Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore Elite 795.75546401
The Express Freeze keeps dinging, it is very annoying and doesn't turn off. It just started to do that, it isn't because we tried to use the function. How can I disable it, I have never used the function?
  • 6 more comments
  • GMaGiK Feb 22, 2008
    No, it is a dinging and the light for Express Freeze blinks.
    No, it is a dinging noise and the light under express freeze flashes.
    I assume it must be a signal that the express freeze is on. The book says it is active for 24 hours but we did not push the button, it just started dinging and it has been over 24 hours.
    Turning off the refrid. for an hour didn't work, it is still dinging. I will have to have my husband inspect the fan when he gets home. Thanks
    Just got home from work, and found out the wife had contacted you. You don't have a clue ,pal!
  • GMaGiK Feb 23, 2008
    It seems to me if it were a problem with the fan it would overheat the appliance, not that the Express Freeze would beep intermittantly.
    I would like to know how to disable the sound until I can have a repair person look at it.
    We have been having a snow storm here since Thursday night, I don't think anyone would rush out here, and it has been beeping since Friday morning.
    posted by GMaGiK on Feb 22, 2008Report abuse
    Comment by GMaGiK, posted on Feb 22, 2008
    Comment by GMaGiK, posted on Feb 23, 2008
    I am glad I spent $9.99 for someone to tell me to take my refrigerator to a service center! What a rip off, and you call yourself EXPERTS!
  • 167 Answers
First you need to explain what is problem then make a critic's!
The problem is emitter board it's damage and need's replacement!
good luck
Posted on Feb 26, 2008
  • 871 Answers
Hi there
if any solutions from fixya experts still cant solve your problem, you always have the last resort to bring it to a service center. hope this wont inconvinience you. thanks for using fixya
Posted on Feb 23, 2008
    Genius:
  • 1,665 Answers
Inside the freezer a fan circulates air over the cool tubing and the refrigerant absorbs the heat from the freezer's relatively warmer air.
Check for fan's operation and then remove back of unit and check defrost heater has not become detached.
It may also be a defrost fault (see defrost tube to be clear the only reason it does not flow is due to a restriction).
What can be happen is that the water backs up the drain pipe and then freezes before as water in the external tray can evaporate.
If problem persists it is better to cal a local authorized tech service to inspect the appliance.
Posted on Feb 22, 2008
    Genius:
  • 3,422 Answers
Do you mean that it is making some sort of huming noise?
Waiting for your reply..
  • 3 more comments
  • Priya darshan Feb 22, 2008
    Could you please explain your problem in detail i need more info.
    First try unpluging your refrigerator for 1 hour and then plug it in.i think the problem is with the the emitter/receiver boards, these look fairly simple to replace.
    Here is the contact details of kanmore:
    Main support number :1-800-KENMORE
  • Priya darshan Feb 23, 2008
    Can you please tell me what is the colour of the light which is flashing?
    Is it red or green?
2 Suggested Answers
repairman45
  • 130 Answers
SOURCE: I have a Kenmore Elite
this is caused by one of two problems. The foirst being the water valve will no longer open due to water deposits on the valve. This can very easily be replaced by pulling the unit out from the wall and removing the rear panel using a 1/4 inch socket. The second problem and cheaper of the two is to replace the switch that controls the water valve, both the parts you need can be ordered at Sears, using your model number. Here is a diagram of where the switch is and how it breaks down. Diagram
Posted on Dec 20, 2010
Troubleshooting kenmore refrigerator
how old is your kenmore? sounds like a bad temperature gauge?
Dec 17, 2013 | Refrigerators
My kenmore oasis dryer comes on but doesn't run
The tumbler is belt-driven so it could be a broken or slipped belt. It isn't hard to replace the belt itself but sometimes getting to it can be a real pain. Search online for service manual or diagrams if you want to attempt it yourself.
Oct 05, 2012 | Kenmore Elite Oasis ST 6806 Electric Dryer
Recently, our Kenmore side-by-side refridgerator starting making a very loud humming, almost grinding, noise. It is loud enough to be annoying from another room. After checking this several times, it...
Look under there and see if any junk is blocking the airflow causing the condenser fan motor to howl.You can oil it with zoomspout oil. It is safe for refrigerators. Don't use WD-40 (flammable) Give it a good clean and verify the fan is moving the air down there. Just cleaning it greatly improves airflow and cooling efficiency. Let me know how it does. Give it a day after cleaning.
Aug 08, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore elite dishwasher about 5 years old and it will not start. The clean button keeps blinking green. Tried resetting power and still it will not start.
Makeing sure you have power is my first step.
Ensure the door isn't ajar is another possible fix...(check that door switch.)
Pressing the start / resume button again after these steps are done is all Ive got left.
I hope this helps.
Jul 17, 2011 | Kenmore Dishwashers
Refrigerator freezer problem. Kenmore Elite bottom freezer refrigerator, model # 795.75546401, manufactured 9/2004 (LG is actual manufacturer). The Express Freeze LED turns on and 2 "beep"...
Press and hold FRZ TEMP button and REF TEMP button at the same time for 3 seconds.And see if that makes any difference in the problem. ---------- If the problem is same then try the manual reset procedure.In manual reset the unit has to be unplugged from power outlet for 24 hours.Then empty both the fridge and freezer section completely.Then after 24 hours.Clean the melted ice water from the inner parts.Then reconnect the power cord of the unit to power outlet.Set the temperature to normal settings.It will take near to 4 hours for your unit to run its regular cooling cycle.Once this is done then check,if the same problem is seen.-----------This will help.Thanks.Helpmech.
Dec 20, 2010 | Kitchen Ranges
Kenmore elite won't quit dinging
kitchenaid refrigerator, model ksRa25CN5500 stopped cooling
May 11, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Keep switching between jet and express. making ding ding ding noise.
Please explain what your meaning of jet and express so I can help you better. LG refrigerators are hard to get parts for. But, I can help you. So I can help and will you look for the model listed above your post. Please confirm the model number, this is very important, Thanks, Sea Breeze
May 02, 2009 | LG LRSC26930 Side by Side Refrigerator
We are new to the Kenmore Elite HE3 8674 dryer and it won't run
Our daugther in law came over, and she forcefully shut the door, and the dryer started working. We are going to have the Sears people to come out and make certain that this dryer is not damaged.
Feb 07, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
5,823 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
