LG rear projection tv
I have fit a new lamp in my tv,but can not seem to reset the fault
indicater lamp.
I have the same problem, did your lamp come in its case?
Posted on Feb 22, 2008
I have a LG rear protection tv. I believe 52sz8d-is. When I plug it in the red power led light comes on and the bulb led flashes green but it won't Turn on
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Jun 05, 2011 | LG RU-52SZ51D 52" Rear Projection...
LG 52" Rear projection TV
Probably something wrong with the lamp. Buy a replacement.
Mar 01, 2011 | LG RU-52SZ30 52" Rear Projection...
Light indicater keeps coming on light wont stop. mitsubisi brand
Have you had the bulb replaced in the unit yet? There is a timer in the unit that is set to a specific number of hours. If that is not reset when the lamp is changed you may still have this problem. The issue could also be unrelated to the lamp but in the power supply itself. I think you would be best advised to contact a repair shop about the unit.
May 12, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp, indicater light still on - Zenith E44W46LCD
hello make sure the lamp fitted securely and the front cover is fitted securely as well
shaun
Oct 25, 2009 | Zenith E44W46LCD 44" Rear Projection...
LG Rear Projection TV won't turn on
Could be your Ballast Board that fires up lamp or Fan is bad that cools Lamp there is also a Fan mounted up under Light Engine if it stops running set will not come on. CK Fan Behind lamp first if it is OK then replace Ballast Go to E-Bay for Best Deal on that part .
Aug 14, 2009 | LG RU-44SZ51D 44" Rear Projection...
How do I reset the lamp life on my LG 52SZ8R.
hold the mute on the remote and press enter on the tv and it will come up in the menu for you to reset
Jul 08, 2009 | Televison & Video
How to reset the lamp timer count on a LG rear projection TV
1. Press the OK or enter button on the front panel and MUTE
button on the remote control simultaneously (About 5 seconds).
2. Press the VOLUME (>) button.
3. Press the OK or enter button.
Lamp time will be reset.
Jun 15, 2009 | LG Televison & Video
Lamp has been replaced but TV wont power up?
If the lamp is a known good one, the next most likely suspects are the lamp ballast/power supply board or a mis-aligned lamp door. There's an interlock switch which opens when the lamp door is removed. Try removing and re-installing the lamp and the door.
Feb 15, 2009 | Zenith E44W46LCD 44" Rear Projection...
LG rear projector tv
Someting does not fit in here. The model 42LC2D is a plasma model and it has no lamp inside. Every part is covered by the warranty on this model.
Jan 03, 2008 | LG 42LC2D 42 in. LCD HDTV
LG Projection TV has dark picture
To do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
Jun 30, 2007 | LG RU-44SZ51D 44" Rear Projection...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
