Question about Whirlpool GHW9300 Duet Washer
Water leaking when machine is off
Water is leaking from the water outlet into the drum when the machine is off. It is a very slow leak but left over night it will fill up the drum.
  • 56 Answers
You need a new water valve. it is located at the back left hand side under the main top(the piece the hot and cold water hoses hook on to)
Posted on Feb 08, 2010
Why does my Kenmore washing machine leaks in front when agitating?
Most likely the sight of water leaking from the front of the machine, means it is leaking from somewhere else. Check all inlet and outlet hose connections. Hard water deposits build up and can cause minor leaks over time. If it is only noticeable during the wash cyclee,(agitating) it is possible there is a leak in the drum. Rare, but possible.
Jun 11, 2014 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Leaking washing machine
Need more information. What type of leak (fast, slow, seep, etc.), when does it leak (when it is filling, draining, all the time, or don't know), and where is the leak coming from? If water runs out as fast as it is filling, you may have a drain hose that is ruptured or has disconnected. If it is a very slow leak, you may have a connection that is working loose. Or, it could be as serious as a hole in the outer drum. Is this a top loader or a front loader washing machine?
Apr 10, 2014 | Maytag Washing Machines
Drum fill with water
If your machine outlet pipe is connected to the sink trap (many are these days) it could simply be that water from the sink is draining into the washer if it is connected like this ensure that where the outlet pipe leaves the the trap it goes up and does not run level or down if the water in the is dirty this is the problem failing this water vavles are passing water when the machine is off
Mar 03, 2014 | Whirlpool 3.5 Cu. Ft. White Front Load...
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Whilst wash on, water leaks from the underneath of washing machine. but cant see where it is coming from
if the water is leaking during the fill cycle when the detergent is being added from the drawer
ensure the draw is clear, if too much deturget rests has blocked the vent then water maybe running out on the inside.
if the problem is happening during the wash cycle this indicates a leak on your drum, ensure your door seal is intact and not leaking.
if the problem is during pumping, ensure that the pump is not causing a problem
maybe open the bottom vent and ensure the cover is seated properly and pump is clear.
also check the outlet pipe is not blocked or leaking and water is running back on the outside of the outlet pipe and under the machine
I hope this was useful.
May 23, 2011 | AEG Washing Machines
Why would the machine leak out the detergent drawer when filling?
When the machine starts to wash water passes into the detergent dispenser and carries the detergent into the drum, if the detergent outlet is blocked, or resticted, this will cause the water to leak out of the dispenser.
Check the dispenser to see if an accumulated crust of powder is clogging the outlet holes, most dispensers are removable for cleaning, check your machine instructions for details.
Dec 13, 2010 | Whirlpool GHW9400 Front Load Washer
Water leaks into drum and machine intermittantly
The mixing value is leaking. I ordered a new one and will replace it.
Dec 20, 2009 | Kenmore Washing Machines
The water is slow to drain and over night the washer filled up with water when it was empty and suppose to be off?
Replace the water valve on the washer, it is leaking water into the unit. Remove the drain pump and clean out any blockage causing the slow drain.
Sep 29, 2009 | Whirlpool Washing Machines
Leaks water inside washer overnight
Could be water fill valves ,,try turning them off for a few nights if this workds ..hey presto..if not could be drain too low,, water entering via sink outlet /drain....in this case raise hose..hope this helps you can let me know.....
Sep 29, 2009 | Washing Machines
Water Everywhere
Look for loose, cracked, pinched, broken hoses to and from the water pump or leaks from the water pump itself. The outer drum could have a rust-through that leaks. This can be repaired with epoxy, but the inner drum must be removed to access it. The cabinet top is opened by using a putty knife or similar tool to push straight back under each front corner which releases a spring latch. Sometimes, the drain hose outlet is pushed from the house drain by high water flow. Tie the hose to the drain with tape or cord. Fill the tub with water, then stop the cycle and watch for leaks.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
313 people viewed this question
Dan Webster
Dan Webster
Sal De
