Question about Zenith SY1951Y TV
I have a old tv zenith model sy1951y, and do not have a control, can you tell me how to set up the dvd or vhs player without the control.
  • 119 Answers
SOURCE: hooking up a cd player
you can use what is called an RF converter. it chanes the rca cables into a coaxial that will screw onto the back of the tv & you can connect the vcr to it at the same time. good luck.
Posted on Feb 19, 2007
JMuskovitz
  • 135 Answers
SOURCE: Hey
You can find the owner's manual for this set online at: http://www.zenithservice.com/gcsc/b2c/hpi/main?tc=owm.command.OwmCmd It says that the BOTTOM four connectors are: 1. S-Video IN 2. Video IN 3. Audio (Right) IN 4. Audio (Left) IN Above the Audio IN connectors are two audio OUT connectors, which you could hook to external speakers, your stereo, etc. But these are not needed for hooking up your DVD player. From your DVD player, you need to hook up either the S-Video or Video connection (Video is typically the Yellow wire), plus the Audio connections (Red and White). If your DVD player has an S-Video output, this will give you a better picture than the standard Video connection. S-Video cables have a different plug, with four or five wires in the connector, and are keyed so they only fit into the socket in one orientation. Be careful to line it up properly and not force it in the wrong way.
Posted on Feb 28, 2007
snakehead
  • 1074 Answers
SOURCE: Use Zenith XBV443 DVD Player / VCR Combo without remote control
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
Posted on Apr 08, 2007
jimbo4026
  • 50 Answers
SOURCE: zenith tv model sy3272dt
there should be a video input on back of the tv you can use, (red,white and yellow colors) this set I believe had more than one input. that would work for you dvd
Posted on Nov 28, 2007
SOURCE: Progressive scan mode will not disable
Hi, you must hold 1st remove the disc (if you have one in) then hold down the STOP which is just under the RECORD button. Hold it for about 6 to 8 seconds. That should clear it.
Good luck
trestaris
Posted on Dec 15, 2007
Why won't the Sony controls let me click onto finalize using a Sony TV w/recoder to transfer VHS to DVD?
Is the VHS tape you are trying to record a commercial VHS tape (movie)? If so, it may have copy protection on it. The recorder is probably programmed to prevent you from making and using DVDs of commercial copy-protected VHS tapes.
Nov 13, 2015 | Zenith XBR716
I have the Zenith XBV443. I'm trying to copy saved programs from my dvr on my tv to dvd discs. My neighbor has a simular model yet we can't find out why I'm unable to do the same. What do you think is the...
The Zenith player/recorder will be able to record to DVD from an external input such as a PVR. The most likely reasons you are unable to record successfully are:
1. The TV / DVR is not connected to the Zenith recorder correctly. You need a separate cable for recording. You cannot record using the cable that is connected for playback of DVD discs.
2. The TV / DVR does not have "VIDEO OUT" sockets
3. You have not selected the correct external input on the Zenith recorder
If you can let me know the brand and model number of your TV / DVR and how it is connected to the Zenith DVD recorder, I can let you know why it isn't working, how to make it work, and even draw you a setup diagram, if required. It's very difficult to give you the correct answer without these details.
You Zenith DVD recorder will record from the DVR - the real question is, can the DVR send video to the Zenith DVD recorder . . . ?
Regards,
BElectric
Feb 17, 2011 | GoVideo Go Video DVD/VCR Combo
Copy VHS INTO DVD
1. Set up with a new blank DVD.
2. Insert VHS and adjust to the beginning of
your recording.
3. Use the DUBBING button on your remote: you can adjust video quality (2 hours or 4 hours play) at this point.
4. RTFM for use of the PAUSE and DUBBING buttons to skip over commercials etc.
Feb 24, 2010 | Zenith XBR716
I have an old Zenith Digital Surround System the Receivver is a Model Z763B with a DVD Player/Recorder connected. When I play a DVD or VHS the sound can be heard through the TV and the Sound System,...
I have the same A/V receiver and in my setup there is an audio output (red and white able) coming from DVD player directly into Zenith Z763B. The video from DVD Player goes to TV input (yellow cable).
There might be alternatives to the setup mentioned above but I like to watch movie in a surround sound, rather than output from TV.
Jan 07, 2009 | Audio Players & Recorders
Recording from tv to vhs
I would have the antenna hooked up to the VCR. Then you could select any channel that you wish to record on the vcr without the tv being involved.
Jan 07, 2009 | Zenith XBV243 DVD Player/VCR
Recording from tv
the line out from your tv has to run into the line in on vhs/dvd player
Dec 27, 2008 | Zenith XBR716
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Hooking up a cd player
I'm assuming you mean a DVD player, not a CD player? 1. You can get an input splitter (basically an A/B switch for the cable), and connect to that, manually switching between the two sources. 2. You can replace the VCR and the DVD player with a combination DVD/VHS unit. Although it would seem logical, it is unlikely that you can hook the DVD player to the VCR, since the VCR will refuse to let the signal pass though it, as part of its MacroVision copy protection. (This is the same sytem that prevents you from recording DVDs onto VHS tapes.)
Feb 18, 2007 | Zenith B25A74R 25" TV
Televison & Video Logo
96 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
