's usually defetive insulation. Other than replace the door you may can tape or other wise fasten more insulation to the inside of the door in the area you think it's freezing in.
Aug 26, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
FROFEN WATER LINE ON REFRIGERATOR DOOR
it seems to me that the tubing is not properly insulated in the door causing it to freeze you can open the liner and see if it is inside the insulation or lower your freezer section so it does not over freeze thanks from gilles
Feb 22, 2009 | GE GSS20IEP Side by Side Refrigerator
Doors keep freezing shut in michigan weather
From you description I suspect water is getting into the door latch. Then it freezes and stops the latch from moving properly. The solution is to keep the water out and the best way to do that is to make sure all the rubber seals around the window and door are working properly and in good condition.
Dec 22, 2008 | 1996 Buick Regal Olympic Gold
Water does not dispense from door
I found that the door on the GE side by side doors are not accessable and cannot be repaired if a water line inside the door is defective. The entire door must be replaced at a cost of almost $370. The problem, which seems to be quite common relative to the lack of water at the dispenser, is the result of the water tube in the door freezing due to excess cold levels in the freezing compartment. This is probabley due to poor insulation around the water line as in exits near the ice dispenser gate. The solution is simple, lower the freezing level and use water frequently to keep it from freezing. Also, keep the lines clean by changing the filter often if the local water source is laden with particulates. I think GE should foot the bill for changing doors or re-engineer the doors to access the area where the water line makes contact with the cold surface of the inside panal.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
No Water
You may have a problem with a frozen water line inside the freezer door.  There is a heating element that keeps that water line from freezing but it apparently has failed.  It is not serviceable.  The whole door has to be replaced.
Dec 27, 2007 | LG LRSC26940ST 36" Side-by-Side...
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
97 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
