Question about Sharp AL 1631 Copier
I have a sharp copier AL 1631- it's making a noise
I have a sharp copier AL 1631- i just replaced the toner with a refill... it's making a noise when i turned it on and when it copies...i read one of the solution, remove cover for the waste toner... was that the long plastic that covers the toner and it connects from end to end of the toner? what's that waste toner feed screw.. was there a screw??? where can i find it? any other solution? pls help.... (
    President:
  • Sharp Master
  • 990 Answers
Hello sir; Bring back the toner cartridge to the store where you bought for exchange.
Posted on Feb 08, 2010
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
Dec 10, 2010 | Sharp AL 1631 Copier
I have a red triangle flashing and the copier sounds like it is trying to warm up and then does nothing. what is going on?
Hi, this triangle means that the toner is empty. This can also be caused by a defective developer unit drive gears. Check that it is okay if not replace the gears. Replace the toner cartridge or refill the toner in its unit. Make sure you empty the waste on its side as it may cause some noise or toner spills. Use cartridge Sharp Al100td or refill with Sharp Al1000 toner bottle. All the best.
Nov 23, 2010 | Sharp AL 1631 Copier
We have a Sharp Model AL-1631 unit that keeps running but doesn?t make copies. Any idea what is wrong and how to fix it? Thanks.
When these Sharp AL series machine just run and run it means they are low or out of toner. This is especially true if you are hearing a light thump thump noise while it is running. Just let it run and after 5 minutes or so it should shut down and then replace toner light should come on. This is the small red light that looks like a stack of 6 dots.
Either replace the toner or have your existing toner refilled.
Good Luck and Thank You for using Fixya.
Sep 17, 2010 | Sharp AL 1631 Copier
Flashing pyramid of dots,
Your toner cartridge is empty. After turning it off then on again it is probably running for several minutes while making a light thump thump noise. This means it is trying to add toner but not getting any. You need to replace the toner cartridge or have it refilled.
Jun 10, 2010 | Sharp AL 1631 Copier
SHARP AR-203 copier unusable after refill
Change the unit chip or reset him.
Sep 01, 2009 | Sharp AL 1631 Copier
Sharp AL-1631
there is severl thing this could be 1. paper feed cluch need cleaned 2-bypayss roller lift arm need removed, 3-or the drum unit need clened out . all thses thing can be dones easilly by a sharp tech about $120 should do it. note this is the only model of copier left that you can refill the toner unit for $6 & drum for $15 ( id keep it )
Mar 10, 2009 | Sharp AL 1631 Copier
SHARP COPIER AL-1631
2 things:
1. Fusing Unit has to be replaced- worn or broken gear
and/or
2. Main Drive clutch has to be replaced.
Either way it has to be done by a trained technician.
Dec 24, 2008 | Sharp AL 1631 Copier
Al 1631
Simple you get a PM, new developer.. call an authorized Sharp Tech...
Oct 21, 2008 | Sharp AL 1631 Copier
Replace toner
Dear sir,
Commonly the sharp and toshiba toners are normally sealed units, therefore no toner refill avaibable.
Contact your service outlet to order a new toner cartridge
May 09, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
250 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
